Question about Kenmore 15129 Built-in Dishwasher
Kenmore dishwasher 665.1671590
Dishwasher quit filling with water and I found the solenoid coil open on the inlet water valve. Replaced the coil and checked. The water sonenoid is working now. Water is coming out of an opening near where the water enters the sump. It is an open vent maybe. I don't know. I can see it coming out a plastic opening above the water valve just below the black water hose connection as it bends back down and into the sump.
  • Jay Pair Jun 08, 2006
    Thank you guys for responding.
    I didn't have any water leak problems untill I replaced the solenoid coil. I know that its strange that now it is having this problem and not before.
    The fill hose is in place and I did remove the screen and clean it after I replaced the ciol. I didn't take the solenoid valve apart. Could something fall out of the solenoid valve when I took the screen out?
    President:
  • 878 Answers
Your inlet hose probably came loose on the left side of the dishwasher. If you pull the d/w out 6 inch. or so you will see the s-shaped hose going to the inlet port on the tub. Make sure it's not pinched or leaking..Catriver
Posted on Jun 07, 2006
  • 641 Answers
Did you have this problem before replacing the solenoid coil or it start after ? In case it started after solenoid coil replacement, its look like you did something wrong while assembling it back. Disconnect Dishwasher power cable and close water tap - remove the selenoide coil, clean the valve from scale or other dirt and check that you placed all parts back properly (spring,gasket...). Good luck !!
Posted on Jun 06, 2006
  • Dov Dror Jun 08, 2006
    If you didn't done it before,take the solenoid valve apart
    and clean it from any scale or dirt (be aware not to lose parts)sometime, scales or other dirt could prevent the valve from doing its job properly.
    Good luck !!!
Diplomat ADP8342 won't fill with water
Assuming the water tap is open and the water pressure is correct, it is likely the inlet water valve in the dishwasher is faulty. If you hear a click at the time the cycle starts but still there is no water then the inlet valve needs to be replaced. Also check the inlet hose for any kinks or blockage of the filter attached to the tap inlet.
The inlet valve looks like this item
Diplomat ADP8342 Solenoid Valve
Aug 05, 2014 | Dishwashers
Dishwasher not filling
The water float switch, located on the inside bottom of the machine, may be stuck in the up(off) position keeping the water valve from functioning. This is a safety device that turns the water valve off when the machine fills in order to keep it from overflowing.
The water inlet solenoid mounted on the inlet valve under the bottom front may also be malfunctioning not allowing the water valve to open and fill the machine. If electricity is present at the solenoid terminals when the machine is in fill cycle, then check the solenoid coil to see if it is open(no continuity). Also, the timer may not be calling for water/ sending voltage to the inlet valve solenoid.
I would start by manually operating the water float valve a few time to see if that helps. You should hear a microswitch click each time the valve stem is moved up or down by the float. If not, check to see if voltage is getting to the float switch and the water inlet valve solenoid.
Most(if not all) machines have a safety cutoff switch which activates when the door is opened. That switch could also be malfunctioning not allowing voltage to the water inlet valve solenoid in fill cycle.
Jan 26, 2012 | Meiko Dishwashers
Dishwasher won't fill with water
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Kenmore Dishwashers
Switch dishwasher on and starts up ok but when it comes to pumping water in it stops and does not do anything else.
Hello
Investigate these five areas if your dishwasher won't fill with water:
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem. You can learn how to access your water inlet valve in the replace a dishwasher water inlet valve section.
Alternatively, your water inlet valve could be defective altogether. That could be the reason your dishwasher is not filling. Test it for continuity. If it is not functioning as it should, replace it.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 22, 2011 | Dishwashers
Hotpoint Super Plus 7821 dishwasher isn't drawing water, please help thank you
Hello
Water Inlet Valve
Aug 03, 2011 | Dishwashers
On whirlpool dishwasher on litle screen we get notification "F6", what should we do, what does it mean?
This is what it means:
F6. 6 Flashes. Water valve (WV1) is switched on but flow meter (FM) senses no impulses (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
Water Valve Closed. Water inlet hose blocked.
Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
The above info is pretty self explanatory but the bottom line is the dishwasher either is not filling fast enough or... is sensing that it is not filling fast enough. Check your inlet water line for flow by first turning off the power and water supply line then remove the line .... open the wall connection valve and check the flow. Also take a flashlight and small mirror if need be to check the hole of the inler to the water valve.
Thanks for choosing FixYa.
Kelly
Sep 02, 2010 | Microwave Ovens
My dishwasher will drain but will not fill up with water ?
Hello there
Specific symptoms include: Little or no water enters the tub . To find the cause, first check to be sure the water is ON.
always “zero” the ohmmeter before making any continuity checks on dishwasher components. . When making continuity checks with the volt/ohmmeter, always turn the electricity OFF at the circuit breaker panel. Live voltage checks will damage the meter movement.With the water ON, remove the lower panel. Place a towel or shallow container on floor to absorb water. Loosen the nut that secures the dishwasher water tubing to the inlet port of the water inlet valve. If water collects immediately in the towel or container, it can safely be assumed that the water pressure is adequate and the plumbing system is not clogged . If little or no water collects in the container, the water line gate valve could be defective or there is a problem in the plumbing system.
Turn the water OFF. Remove the lower panel. Loosen and remove nut that attaches water tubing to water inlet valve inlet port. With tubing removed, check for corrosion and debris that has accumulated inside the tubing and inlet valve inlet port. . Turn the water supply ON. Select a cycle on the timer dial where the dishwasher starts to fill with water. If it starts to fill with water — you fixed it. The problem was corrosion inside the water tubing or inlet valve water inlet port. If the dishwasher still does not fill with water, an additional electrical check will have to be made.Next, test for electrical power to the water inlet valve from the dishwasher timer assembly. Using the volt/ohmmeter, set the meter on the 150-volt scale and attach the two test leads of the volt/ohmmeter to the two terminals of the water inlet valve solenoid coil to be checked. Turn the water ON. With the test leads attached to the solenoid terminals, select a cycle on the dishwasher timer dial where the dishwasher starts to fill with water. Push in or pull out the timer dial. You should get a voltage reading of 110-125 volts A/C on the volt/ohmmeter scale. If you get a reading, this would indicate that electricity is available from the dishwasher timer assembly to the water inlet valve.However, the absence of water flow means the water inlet valve is defective
Dec 31, 2009 | Maytag Dishwashers
Water does not drain in my kenmore ultra wash iii 16779
Hi!
Thanks for using FixYa. Disconnect the power source to your dishwasher before you conduct this or any other test. Either unplug the unit from the wall outlet, or flip the appropriate breaker in the circuit breaker panel. Locate your dishwasher's water inlet valve. It should be located behind the lower kickplate panel in either the right or left corner. There will likely be two screws either on the top of the panel, or on its bottom. Remove these two screws, and then remove the kickplate. On some dishwasher models, the door has to be opened in order to gain access to, and remove the kickplate’s screws. Close the door before you remove the kickplate panel.
You will be able to identify the water inlet valve by the hoses that connect to it. There will be one hose feeding water from the house to the water valve, and another hose leading from the water valve that carries water away. Now is a good time to inspect your dishwasher's hoses, to make sure they aren't responsible for any water flow problems. Make sure the hoses are securely connected to the valve. Also check to make sure there are not kinks in the hoses. Kinks can impede the flow of water.
There will be two wires connected to the water inlet valve. If your dishwasher's water inlet valve has two solenoids, then there will be four wires. Label the wires so that you will be able to correctly reconnect them later. The wires are connected using slip-on connectors. Grasp the connectors and pull on them firmly in order to disconnect the wires from the valve's terminals. Do not pull on the wires themselves. You may want to use a pair of needle nosed pliers to help you.
Use your multi tester to test the valve for continuity. Set the device to the ohms setting x 1. Touch each of the meter's probes to a terminal. If you receive a reading of infinity, it means the valve's solenoid is faulty and the valve needs to be replaced. If your valve has two solenoids (four terminals), test the second pair of terminals in the same manner. If either pair of terminals receives a result of infinity, replace the water inlet valve.
You do not have to remove the water inlet valve from the dishwasher in order to test it. Just make sure power is not getting to your dishwasher before you conduct the test.
Interestingly enough, it is entirely possible for your water inlet valve to pass the continuity test and still need replacing. This is because sometimes the valve itself is faulty, but its solenoids are not. For instance, a leaky valve may pass the continuity test, but because it is leaking, it should be replaced anyway. The same applies to valves that are filled with debris. The debris may be what is causing the valve to not function properly. If you are unable to clean out a debris-filled water inlet valve, you will have to replace it.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 09, 2009 | Kenmore Dishwashers
No water coming into dishwasher
dishwasher will not fill with water: This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned. ----- There's no water entering the machine If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Nov 03, 2009 | Kenmore Elite 21086
Dishwasher will not fill up with water
did you chek the level micro switch thats in serie with the intlet valve
Jun 18, 2009 | GE 24 in. Profile PDW7800 Built-in...
Kenmore 15129 Built-in Dishwasher Logo
629 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
