Question about Lexmark Color JetPrinter Z65 Pro InkJet
Sudden problem onset
Had printer 18 months. Has been working well. Running with XP home. Suddenly getting horizontal lines through print lines and print page appears elongated ie: one page now 1.5 pages. Paper feed seems erratic. Test page seems ok slight change in last line. Have changed cartridges, paper, reloaded software. Have cleaned cartridge contacts and contacts on printer. Checked USB connections. Any suggestions besides the obvious.
SOURCE: Lexmark X3350 printing
i just fixed this problem.  first i bought a new (remanufactured 3rd party) cartridge off ebay and found it wasn't working either.
there are cartridge cleaning instructions in the troubleshooting help section that show you how to carefully wipe clean your cartridges.  follow that, it solved my problem.
Posted on Feb 11, 2008
SOURCE: Lexmark Z45 printer won't print
I am the same user as the guest above, I just found a solution. I took mine apart. I found that (when looking at the unit from the front with the cover off with the gears on the left) the 3rd gear from the bottom left had a crack in it. It was the gear that turns the 4 large round rubber cylinders from underneath the paper. Anyway, I kept turning on/off until the crack was on top and then I dropped a drop of Super Glue (red cap version for use on Rubber/Plastic/etc.). I put a little pressure on it using 2 thin screwdrivers in the gear teath to compress it but in looking back I don't think that was necessary. I think the crack in the gear was causing mine to slip so just making it solid again helped enough to make one work like normal again. I'll see how long this holds up. Good Luck. Scott.
Posted on May 26, 2008
SOURCE: Lexmark Z600 ONLY print test pages
Seemes very daft, and sounds like a twit, but not really.
When I recieved the new cartridge I placed it in the correct cartridge retainer in the printer matching up the dark green colour of the cartridge and the top clip, and it printed nothing even after a tryed re-seating it.
So I placed it in the other thinking maybe I somehow might have placed it in the wrong slot, so I placed it in the other (Colour), and set that up as I did the other, and it printed a blurred page but then stopped printing.
After that I then placed it back in the other cartridge retainer, set it up as the previous times when it did not work, and then it worked.
Seems strange and simple, but it did not work the first time at all, and after faffing with it finally did.
This might help someone, and then again might not.
Posted on Oct 09, 2008
SOURCE: C912 horizontal lines in print
change your magenta led it sounds like that may be faulty big job if not theat then its a new rip baord which is under the cover
Posted on Nov 03, 2008
  • 258 Answers
SOURCE: Paper does not feed from Tray 1.
Check your printer settings.
Sometimes if your printer or the program you are printing from has the paper source set to "Letter" it waits for you to press the continue key on the printer which allows you to insert headed note paper before printing.
If it is set to letter, change it to A4 and this should solve your problem
You may need to change this in both the printer settings and/or each program from which you are printing
Posted on Jan 12, 2009
1998 PU B series 170,000 mi Problem - starts but then cuts out after a second or two. Sudden onset of the problem
fuel pump not working check power and relay ....turn key and listen for hissing sound from pump
Aug 19, 2012 | 1998 Mazda B-Series
Printing mirror image
your printer OS must be compatible with your computer's OS
Feb 25, 2010 | HP Officejet Pro L7680 All-In-One Printer
Horizontal lines running through my prints.
Try printing at the slowest or best setting for a while. You would be wasting a lot of ink if you do head cleaning several times.
Feb 12, 2010 | Epson Stylus Pro 9600 InkJet Printer
Horizontal lines (red) on first 1 - 2 pages of initial print-out
Do you refill ink tank? Print blank pages. Is there horizontal lines appear? It might be caused bay ink leakage. Check respiratory hole at ink tank and rubber seal at bottom of ink tank. Print blank pages until no horizontal lines and try to use new ink tank.
Aug 17, 2009 | Epson Stylus Photo 1270 InkJet Printer
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Xerox c2424 prints horizontal lines in all prints
Scroll the menu for troubleshooting, then run the Eliminate Light Stripes mode a couple of times
Apr 12, 2009 | Xerox C2424 Copier
Black horizontal lines printing on all printing.
Push menu on your printer, then fin maintainance. Then go to clean printer and push the green button. It will clean the cartridges for you and that should help.
Apr 10, 2009 | Dell 924 All-in-One InkJet Printer
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
White lines throught the print
Try cleaning printheads through printer driver.
Nov 25, 2007 | Epson Stylus C88 InkJet Photo Printer
Lexmark Color JetPrinter Z65 Pro InkJet Logo
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
