I own a 2000 and have had problems getting any airflow from the heater or A/C. Both work as the cab will cool or warm from the air radiating from the vents. All settings on thermostat work and I can hear the motor working in each speed. I was told this could be the blower door actuator.? Any insight?
The blower will supply air no matter where the blend door is positioned, it will be hot cold or somewhere in between but you will have full airflow, so the blend door or the actuator is not the problem. Find the air intake for the blower (at base of windshield) and make sure it is not full of leaves or if you have a passenger cabin air filter (commonly called a pollen filter) it is not plugged up.
SOURCE: A/C works fine, the blower's fine, replaced thermostat, no heat.
If you don't hear a thud or noise of a flap opening or closing when switching between hot and cold then a lever is probably broken.
SOURCE: how to reset the HVAC
You have a problem with mode mode control switch, it is either leaking vacuum or has no vacuum to it, all of the different modes are switched using vacuum operated air door motors to send air to the selected outlet, i.e. floor, dash. defrost or a mix.
SOURCE: airflow problem through ac vents
Your selector panel is bad, ( temp, blower, ect.) all one unit, my 95 did same thing chg. that unit and it fix it.
SOURCE: Is the thermostat easily accessable inside the
its not easy. so make sure its bad. Have a shop scan the engine computer while you think the engine is at normal engine temp. it should be 190-195f if its lower than that, yes the thermostat may be bad. but its a job to replace.
yes it could be the blend door, could be broken, or the actuator, or could be the climate control too, if you know where the heater core is then you just found the blend door, goodluck. Thanks
In all modern cars there is a tiny DC electric motor driven gear drive that moves a plastic door that blends heated and cooled air from the AC and the heater core, this is called (interestedly enough) the air temperature control blend door actuator. The motor that moves this door fails because the door starts sticking from warping, most common complaint is no heat but it can be no AC as well. To replace these parts (blend door and blend door actuator) you must remove the entire dash from the car. Always have this problem confirmed by a dealer or qualified repair shop as it is a very expensive repair.
