Question about Harman Kardon HK595 Computer Speakers
Have sound, but humming noise is in background
I have sound, but why is there a humming noise in the background?
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 64 Answers
A typical reason for periodic humming noise in all channels are some capasitors that dries out. C922, C924 and C962 are all mounted on the main pcb. They are mounted close to the cooling rib of IC91, IC92 and IC93 and this is the reason why they dry out.
Posted on Sep 30, 2014
  • 238 Answers
Your audio codec might not be updated. Try installing audio codecs for that matter. Go to this link:
http://www.free-codecs.com/XP_Codec_Pack_download.htm
Download it. When a box appears, Click Run button.
*Drop me a comment and i will assist you.
Best regards
Posted on Jan 04, 2009
I'm getting a low background noise coming from the tv. Any suggestions on how to stop this annoying problem?
is it a humming sound or a shhhrhhhr sound. humming is interference from the tv, lead may have fell down on to the board near to the transformer... shhhrhhr sound is weak capacitor and/ or maybe a damaged speaker.
Sep 22, 2013 | Samsung UN65F6300AFXZA - UN65F6300AF 65...
Background noise coming through my wifi
If you notice a low frequency hum noise (Buzz) coming through your speakers ..... Q: When the X11 headset is idle I notice a constant background hiss ..... Q: I run myXbox live off of a wifi adaptor and now that i have the Ear ...
Aug 13, 2013 | George A. Gathecha Google Search
Background noise
no problem with..record some part of the start with no voice just a 5-10 seconds remain quite...just kept running the recording...then start and record your voice after which install AudaCITY Software and drag your audio file in it and then select the first 5-19 seconds recording which was just the background kept recording selecting the part go to Effects -> Noise Removal then press Get Profile,
after which again select all the track by: Control + A key on PC and then go to Effects Noise Removal move the bar to the left side...and press ok/continue key....now your track is very much clean by the noise...and
for sound loudness select all the track and go to Effects -> Normalize then again Effects -> Amplify put the slider value to -0.1 of what the value is shown.
Jan 19, 2012 | Vizio VSB210WS Soundbar
Humming noise from NCR RealPOS 70
In a word...yes. Except that you said it is coming from the "screen"? Did you mean the screen on the power supply? If so then yes...probably the fan.
Mar 17, 2009 | Computers & Internet
My fender twin has alot of buzzing and hum noise
It is usually caused by interference somewhere in the room. A major source is art CRT such as a TV ot computer monitor. First try turning off any other electic devices in the room. Your could also see if there is a ground lift switch on the amp. If that dosen't do it, you can try lining the cavity of your guitar with tin foil. I t sounds weird but it does cut back on some interference. If none of those work, bring your amp to your local tech and have the preamp tubes tested. It may be that one of them is going bad.
Dec 14, 2008 | Audio Players & Recorders
Hi I bought a Panasonic 42 Inch class 720P Plasma HDTV TH-42PX80U, the picture is fine, but there is a humming sound in the background of the audio. The louder I turn the tv the louder the hum. I tried...
If turning up the audio amplifies the problem, it is in the initial stages of audio. It could very likely be outside the TV, try difference sources to troubleshoot your setup. If it hums on all inputs, the problem is before your audio switch and could be on the board with the AV jacks. Note all plasma tvs hum out of the back of the tv (ie power board, y-sus, z-sus board and panel all make a little hum noise)
Dec 06, 2008 | Televison & Video
Background "hum" in R speaker
Yea try plugging it into another wall socket, if it's still humming could be a damaged transformer. or bad capacitor.
Jun 05, 2008 | RCA RS2531 CD Shelf System
Background noise
Check the cables in the back If i remember the Component Red jack is right next to the audio out jacks (also a red jack) if the audio cable is hooked up to the component jacks this will cause a humming static noise
Apr 12, 2008 | Samsung DVDR120 DVD Recorder
Harman Kardon HK595 Computer Speakers Logo
384 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
