Question about Toshiba 42HP95 Television
Thank you wow man your a genius. Thank you so much for helping me i thought for sure i was going to end up paying a **** load for this to be fix. i did exactly what you said to do and it worked perfectly. I cant thank you enough really thank you. if your ever in San Diego please email me Randyco03@yahoo.com ill buy you some beers. thanks again man i appreciate this so much. Cheap Tech know his stuff
Cheap Tech,
I just had to write and say THANK YOU SOOOOOO MUCH!! We had the same thing happen. We tried your solution and it worked like a charm. We can't thank you enough. These days, and in this economy, who can afford to go out a buy a new TV (especially when the one you have is only 3 yrs old)?? As an aside, we will NEVER buy a Toshiba again...
Posted on May 04, 2009
Randyco03,
Glad this was of help! Normally I don't take the time to post about stupid fixes that I find but was so dumbfounded by how easy this fix was and how little information was available about it that I just had to post... I travel quite a bit so you never know, I might end up on your door step looking for beer!
Good Luck,
CheapTech
Posted on Oct 18, 2008
I purchased driver pro lifetime and I need to use activation key to fix driver problems
NEVER pay for driver software. You can get ALL of the drivers you will need from your laptop manufacturer. Stop the payment immediately.
Provide me with your exact model number and I will help you.
Feb 04, 2015 | DriverSoft Driver Genius Professional...
Tip
I thought for sure I would have to call a repair man. I did exactly what the...
This advice is for Kenmore Elite, Whirlpool Duet and Maytag Epic model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Feb 27, 2010 | Washing Machines
Engine wont start after charging, will start with a jump. The pto will not engage
Sounds to me like you need to scrape the **** off of the battery cable ends and the battery posts,or you just have a battery that has sulfated and will not take a charge.Repairing the connections or installing a new battery should fix the starting problem and because the pto is engaged with electricity it should fix that too.
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Is it Possible To Run Bright Lights as Dim Lights?
The repair guy fixed the front end? Why? Was it in a crash? If so why not take it back and have it corrected?
Mar 04, 2017 | 2000 Toyota Sienna
Yellow light keeps blinkingand the tv wont turn on
If the status light is blinking yellow it means the filter cover is open ( On the left side of televison)
If the lamp light is blinking yellow it means the lamp cover door is open. ( Behind front lower panel) If both covers appear intact the switches may be defective or not engaging properly.
Dec 11, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Freezer Works Frig Stays at 70
Wow, pay for the Premium Assistance Plan to get a quick solution ! I fixed my issue but thanks for the help ! I went to a FREE online forum and got my fix.
Mar 25, 2009 | Maytag MFD2561HE Stainless Steel Bottom...
I have a GE brand new washing machine WSSH300GWW, great front loader machine, as soon as I turned it on, I could barely hear it, loved it. But as soon as it went through its spin cycle, wow. I thought my...
First thing is to make sure all of the shipping (brackets, bolts, straps, etc) have been removed.
Do FULL loads, NO partial (small) loads, these machines do NOT like small loads.
Where is the washer? Basement, first floor, second floor. Basement is the ideal place, on a concrete floor. If not, does the dryer shake when the washer does or is it just the washer? If the dryer does, the it could be the floor, not re-enforced enough. If all else fails call for service since it is NEW, but chances are the servicer will say what I just said.
Jan 07, 2009 | Neff W5340X0 Washer
Control locked
is any thing on or working check to make sure door is latched
Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Controle light stays on
Press and hold 'dry' & 'spin', shd unlock
Apr 14, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Televison & Video Logo
325 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
