Question about RCA 14F512T 14" TV
Pink/Orange Screen Screen is not working. I currently have a DVD player hooked up and can hear it playing, but the screen is pink/orange! Any suggestions?
  • RCA Master
  • 1,587 Answers
The blue video drive is out. You would have to trace the circuit back from "KB" on the CRT board to the video processor chip and see where it differs from "KG" and "KR". Check for bad solder connections, especially at KB and Q509 (about 0.5 inch away from KB). If you don't find any, then you'll need to do electrical testing. I assume you know how to use an oscilloscope and avoid getting zapped while working inside the TV...
Posted on Dec 08, 2009
Necesito el diagrama de la fuente del rca
Posted on Oct 18, 2008
I bought a Ouku 7" screen DVD Navi unit for my 2009 Honda Civic. There are 4 loose wires on the harness labeled as follows:
Orange goes to the switch on the emergency brake. This allows the DVD player to play movies with the brake on ( liability issue...people sued and bankrupted a manufacturer because they watched tv while driving and some people got killed) should be the light green wire at the switch on the ebrake handle.
Blue is used on a vehicle with factory analog steering wheel controls
pink is connected to the back up lights and activates the backup camera feature if you have a back up camera
blue w/white stripe...best guess has to do with infra red remote ...possible allows an ir eye to be installed.
I would suggest go ogling the model number for a wiring diagram or owners manual if you don't have one.
Nov 01, 2016 | Honda Cars & Trucks
Screen is orange and pink where it should be white
Try updating graphic drivers from the HP website.
HP has a lotta tools inside, maybe one lets you run an updater HP Pavilion dv6405us Notebook PC Drivers Download
Feb 28, 2014 | HP Pavilion DV6405US Laptop
What color wire do i hook the pink wire to
Pink wire is generally the parking brake safety. If you dont want the dvd player to play video while in drive wire it to the ground on your parking brake sensor wire. If you do want it to play video while your driving, wire it directly back to the ground wire on your stereo.
May 15, 2010 | Alpine IVA-D300 Car DVD Player
Can't find Jensen UV10 e-brake bypass code.
Ok what you gotta do is connect the pink e-brake wire with the black wire that is already connected to the radio as the grounding.
UV10 Works 100%!!!!
Greetings from Montenegro
Jan 28, 2010 | Jensen Car Audio & Video
The colors are wrong on the screen. everything is orange and green and pink. just started after 6 months of perfect play. changed hdmi cord and port and that didn't help. it may be from overheating, but is...
Not a solution, but this will still allow you to watch DVDs until you carefully research customer feedback on DVD players. (Which I didn't do when I bought my DVP3962!)
That happened to me after 6 months. I used the A/V cables, then after a week or so I tried HDMI again. It worked for another 5 months, and is now crazy colors again.
Nov 15, 2009 | Philips DVP3962 DVD Player
The wiring on the 8 pin harness has come apart
Red,black,orange,pink. bottom is yellow,hole,green,light blue/yellow
Apr 10, 2009 | Kenwood KVT-617DVD Car DVD Player
Vm9312 in dash will not play video
Go to your radio tuner screen and go to your set up page then use your remote and press 5,4,3,2,1,0 and hidden menu will pop up then you will have to press the tool looking button on the left side of the screen and it will give you an option to it off so you dont have to hook up the pink wire.
Nov 17, 2008 | Jensen's VM9312 Car DVD Player
Wire identification
I dont have schematic but I know that the lt. green goes to emergency brake switch, I have the blu wire hooked up to my amp remote, orange may be for dimmer when headlights are turned on, blu w/wht. stripe I'm not possitive but I think its for an electric antenna, my cq-vd6503u does not have a pink wire.
Oct 20, 2008 | Panasonic CQ-VD6503U Car DVD Player
Wiring
yes orange is illumination cap off both they can cause some problems on some cars red is your acc. or switch to ign. brown is mute cap it off pink is your reverse cam hook up if your not running one cap it off you radio is probably not working because your red wire needs power when the car is on
May 12, 2008 | Kenwood Excelon KVT815DVD Car DVD Player
Phase Linear UV8
go to setup hit 543210 but hold 0 then turn the bake override on and then hit the X
Dec 11, 2007 | Jensen VM9510 Car DVD Player
RCA 14F512T 14" TV Logo
180 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
