Question about Hitachi 57G500 57" TV
Hitachi 23" tv/ toshiba vcr
Not sure i'm in the right area, but can't find anything more relevant. i have a hitachi tv on which i run videos and dvd's from a toshiba unit. sometimes the tv screen go black, either immediately or gradually during the film. the time it has been playing can vary considerably, and sometimes it doesn't happen at all. i turn the vcr off and the tv picture is fine, later i can return to the vcr and the picture is fine. any ideas?
    President:
  • 3,130 Answers
Sounds like a problem in your VCR IF what your saying is when the screen goes dark and you turn off the VCR then the screen on the tv returns to normal?? Does this happen with the vcr on and the tape not playing?? No Ok you have a problem in the video processor Ic or the circuit but most likly the IC as Ive seen this already twice in a toshiba VCR. No if it happens even when the VCR is on but the tapes not plying and the vcr is sitting, and the screen fades The problem is the on screen disply IC in the vcr. seen this a dozon or so times already. Vcrs no a days are not worth the money to invest Unless you got a really good one from the past, BUT you can by a good on for these times for well under 100 bucks . Good Luck
Posted on Jun 07, 2006
Connecting my VCR/DVD combo to Toshiba television
It would be helpful to know what cable your trying to connect, component, S-VIDEO, HDMI, etc. Also the make & model of the combo unit & Toshiba TV. However the basic process is usually the same for most hardware. Make sure the connection to combo unit is "video/audio out" not in and make sure the input for the TV says IN not OUT. Then you need to set the TV to the correct input channel. And then make sure the combo unit is using the correct output... usually this is automatic for component cables but not always.
Nov 16, 2011 | Toshiba Televison & Video
Doesn't show anything on TV
I am sure that your cables are connected correctly. If they are your TV and DVD/VCR palyer has to be on the same function. i.e. aux on the newer TV's or channel 2 or 1 on the older models. THis is a easy fix and this will start you on the right track.
Jul 16, 2011 | Toshiba SD-V296 DVD Player/VCR
My dvd player works and plays movies but i changed the video to s-video and now i can't see anything on my screen just able to hear movie play. how do i reset it back to normal video?
Make sure you're tv is set on S-VIDEO, not AV1 or AV2 or VIDEO 1 or VIDEO 2, etc... there's most likely a setting on your tv to select your input to S-VIDEO.
Oct 09, 2010 | Toshiba SD-4100 DVD Player
There is no colour on the movie
Make sure you have the cables hook up right. If you are running component mode it takes three for video blue red and white ends. If you are running composite it takes red, white, and yellow.
Nov 20, 2009 | Toshiba HD-A20
Reset Toshiba SD-5000 Dvd player to factory defaults
With most Toshibas, you could un-plug them and leave it for either 10minutes or 30minutes and it would reset. strange, I know. give it a try.
I also found this when working on a similar problem with your player, it may be relevant -you could try pressing the power button and another button..
sorry, I don't have one in front of me to test..
[[power off the player
hit the power button and immediately hold the HDMI select button
the 3 HD indicator lights will cycle and then pushing the HDMI select button will move through the resolutions.]]
Aug 31, 2009 | Toshiba SD-5000
Dvd won't send picture/audio to tv
for video, 3ways and any of this should work.
Step1, video out of dvd to video in on top at video1 section on tv. or
Step2, svideo out of dvd to svideo in at video1 section on tv. or
Step3. using component video DVD unit component video out to TV unit component video in at video2 Y to Y input of TV Pb to Pb input of TV Pr to Pr input of TV
for audio, connect left/right audio of dvd to left/right input of tv. Input section of TV is in the middle. on tv back panel from left to right is antenna input, IN section - this is it, use this for all your connections. let us know if you have any issues. thanks.
May 02, 2009 | Panasonic DVD-S27 DVD Player
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvd wont work.
First, is the DVD player output (Video out, audio out) connected to the TV input? Have you used the Yellow cable from  DVD video out to the TV video in? Mixing the audio and video cables will result in no signal. Have you selected the proper input with your TV remote control. Most plasmas accept a variety of input signals; you must select the right one. I deal with a number of these issues. Usually the connections are made improperly or the correct input source is not selected with the TV remote. Put a DVD in the player and press play. Be sure you have made the proper connection from DVD player video/audio out into an auxiliary or video input on the TV. These could be labeled Line 1 or Line 2.  With the DVD playing, run through the input options on your remote control. The button might be marked source, video or input. The screen should display your choices i.e. video 1, video 2, etc. When you see your DVD program, you've got the right combination.
Dec 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Will not show picture on disc
Check the RCA wire or fiber optic conection. If you use RCA wire be sure you put Video output from your DVD to input Video of your tv set.
Apr 16, 2008 | Toshiba D-KR10 Multi-Drive DVD Recorder
Hitachi 57G500 57" TV Logo
70 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
