Question about Mitsubishi Heating & Cooling
Water leaking into front passenger floorboard
    Novelist:
  • 124 Answers
Look under the hood . find the big plastic fan cover on the right side passenger side of the car. reach you hnd down under it and be prepared to get dirty. undewr the bottom of the plastic shroud of the cvover is a hole the size of a pencil . that is where the water that condenses out from the ac drips out. they get plugged. stick a dull pencil erasser sized object up in the hole and water will usually gush out. in worst case , use a shop vac and a piece of rubber hose and **** it out. be advised even with all else ok you can sometimes get a drop of water on the toe of right passenger at times. sometimes even running over a sert of rr tracks at high speed can b ust loose the clog. usually the pencil works best.good luck guy..........
Posted on Oct 18, 2008
My 2000 ford crown Victoria. Have water on the rear passenger side floor. What could be the problem
Hey Grady..
There are few things that could cause the water intrusion... Is the carpet in the front floorboard wet?.. ..Has it rained recently? This will rule out window seals leaking? Have you opened the trunk and checked to see if water is in the trunk? OK..IF it has not rained, no water in the trunk, AND the front floorboards are wet, then the heater core is leaking...
Do It Yourself and DIY Auto Repair by ChiltonDIY
Free Automotive User Manuals ManualsOnline com
https://haynes.com/en-us/search?query=2000%20Ford%20Crown%20Victoria
Grady.. sounds like its either the window seals or the door seals.. check for damaged door seals, cracked window seals..
Jul 03, 2017 | 2000 Ford Crown Victoria
Water on drivers side floorboard . Why?
If you have a sunroof it could be the drain that follows the front pillar letting out under the front fender. These hoses are known to plug and crack open releasing water into the floorboards.
Driver side door check along top and front edge for tears or twisted looses sections. Internal to the door water can drain down along the window and is released outside the door seal. If the bottom of the door has the opening that releases the water plugged then water will drain over into the floorboard.
Jan 06, 2016 | Cars & Trucks
Water in passenger floorboard
If it smells sweet and is sticky it is your Heater Core leaking. IPD has all the parts and a Video on You Tube that makes it very easy.
Apr 07, 2014 | 2001 Volvo C70
2003 lincoln town car water on passenger floorboard from air conditioner
Raise the hood and look on the firewall around the passenger side and around the heater hose and there is normally a drain coming out of there. Are you sure it is the ac and not the heater core leaking because usually when you see water in the front passenger area it is from a leaking heater core.
Feb 19, 2014 | Air Conditioning Evaporator 2003 Lincoln...
2000 Buick Regal GS water leaking into passenger floorboard
Sounds like the A/C condensation drain is plugged. I hope this helps!
Jul 23, 2010 | 2000 Buick Regal
The passenger side floorboard gets wet =
is it only when the ac is on? there is a pan under the ac unit that has a hole in it to allow the condensation to empty. if that hole gets plugged it could cause the condensation to build up and back into the inside of that car. i unplugged mine and floor stayed dry
Jun 03, 2010 | 2005 Chrysler Town & Country
My car is trying to heat up and leak some water is it comeing from the water pump or heater co..how can i find the problem
If it is the water pump the water will be coming from the front of the engine. If it is the heater core it will be coming from the firewall area and you may even have water (coolant) leaking into the passenger compartment on the passenger side floorboard.
Apr 28, 2010 | 1999 Chrysler Cirrus
Grand prix front passenger floorboard gets wet
You could have a leaking windshield seal, and its running down the inside of the dash and onto the mat. Has the windshield been replaced?
Aug 13, 2009 | 2004 Pontiac Grand Prix
Leak onto floorboard
Here is what all dealers do to find water leaks, we spray a fine mist of water on the car near where the water might be comming in with a spray nozzle, someone gets inside the car and look for the leak, there is no other way, and I have been doing this 30 years.
Dec 03, 2008 | 2005 Dodge Neon
Water leak on the passenger side
were at on the passenger side? If its in the front floorboard,passengers side.the heater core may be leaking antifreeze.Also the a/c drain it also located in the same area.check your antifreeze,if not low,drive for a few miles with a/c on,stop on dry level place.there should be water dripping under passengers front.that is were the a/c drain is supposed to be.
Aug 12, 2008 | 1999 Plymouth Voyager
Heating & Cooling Logo
333 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
