Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
TV picture and audio disappears for minutes at a time
My TV picture and audio disappears for minutes at a time.
My power light does not go out. The lamp light does not
turn red or blink. What could be the problem?
I'm having the same problem and believe it has to do with the lamp, from my online research. Sony has listed that they had problems with the access door to the lamp and through March 31, 2009 will repair the lamp access door and any other components damaged as a result at no charge for any of the covered televisions (KF50WE610 included), To schedule a repair call 888-649-7669.
Here's the super long link or search sony for warping. http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=http--esupportsonycom-perl-news-itemplnewsid261templateid1regionid1KSMFlag7370&sliceId=&docTypeID=DT_NEWS_ALERTS_1_1&dialogID=15656064&stateId=1%200%2015658185
My tv is doing the same thing: picture and audio disappearing for minutes at a time with the power light staying lit. My online research leads me to think the lamp is the problem. Indeed, I found Sony's instructions to replace the lamp, and found my access door to be warped and melted in places. I can also see that there's some warping surrounding the lamp as well. So my point is if this problem is being caused by the lamp needing replacement, and if the lamp is damaged and falls under their extended warranty above that replaces components damages as a result warping, this might all get fixed for free. My appointment is scheduled and I believe I have a good chance of them replacing not only the access door, but the interior including the lamp at no charge and that my tv will again work.
Since I've seen our problems listed on this site with other sony models---and that replacing the lamp seems to have helped almost everyone--the fact that Sony will come out for free is great. The instructions from sony at http://www.docs.sony.com/release/XL2100U.pdf and if your access door is warped, then you get a free fix, and hopefully they will fix any inside damage as well, including the lamp. It's a free call, so worth a try.
Posted on Oct 25, 2008
  • 320 Answers
If you're hooked up to a cable box by the HDMI cable, try connecting up by component cables. Cable boxes have notoriously bad HDMI outputs, causing no or intermittent sound and picture problems
Posted on Oct 18, 2008
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
CRT Board
A crt board can cost from $25 to $40, the problem is that crt board should be tested before replacement, even if it is the most likely cause, there is always possibility that there is also something else (tube, main pcb etc.)
Jul 08, 2008 | Televison & Video
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Flashing red light
I think this sounds like my problem (need to replace the projector lamp). However, when I hit the "on" button, my SXRD 50" blinks green for about a minute then starts blinking red. Can you confirm the bulb solution? I was very pleased with this sight when my fan malfunctioned. I got the fan in a matter of day's from Sony and it fixed that problem.
Oct 29, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Won't piwer on
Tried to turn it on? Sounds like you need to replace the lamp. However, I got an additional week out of my unit. Although poorly dimmed and the red Lamp light blinked constantly for that one week, at least it gave me enough warning to seek out a replacement. But so long as you're not mistaking the Power/Standby or Timer light for the Lamp light then I would have to agree with you. http://store.l-f-l.com/prod/A-1606-034-B Includes shipping to the United States and no sales tax outside of California.
Aug 16, 2007 | Sony XL-2100U Projector Lamp for...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
95 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
