Question about HP Compaq Evo Notebook N410c
Evo n410C will not power up
Hello, were you able to solve your problem that you posted with your laptop not powering up (see below)? I am having what sounds to be the exact same problem with mine, an evo n410c. It was working fine until one day turned it off and it would not turn back on. Just the green LED's
Evo suddenly ceased to start. When connecting the power (with batts or w/o), after a few second the start up lights come on, but nothing else happens. When you pressthe power button, there will be a minute click (almost pop), the lights go out, and after a few seconds, it will do the same. The HD is fine. Tried it in another machine and it checks out. Put a HD in the Evo... same symptoms. Have tried three power supplies, so not there. Ideas? All seem intact on the inside as far as connections. No known drops or bumps. This happened before, and after checking the HD and connections, it started up fine, but suddenly, the failure came back.
I am using compaq evo n410c laptop recently i installed windows 7 but now wifi,sound lan are not working, how can solve this problem
there is no driver support for windows 7 for that model. none of those components will work with it.
Mar 16, 2011 | Compaq Evo N410C Notebook
Replacing bios battery in evo n410c laptop
Dissemble the laptop and find bios battery. It is smaller than desktop bios battery. Usually covered by plastic wrap. Remove it and replace with new one. Observe the polarity of battery carefully.
Regards
Jan 25, 2011 | Compaq Evo N410C Notebook
What is my power on password for a compaq evo N410c labtop?
If you forgot Windows password, you can create a Windows password reset bootable CD/DVD or USB flash drive to reset your lost or forgotten Windows password, i have created a bootable CD with the tool Windows Password Breaker and reset my administrator password successfully.
Dec 23, 2010 | Compaq Evo N410C Notebook
CAN NOT POWER ON WITH THIS LAPTOP
try this out,
remove the battery from the back of the laptop, and power it on without the battery inside first, then if it comes up, change your battery. if it doesnt, kindly let me know so that I can tell you what next to do.
Oct 05, 2009 | Compaq Evo N410C Notebook
I found my compaq evo n410c notebook after ages but now when i swtich it on it asks for a power-on password but i have no clue what it is
this varies from laptop to laptop, on some laptops you can remove the bios password by removing the 3 volt memory battery inside, some laptops may have a switch inside to remove the password.
In most cases you will have to take the laptop apart to get rid of the password.
if you enter the password wrong 3 times you may get a system disabled xxxxx number message, a hp service center will be able to unlock the laptop for you.
Sep 10, 2009 | HP Compaq Evo n410c (470042993) PC...
How do you repair the error message IRQL_NOT_LESS_OR_EQUAL for an Evo n410c?
Hi there
This message usually pops up in the "blue screen" This Stop message indicates that a kernel-mode process or driver attempted to access a memory address to which it did not have permission to access.
This error usually occurs after the installation of a buggy device driver, system service, or BIOS. To resolve it quickly, restart your computer, and press F8 and select "Last Known Good Configuration"
this should repair the machine, although in some case the system has to be recovered
Keep us posted and Merry Christmas
Dec 24, 2008 | Compaq Evo N410C Notebook
Evo N410 usb boot
yes u can
its a long procedure so i would suggest u to go through the following pages
http://articles.techrepublic.com.com/5100-22_11-5928902.html
www.bootdisk.com/pendrive.htm
Apr 26, 2008 | Compaq Evo N410C Notebook
Compaq evo N410c sound and video play too fast
I bought a used Compaq evo N410c and had the same problem.  I went to HP's website and downloaded the ADI Soundmax Audio Drivers and both video/sound are working fine.  The drivers installed without any problems, I was not prompted to insert any disks.  nicole79, sounds like you may have downloaded the wrong drivers.
Mar 28, 2008 | Compaq Evo N410C Notebook
EVO N410c won't boot past windows page
You need to get ya XP setup disk and use that... to repair OR reinstall.
Do you not have a recovery disk?
the link below should be of some help good luck
http://www.michaelstevenstech.com/XPrepairinstall.htm
Feb 07, 2008 | Compaq Evo N410C Notebook
Compaq N410c laptop power-on problem
POST troubleshooting steps. then this issue is not a NO POST but is an power related issue see document ...
Good Luck, Please dont for get to Vote/Thank You.
Dec 20, 2007 | HP Compaq Evo Notebook N410c
HP Compaq Evo Notebook N410c Logo
166 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
