Question about Cameras
I turned my digital camera on and the LCD screen is showing the image upside down and backwards.
  • Cameras Master
  • 4,738 Answers
The auto rotate sensor is going bad. Look in your camera's menus for a selection to turn autorotate off. Actually going inside the camera and fixing the sensor is possible for those with some electronics background, but really not worth the risk of further damaging your camera. This feature is not necessary as most image processing software has this same feature if needed.
Posted on Oct 18, 2008
My cool pix S220 is showing backwards and upside down images when I turn on the camera. Is it toast?
Hi... try to reset the camera using Factory reset and see if that helps. If not
then let me know
Jan 23, 2011 | Nikon Cameras
Replacing LDC screen on Fuji Z10FD camera
Probably, yes.
Remove the 2 screws on the side,
Remove the 3 screws in the buttom. (2 of which are tri-wing)
Remove the 2 screws in the battery compartment.
Flip out the chrome side (from the front backwards)
Remove the 2 screws underneath the chrome side.
Turn the camera upside down. You can now flip the backcover down (gently lift the cover, both on the mid by the tripd hole and on the side, where the crome plate was) Watch out for the USB connector.
Gently lift the broken LCD out. You need to release (flip up) the tiny white lock on the connector to release the ribbon.
Assembly same procedure, but backwards.
Beware of the flash components. The can give a nasty electrical chock.
May 21, 2010 | Fuji FinePix Z10fd Digital Camera
Inverted image
no solution I know and I have the same problem!!! Did you find a solution yet???
Mar 04, 2009 | Konica Minolta DiMAGE E50 Digital Camera
Nikon D50 LCD
It sounds to me that there is moisture in the camera. Send it to a repair centre.
Nov 16, 2008 | Nikon D50 Digital Camera
Image is upside down and words backwards
malfunction in the camera and will need repair
olympusamerica.com/repair
Oct 17, 2008 | Olympus FE-210 Digital Camera
Monitor 2 - Image is upside down and backwards
Check your graphic card settings. I have a 6600gt, and can invert my screen. Try going: right click your desktop, select properties. Go the settings tab. Clieck advanced. There do you have a tab for your graphics card? Mine shows I have a 6600Gt. After selecting the tab it displays options. I have NVrotate. That rotates my screen.
Jul 16, 2008 | Computers & Internet
Picture is upside down and backwards
I have the same problem. How and where does this come from? My camera was sitting in the dock when I noticed the problem!!
Nov 26, 2007 | Kodak EasyShare C315 Digital Camera
Mirror image
I would be interesting to discover a solution An E-500 has reported this too Suggest only Olympus will have the answers.
Aug 16, 2007 | Olympus FE-115 Digital Camera
LCD upside down and backwards
look for a small pinhole somewhere on the camera body. then insert a pin to reset the camera. if no pinhole, remove batteries for a long time (about 24 hours) then try again.
May 31, 2007 | Olympus Camedia C-725 Digital Camera
My Screen is upside down and the words are backwards
The first thing I would do is a reset. Read your manual about this process, which often requires pressing two buttons at the same time or take your batteries out, wait a minute and put them back. See if resetting helps. Not being familiar with your camera, speciffically, Ithis sounds like the firmware in the camera is reading the info back to you backwards when it processes the image (from memory) for you to view. That means it is the firmware in the camera that is defective and sometimes you can update or reinstall that. I would check the manufacturer's site for updates or recalls and if it is under warranty, send it back to be fixed.
Jan 28, 2007 | Fuji FinePix A120 Digital Camera
Cameras Logo
132 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
