Question about Compaq Presario 700 470024-192 Notebook
Power on but the monitor or the dvd rom has no power
I bought a new battery pack could this mean the hard drive is bad
    Genius:
  • Compaq Master
  • 1,252 Answers
If your hard disk, rom is detecting on bios then they are not dead
Posted on Oct 31, 2008
Pc starts but black screen
Bad video card, bad hard drive, bios battery. If you have a screen but only a blinking cursor on it, likely a bad hard disk drive, meaning all your data and files are now gone, also your os is likely inaccessible. If you can heart it boot up like normal through speakers then video card or monitor, more likely the monitor's power supply is bad, find another monitor (size not important, just the display connector) and connect it to your PC with the power off. If it works then it's the monitor that is bad, purchase a new monitor, if another known working monitor doesn't solve the screen issue, it's probably your video card. A new card is cheap and you should be able to install a new one and have basic display until you install the drivers.
Sep 02, 2013 | Dell Inspiron 2600 1.2GHZ Celeron...
Tip
Instructions to keep your Laptop Battery last longer
There are certain elementary rules for getting more from your laptop battery. Make it a point to turn off Wi-Fi and BlueTooth. You are aware that most laptops have shortcut keys to instantly disable wireless networking. Completely avoid playing computer games, music or DVD movies as multimedia activities tend to drain laptop batteries. Disconnect all external devices like PC Card modems, firewire, USB devices and optical drives. It is advisable to use the notebook touchpad instead of an external mouse. It will also help to adjust your screen brightness as dimming your display saves battery power. You'll certainly need to see your screen, but just how bright do you need it to be? Screens lighted at full strength eat up 15 percent more battery life than if your battery was at 50 percent brightness. So, be sure to squeeze more life out of your laptop by reducing the brightness of your monitor a great deal.
3711.jpg Select a laptop power scheme that turns off the notebook monitor and hard disk after 10 minutes of inactivity. Remember to decrease or mute the laptop speaker volume. Lastly, programs that are run from a CD or DVD can be copied and run from the hard drive, which typically consumes less power than an optical drive. Some games offer you the choice to install to the hard drive, so choose this option, as you will get more life out of your laptop than using the CD-ROM or DVD player, which are massive battery consumers. There are also some more tips to improve your laptop battery life. If you do not use your laptop for extended periods of time like a few days or a week, then remove the battery pack from the laptop. Never expose the battery to high heat or extreme cold conditions. For instance, do not leave your battery in your car during the summer months. Hot batteries discharge very quickly, and cold ones can't create as much power. Make it a point to plug your laptop charger adapter into a UPS and not directly into a power outlet or surge protector. Fully charge new battery packs before use. New pack needs to be fully charged and discharged (cycled) a few times before it can qualify to full capacity. Leaving a battery in a laptop while using an electrical outlet for long periods of time will keep the battery in a constant state of charging up and that will reduce the life cycle of the battery.
Energy management has been a problem since the earliest days of mobile computing. Drains on a battery include virtually every component on your laptop, including the screen, the hard drive, the CD-ROM and DVD-ROM, and other peripherals. The biggest villain is DVD movie, which cause the screen to run at full power for the life of the movie. Make sure you have no devices plugged into the laptop that can drain its power, such as a webcam, USB thumb-stick, or wireless PC card. According to laptop manufacturers, connected peripherals can impact battery life by up to 12 percent (depending on the peripheral), so get used to the touchpad instead of using an external mouse when you're away from an electrical outlet. As a ‘Prevention is better than cure’ philosophy, it is worth mentioning that air travelers should make it a point to recharge the battery before a flight. Find an electrical outlet while you're waiting for your flight at the gate, a restaurant, or departure lounge.
on Jun 01, 2010 | Computers & Internet
I can't play a dvd on my computer?
if you burn this dvd by yourself then there must be problem with the X speed of your DVD ROM drive.Most of DVD rom drives does not play dvds scratched and old dvds.Lens of your dvd rom may be faulty.If DVD is new and its condition is better then there must be problem in your PC.Proper dvd player is not installed in your pc.I would recommend KM player or K-lite media codec pack.You can easily get them on google or at www.download.cnet.com/
Jun 04, 2012 | Computers & Internet
My HP Media Center PC M1170n with a asus ptgd1-la motherboard runs but will not boot. The fan runs, both CD and DVD drives attempt to read(lights flash for several seconds each) but even using the HP...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
if this fail to fix the problem
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
also
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
only do the registry check if you cant see the drive/s in windows explorer/my computer
or it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 17, 2011 | ASUS PTGD1-LA Motherboard
Computer will not start up on power up. Computer does a system check with all L.E.D. lights, cooling fan starts, empty cd drive bay does a system check. The computer hard drive will not start and the...
notebooks, battery out first, just take it out the leds mean zero.
there is no LED that can tell you a battery is ok,
did you?
if that fails.
next is what, BIOS
get the BIOS screens up. (my guess its DEAD) not even text or HP logo.
if not the pull hdd,dvd and all ram but 1 stick.
and all usb jacks empty , unload it.
fails now. then the Power pack is bad
you do know packs can be, good, bad or weak right
19vdc is good, 10 not.
see?
the GOAL on ALL PC's get BIOS UP.
take no hdd , no dvd to do that. ever
once it works we can move to booting any OS>
we can boot to 5 things on my laptop, even SD,mem.
try to think this way
if the Power pack is 65w+ and 19v
then remove all possible shorted devices from the PC.
strip it down. if it runs now, (means BIOS wakes up an screen)
test 2 on all LT
is the rear VGA jack will run a external screen if the internal is suspected.
black screens only can be CCFL dead.
if it has that.
i cant hear you hdd spin/
nor see the eject work work on the dvd
if the PC self shuts off, that means the power supply has issues
the Power pack bad , the MOBO regulators are in overload
and shut it down (called shorts on devices)
this is normal action on any regulator..... normal for shorts./
Jul 20, 2017 | HP Pavilion dv6000z Notebook
I just bought it off of craigslist hoping to fix
with nothing happening it is very possible the hard drive that needs replacing or is missing
Mar 24, 2017 | Gateway CX2610 Notebook
New computer tower motherboard(Intel D945GCPE), Processor(Intel Celeron 430 LGA775), memory, hard-drive(ATA), & dvd-rom(ATA). Got it all installed in new tower(ATX,I have green light on the motherboard...
First try to clear CMOS
Turn off the system and disconnect power cables
Locate the CMOS battery on the motherboard and take out the battery
Wait for about 15 minutes
Reconnect battery and try to turn it on.
If it remain same, disconnect power cables
Disconnect hard drive and CD/DVD drives
Try to turn on again.
Also check if the front panel connectors (Power SW, Reset, HDD connector) are properly connected.
Mar 09, 2010 | Intel Computers & Internet
I have a Gateway w340ua the other day i shut it down properly and todat it will not boot up at all nothing on screen but the dvd rom light comes on ?
Attach a external monitor and reboot -- if it comes up then the LCD on the laptop may be broken / damaged. This is where I would start.
let me know what happens after that.
if still no picture it could mean a bad video card and might need replaced.
Looks like a bad video card/chip or motherboard.
Experts only!!!
Try this:
  1. Power OFF the computer
  2. Remove the battery
  3. Unplug AC
  4. Remove the RAM
  5. Remove the CMOS battery
  6. Press and hold Power ON button for 30 secs. at least
  7. Put back the RAM and the CMOS battery
  8. Put back the battery
  9. Plug back AC
  10. Power ON as normal
If that does not help, remove the hard drive and just boot into BIOS setup.
Oct 09, 2009 | Computers & Internet
Cant get DVD's to play
Try cleaning off the laser of the dvd drive with a damp q-tip. This will make sure there is no specs of dust or dirt on the laser.
If it sill plays cd's but not dvd's then that means the laser is bad cause it takes more power from the laser to read dvds cause there is more information that needs to be verfied.
So if the laser is bad that means the drive you bought was defective. Try a bunch of different dvds to be sure you don't have any that are bad.
If your getting it with any dvd your putting in there then you know you need to get another drive.
May 31, 2009 | Dell Latitude C600 Notebook
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
Compaq Presario 700 470024-192 Notebook Logo
27 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
