Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice forming bottom of freezer leaking out the door
Water seems to be coming from a stainless steel lined vent that is on the bottom of the back wall of the freezer compartment. Drips down under the freezer door, episodically, every 48 hours or so, a cup or two of water.
  • wfmknight Oct 18, 2008
    Yes. Turns out I could have fixed it without taking the cover off just by aiming hot water from a squeeze bottle through the grill to where the drain lies beyond. Thanks.
  • Anonymous Mar 23, 2014
    Frozen defrost line. Drips on bottom of freezer then leaks on floor after four weeks
    U
    Scholar:
  • 112 Answers
It is acutually a collector pan for the drain hose. When the refrigerator runs a defrost cycle (about every couple days), that pan collects the water from the ice that is melted and drains it through a hose inside the unit, to a pan under the unit. You will have to pull the back panel off the back of the freezer and melt it with either hot water or a hot blowdryer. Do it until you see the water draining freely into the bottom pan.
Posted on Oct 18, 2008
How to fix kitchenaid kbfc42fts bottom freezer builds up ice and leaks on floor
The drain line is clogged go around the back of machine take off back cover and you will see a drain line coming through the floor and at the end of it is a rubber grommet.The rubber grommet is clogged up just take it off and throw it out and then turn off machine for 24 hrs with doors open to melt out all the ice
Aug 08, 2014 | KitchenAid KBFC42FTS 42" Bottom Mount...
My frigde is leaking water and it creates a block of ice under the freezer drawers. Can this be fix and How??
have you installed a new water filter lately? If so, check that it is securely installed, as water could be leaking by it and forming in the bottom.
Nov 04, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Water is leaking down the side and back of the freezer from the ice maker. I have the GE CAN9 ice maker. Were is the ice maker water valve located ?
Bottom right in back of ref.<br /> Its what the water line from the wall attaches to.<br /> <br /> <br /> If this was helpful please rate me.<br />IMUFO2<br />Leo Ponder Appliance-Tyler,Texas<br /><a href="mailto:imufo2@sbcglobal.net">imufo2@sbcglobal.net</a> <br />
Aug 30, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
Sep 30, 2009 | Maytag Sovereign 60 Side by Side...
Ice forming in the bottom of the freezer
Unclogh the drain hole inside the freezer in the bottom of the bakc wall pouring hot water until the ice melted and keep pouring until goes through.Repet this every 3 or 4 months to keep it clear.
Jul 22, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Leaking water
In back of the refrigerator behind a removable panel you will find a hose going into the drain pan under the refrigerator. Check and make sure there is no obstruction in the hose which would back up water into the freezer. After the drain hose is cleared the freezer should be defrosted and ice cleared from the drain area in the back. You can direct some hot water with some bleach in it through the drain to insure it flows into the pan.
Jun 15, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice forming on bottom of freezer
Switch off the power
First keep all the items out
Open the door and remove all the fixers
let the whole body will be get dry
check the freezer is there any gap between the door
Let me know if your problem is solved and rate me as FIXYA!
Mar 07, 2008 | Kenmore 73503 Stainless Steel Bottom...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
420 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
