Question about Sansui DTV2760 27" TV
Sansui without remote
We are trying to get a VCR to work on our Sansui TV. We do not have the remote. Is there a TV/Video switch somewhere on the TV? We haven't found it.
  • Sansui Master
  • 520 Answers
No. You will need the remote. Call the number on the set for an original. You could try your luck with a universal remote. Try a RCA brand. Good Luck!
Posted on Oct 22, 2008
Code for universal sony remote sony-v201
Hello
Sorry to say that Sansui is not listed to Sony V201 remote control. Anyway I'll give you some three digit and four diit conds for Sansui. I'm not sure will it work, but try these, sometimes you may get.
Three digit universal remote codes for Sansui are:
135/ 136
Four digit universal remote code for Sansui TV/VCR combo is
0310
Four digit universal remote code for Sansui TV are:
0135 0310
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
NOTE: Switch OFF and switch ON your combo with its FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
Hopes you will be helped.
OK.
Jan 27, 2011 | Sansui COM312AD 13" TV/VCR Combo
Need a remote control for Sunsui RV TDC2075 A
Try to get a UNIVERSAL multi remote if you are not able to get the original from the sansui dealer. The remote can be tuned accordingly to the set as instructed. You will be able to lock each of the function of the TV/DVD/VCR as you change the mode switch. Hoope you can look around for the best type/model in your city , try the spareparts accessories shop near to your place where all the electronic spares are available. hope this works. Good day
Aug 14, 2010 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
I have a tv/vcr combo sansui tv with no remote and i have universal remotes which none of the sansui codes work. Any suggestions? What company makes Sansui?
Hi! actually most sansui are manufactured from china, so you should try the codes designated on china brand of tv"s.
Oct 16, 2009 | Televison & Video
I am trying to sync my sansui tv with my magnavox dvd/vcr combo. I can't figure out what channel the sansui needs to be on to play a dvd. The input button on remote is not working.
Tries buy a new remote this website have a exact or very close to the Original remotes.1-800-Remotes Factory Original.Tries channnel 3 only or 4 only functional for video equipments.
Sep 29, 2009 | Sansui DTV2760 27" TV
Sansui VCR/DVD
Cant' get remote buttons to work. No buttons work so can not watch DVD or Tape but can hear sound. Without the TV/VCR button not respondingnit won't switch over.
Jul 06, 2009 | Sansui VRDVD4005 DVD Player/VCR
Sansui COM3101A 13" Tv/VCR Combo Problem
You can try the codes for Orion, Emerson, and RCA. Call the number on the back of the set to see if the original remote is available.
Sep 28, 2008 | Sansui COM3101 13" TV/VCR
Need to find a code to work the tv/vcr combo from a comcast digital remote
Try the codes for Orion, Emerson and RCA as well as Sansui. Good Luck!
Jul 22, 2008 | Sansui COM3101 13" TV/VCR
I need the code to set for sansui tv using ge universal remote control. pls help me! thanks
I own a One-for-All universal remote, and my booklet says the setup code for a Sansui TV ( without a built-in DVD or VCR) is 0463. I can not guarantee that this number will work with your remote, but it is worth a try.
Jul 05, 2008 | Televison & Video
Programming Device Control code for Memorex MVT2135B
21479 is the Sansui code that worked for me with the Memorex TV/VCR combo MTVT2135 and the Comcast Custom DVR 3 Device remote.
Jan 20, 2008 | Memorex MVT2135 13 in. TV/VCR Combo
Sansui DTV2760 27" TV Logo
166 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
