FixYa.com
Tags:
Mag Innovision LT776s 17 in. Flat Panel LCD Monitor
Monitor went blank
posted by Maryfran on Jun 06, 2006
My monitor started going blank,but if I powered off then booted on,it would stay on for awile it kept doing this then one day the color got distorted and went blank again and now it won't come on at all....my hubby unplugged the monitor power cord and it came on again,but then the color faded an got distorted and then goes blank again...What can I do to fix this?....Thanks in advance,Maryfran
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 27, 2008
Not Rated (0)
Mergatroid
Rank:Wiz Wiz
Rating: 85%, 94 votes
This is a generic symptom that could happen to any LCD monitor.
The following is a generic answer applicable to most.
Two possible causes are bad capacitors or a bad light inside the LCD panel.
Open the unit and check to see if any of the capacitors in the power supply or other boards look domed or vented on the top.
Replace any capacitors accordingly. Use the same value capacitors. Most often, 1000uF 16V or 25V, 470uF at 16 or 25V, 220uF at 16V or 25V.
If this doesn’t solve the problem, try checking the surface-mount transistors on the inverter board that run the lights. Some times these transistors go bad. Check the area for any cracked or overheated ceramic or mylar capacitors.
Also, you may have a bad light inside the panel. This is tough to test without a spare light to use for troubleshooting.
You can take the panel apart and inspect the lamps but it is very tedious. It's tough enough to get them apart and back together again never mind keeping the layers clean. You have to try not to get any dust between the layers or you will see it in the picture.
There are usually two light fixtures each of which holds two lamps. One fixture is at the top and one at the bottom. Remove them one at a time and inspect the lamps to see if any are broken or very dark on the ends. If one looks out of place, it could be bad.
You'll have to find replacement lights on the net. It's not easy to replace them, but if you've gone this far, good luck. You should be able to get generic instructions off of the site that sells the lamps.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Monitors problems?
Mag Innovision LT776s 17 in. Flat Panel LCD...
Screen movement to left.
My screen has developed a black... Answer This...
Mag Innovision 17" flat...
I am also experiencing the same... Answer This...
LCD screen blue
LCD Screen is blue and stays... Answer This...
computer screen
just played a game and now my... Answer This...
lt765s
monitor is not clear, lines and... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
