Question about Sony Playstation 3 (PS3) Console
Ps3 error 80710723
Update error
  • 7 more comments
  • holton1989 Jan 02, 2009
    i keep trying to update my ps3 so i can go online but it keeps coming up with error 80710723 and says a connection 2 the server cannot be established sometimes it only updates 2 i percent an sometimes it goes up 2 26 percen5
  • Anonymous Jan 10, 2009
    If I was to log on to the net from my PS3 I can so that. If I do an innernet connection test it will connect to the net. It is just with Rockband 2 that I get the error code (80710723). I need HELP!!
  • ktjones1985 Jan 29, 2009
    but the error message I'm receiving is 80710723 "connection to the server cannot be established". The post you linked to refers to different error messages, so I'm not sure if that solution would work or not. It's weird, because it won't let me go online until I download the new update. But whenever I try to download the new update I get this error message. What's even more strange is that I will get part way into the download (5%, 8%) before getting the error. So it's not like it can't "establish" a connection, it seems like it has a connection but then loses it for some reason. However, the signal strength to the PS3 and internet connection through my computer remain stable at all times....
  • rocheteay Feb 03, 2009
    I have the same issue. I am trying to perform the update and after 5% + or - an error 80710723 appears and stops the download despite internet strength is 100%
    I my settings I left the IP address as Do not use... is this the problem? if yes what IP address I shall use
    Tnx in advance
  • mooncrooner Feb 23, 2009
    I had the same problem (error 80710723) when trying to download the patch to Resistance 2.
    This solved my problem (for the linksys router):
    http://boardsus.playstation.com/playstat...
  • Anonymous Feb 26, 2009
    i was about to play call of duty online when it said i had to do an update so i clicked the update and at first it was but just REALLY slow so i restored my ps3 hoping it would fix the problem but it didn't and between 3 - 9 % of downlaoding it would come up with the error 80710723 can anybody help with this ?
  • Anonymous Feb 28, 2009
    yeah i was trying to play cod5 and the system tried to do a software update 1.03 and then it wouldnt even go to 1% and it said error 80710723
  • Anonymous Mar 06, 2009
    The error comes while I am updating my ps3
  • Anonymous Mar 21, 2009
    I need to update cod 5 and it always says error 80710723
This same problem happened to me awhile ago. The way I fixed it was I went under settings to network settings. Then went down to media server connection and disabled that. Once I did that I had no trouble at all updating games. Hope this helped :)
Posted on Jul 18, 2009
I too went into "network settings" on my PS3 and disabled the "media server" connection. Worked like a charm!
Posted on Jan 09, 2010
Just wanted to say disabling the media server connection worked like a charm for us too with COD Modern Warfare 2 Thank you so much!
Posted on Dec 22, 2009
    Scholar:
  • 44 Answers
This is a common error. Check you network connection setting on you PS3. That should tell you the ip you are using. To enable DMZ log into your router through your browser ussually to do this the address is http://192.168.0.1/. You will be asked a password and username. Most cases it is "admin" and password is left blank unless someone has changed it. Also with your PS3 connected the router will tell you the assigned ip address under wireless connections. For more details about people with similar problems, please refer to this link. http://boardsus.playstation.com/playstation/board/message?board.id=psnetwork&message.id=28580
Posted on Oct 18, 2008
    Filmmaker:
    Uploaded 5 video answers.
  • 42 Answers
You have a few solutions for the 80710723 error -
  1. Try using a wired Internet connection.
  2. Disable the 'Media Server' in your settings menu. (System Options/Network Settings)
  3. Manually update from Sony using a USB drive.
Check out this article here for a full and in-depth guide to doing this, plus a video guide.
Posted on May 10, 2011
    Problem Solver:
  • 7 Answers
What I did to stop this error was to go from my wired connection to the wireless connection and during the setup I disabled UPnP and I was able to complete the system update that I was needed to Play COD5.
Posted on Feb 01, 2009
This worked for me, I just bought my ps3 on 30/12/09 and it would not link to my wireless network even when it found my wireless network (netgear) with the network key entered. I began to scratch my head looked on the internet and gathered some ideas, now I'm no network nerd but this is what I did- firstly you'll need to beg borrow and steal an Ethernet cable plug it into your PC or already connected wireless laptop and internet, then plug it into your PS3, then scroll across to settings and then system update you will then download straight onto your PS3 with software version 3.15. I guess there is some kind of fix for wireless in there and now it connects to the internet as it didn't before.
Posted on Jan 04, 2010
Try this link: http://digifaq.blogspot.com/2011/06/how-to-fix-ps3-error-80710723.html , That works for me. Hope I helped
Posted on Jun 29, 2011
5 Suggested Answers
v4ndre
  • 148 Answers
SOURCE: ps3 wont update error 80710723
be carreful about newer updates....sometimes this hot releases comes with problems...i think wait should be the correct decision...then if nobody got problems with it..try the updade as well.
Check out the cables of your internet conections and if your pc is acting like a server and sharing internet connection maybe the firewall is blocking your PS3 update... Good Luck!
Posted on Dec 04, 2008
SOURCE: Ps3 error code 80710723
we have a playstation 3 and we cannot figurew out to get on the internet.....what is a port number and what is a ip address?
Posted on Mar 15, 2009
benwabnick
  • 2404 Answers
SOURCE: what dose error code 80710723 mean when trying to
Your PS3 is not downloading updates because you need to deactivate the "Media Server Connection" under Network setting.
Posted on Apr 23, 2010
SOURCE: keep gettin error code 80710723 when updating system on ps3
mae your playstation 3 wired then download it. once downloaded then go back to wireless.
Posted on Jan 12, 2009
How do I fix Windows 10 update 0x800705b4 error code?
This error commonly occurs within the operating system at the time of windows updates. If this error is not fixed, it will lead your system slow or even corrupt it.
This error may arise for the following reasons,
1. windows defender update
2.
Damaged system files.
3.
Third-party anti-virus and malware.
Solution for the windows 10 updates 0x800705b4 error code:
Right here are a few solutions for troubleshooting 0x800705b4 error code,
Method 1: Uncheck the "get updates for other Microsoft products when you updates windows" option:
• Open the "Windows Update" and click "Advance Options".
• Uncheck the "get updates for other Microsoft products when you updates Windows" Option if it's marked.
• Now the update process should complete successfully.
• You may run this process continuously until you get the "your device up to date" message.
• Once this message appears, again check/select "get updates for other Microsoft products when you updates Windows" Option.
Method 2: Temporarily disable the "Windows Defender"
• In case, the above solution doesn't work, you can disable the" Windows Defender" for temporarily.
• Type Defender in the search box and open the Windows Defender Desktop app.
• Click "Settings" and turn off the Real-Time Protection and Cloud-Based Protection options.
• Close the setting window and now the windows defender appears in red.
Note: After that do all the steps in solution 1 again, hope the update process will be successful this time. Once this issue is fixed, you can turn on both Real-Time Protection and Cloud-Based Protection.
Method 3: Run the Windows Update in "Clean Boot"
You should login computer as an administrator for performing "Clean Boot".
Method 4: Run the "Microsoft Update Troubleshooter" and Restart the Windows Update:
Still, if you having update issue, download the "Windows Update Troubleshooter" and Run.
After this, restart the "Windows Update Service".
Follow these steps for Windows Update Service restart,
• Open the Command Prompt(CMD)
• Type "net stop wuauserv" then press "enter"
• Wait for the confirmation message.
• Then type "net start wuauserv" then press "enter"
Hope the above solution will fix the update issue.
Jun 12, 2017 | Computers & Internet
Hi my mum has just purchased windows 8..can get onto facebook...but when she wants to play mindjolt games..(golf solitaire) it will come on... but then has a white screen where the game should be.altho it...
Hi there. Firstly... make your mom a cup of tea . You know how to calm her down . Then take on this task . It looks like a impossible task , but just follow the instructions . You can do this: Install the Windows 8.1 Update (KB 2919355)
  • ?Email
  • Microsoft support. Code 0x800F0922 This error might mean that a file needed by Windows Update is damaged or missing. Here are a few steps you can try to fix the problem:
    1. Run the Windows 8.1 Update troubleshooter to fix the problem.
    2. Install the Windows 8.1 Update or Windows RT 8.1 Update.
    Code 0x800F0923 This error might mean that a driver or other software on your PC isn't compatible with the update. For info about how to fix this problem, contact Microsoft support. Code 0x800F0922 This error might mean that your PC couldn't connect to the Windows Update servers. If you're using a VPN connection to connect to a work network, disconnect from the network and turn off the VPN software (if applicable) and then try to install the update again.
    The error could also mean there isn't enough free space in the System Reserved partition. You might be able to fix this problem by using third-party software to increase the size of the System Reserved partition. Error: We couldn't complete the updates. Undoing changes. Don't turn off your computer.
    Error: Failure configuring Windows Updates. Reverting changes. These are generic errors that might appear any time a Windows update fails. You'll need to determine the specific error code to investigate how to best resolve this problem
    You can find the error code for the failed update by viewing your update history. Look for KB 2919355 in the list, note the error code, and then contact Microsoft support.
    To view your update history:
    1. Open Windows Update by swiping in from the right edge of the screen (or, if you're using a mouse, pointing to the lower-right corner of the screen and moving the mouse pointer up), tapping or clicking Settings, tapping or clicking Change PC settings, and then tapping or clicking Update and recovery.
    2. Tap or click View your update history.
    Error: The update is not applicable to your computer. This error might mean that your PC doesn't have the required update KB 2919442 installed. Check to make sure that all important updates, including KB 2919442, are installed on your PC. If all updates are installed, you might need to refresh your PC.
    To refresh you PC:
    1. Swipe in from the right edge of the screen, tap Settings, and then tap Change PC settings. (If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, click Settings, and then click Change PC settings.)
    2. Tap or click Update and recovery, and then tap or click Recovery.
    3. Under Refresh your PC without affecting your files, tap or click Get started.
    4. Follow the instructions on the screen.
May 07, 2017 | Computers & Internet
STATUS CODE 4099-4174-1600-0700-C000-000E
Xbox.com has a handy search page to lookup error codes:
http://support.xbox.com/en-US/error-code-lookup
From that page, those is the answer and resolution they give, good luck:
" Error C000-000E occurs when you try to download an update to your Xbox 360 console
Problem
You see the following error when you try to download an update to your Xbox 360 console:
error code xxxx-xxxx-xxxx-xxxx-C000-000E
Update failed.
Note In this error code, the "x" digits vary.
This error message means your console could not download a software update from Xbox Live.
Solutions
To resolve this problem, try the following solutions:
Solution 1: Try installing the update again.
Solution 2: If you're having problems connecting or staying connected to Xbox Live, see Troubleshoot your Xbox Live connection.
Note You can also update your console software by copying the update to a USB flash drive or a disc and then applying it to the console. "
Jun 13, 2014 | Microsoft Xbox 360 Console
How do I fix windows error update 8 to 8.1 0x80070003?
copied from windows website.
Windows Update error 0x80070003 Applies to Windows 8.1, Windows RT 8.1 If you receive Windows Update error 0x80070003 or 80070003 when you use Windows Update, try running the Windows Update Troubleshooter.
May 15, 2014 | Microsoft Windows 8 For Tablets
Windows Update error code 80070103
This windows update error code means you already have the latest drivers installed onto your computer and you don't really need to upgrade it.
To know more, follow this link: Windows Update error code 80070103
or you can also visit: Update error Code 80070103
Hope this helps, Mrityunjay.
Jun 16, 2012 | Computers & Internet
Error 6000
http://www.restoreguard.com/p/error-6000.html?keyword=Error%206000&cct_info=1'26128'9823937937'55695897'1164023577'p'6525875547'kw'3000013024'g'''&cct_ver=3&cct_bk=error%206000&gclid=CPWE9JKtmasCFaEG4godnRrZhg
Please download the tool and install
Sep 13, 2011 | Office Equipment & Supplies
A sony update came.i started to install.then a error message came.it said update error happen and will try again.it did it 3 times.till a error number came up.went to sony site and it said to try reset.but...
If it was an error after the update was downloaded then the only thing I can think of is restoring the PS3 to factory settings and trying again.
Many times I got such an error it was because my connection was fickle, it would keep cutting out and not properly downloading the update and causing an error. In this case I would have to just keep restarting the update and hope it would finish.
Hope this helps.
Mar 11, 2011 | Sony Playstation 3 (PS3) Console
Update KB946140 and Error Code 646
Sometimes MS update has compatibility issue.Better no to install cause sometimes it can create a bug (Blue Screen Crash) to your system.Try to restore yor windows 7 to an earlier point and the error message gone.Also try to turn off your automatic update so that you can choose your update to be installed.
Nov 09, 2009 | Microsoft Outlook with Business Contact...
Microsoft updates
Most of the time when updates cannot be installed, is because you have installed a file that is newer than the one provided by Microsoft, or you already have the "update" and Microsoft gives you the error.
Essentially when your computer communicates with the Windows Update website. It uses TWO technologies called:
Active X - to interact with the Microsoft site. The first time you visit the Update website, using your profile, you are asked if you will accept the Windows Update Control Package (the Active X control) onto your machine.
SSL (Secure Socket Layer) - A method of data encryption used by Internet Explorer.
Now this general error message 0x800A138F, that some folks get when they visit Windows Update, has been around for a while. BUT, when the MSBlast virus was unleashed Microsoft changed a few things at the main update website. One of them was to use Akamai for additional bandwidth and this connectivity is exclusively using HTTPS (SSL) for the downloading of the update catalogue. It is since then that we have seen an escalation in the number of 0x800A138F error messages!
The following steps will help many of you... BUT
What would be REALLY helpful to anyone trying to support you, is if you go to the "Windows Update Log" and look for any "Errors". This gives a clearer indication as to the exact nature of the problem. (The 0x800A138F error message is a "General" error THE real error number is in the log. A list of possible error messages is in a table at the bottom of this page.)
The windows update log is in the following places:
C:\Windows\Windows Update.log (Win XP & Win98/Me)
C:\WINNT\Windows Update.log (Windows 2000)
Just copy and paste the above in Windows Explorer to open the log file...
Feb 26, 2008 | Microsoft Windows XP Professional With...
Turbo tax
Go to this website http://turbotax.intuit.com/support/kb/update/update/2201.html?lid=stic double click the link maualy update your Turbo Tax hope i help you with your problem :p
PS:
or
Error 9111 indicates a connectivity issue:
An error occurred while we were checking for TurboTax updates and we could not connect to the program update system.
Your computer's firewall or other security software prevents TurboTax from accessing updates on our server. Error 9111 will continue to occur until you resolve the issues caused by your firewall.
Do one of the following:
  • To temporarily work around this issue, manually update TurboTax.
    icon_note.gif Note: Manually updating TurboTax does not resolve connectivity issues caused by your computer's firewall. We recommend you address these issues before attempting to update TurboTax again.
Still can't update? If you still have problems updating TurboTax, order the free update CD. To order, call us toll-free at 800-624-8384.
or
It's Blocked with your Firewall try UnBlock it to your firewall
for Firewall removal instruction click this link:
http://turbotax.intuit.com/support/kb/connectivity/firewalls-and-anti-virus/113.html
Feb 24, 2008 | Microsoft Office Outlook 2003 for PC
Sony Playstation 3 (PS3) Console Logo
25,044 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
