Question about Garmin eTrex Legend GPS Receiver
Garmin Etrex Legend
I need to set my E Trex to read in degree decimal format rather than degree minute second. Can anyone help me with this problem. I am sending in the coordinates to my company and all of my work is being sent back, due to inaccurate readings. Also, if I can get my readings in degree format, am I also to set the North reference options, such as true, magnetic, grid, or user. Which field should I use, and does this have an affect on the readings for degrees.
Thanks for help
  • Anonymous Oct 25, 2008
    need degree decimal format for business use
  • Garmin Master
  • 638 Answers
Setup > Position Format > Page 44 of your manual.
Posted on Oct 29, 2008
I have a Garmin etrex legend, and when I enter the Lat and Long for geocaching on either the lat and long, I cannot enter the numbers 5 thru 9 into it. An example is, I can enter N 39-7.178. The blank...
Go to Main Menu > Setup > Units > Position Format > change to hddd.ddddd format. This is the decimal format which is widely used by geocaching forums.
Page 44 of your User Manual:
http://static.garmincdn.com/pumac/eTrexLegend_OwnersManual.pdf
If this solves your problem, please come back and rate our solution. Thank you.
Sep 19, 2010 | Garmin eTrex Legend GPS Receiver
The 5th digit the cordinates N & W WILL NOT LET ME PICK ANUMBER 6
You need to make sure your unit is set for decimal degrees. It's probably set for a different format.
Main menu> Setup >Units > hddd.ddddd
If this solves your problem, please come back and rate our answer. Thank you.
Jul 11, 2010 | Garmin eTrex Legend Cx GPS Receiver
When I enter the lat and lon corridinates from the Garmin ETrex legend into google earth they seem to be about 50 miles off.
Make sure you are using the exact same format for both. Degrees and minutes are not the same as decimal degrees.
May 30, 2010 | Garmin eTrex Legend GPS Receiver
Consistent error entering garmin etrex coordinate in google earth
Consistent errors are usually projection or datum related. If you are taking coordinates collected in one projection and displaying them in your GPS in another, you the points will offset. I'm not talking about the decimal degrees 00.000n 000.0000w vs 00 00 00N 00 00 00W. I'm talking about the geographic model to represent the surface of the earth. Google Earth generally uses a geographic projection with WGS 1984 or WGS84 Datum. Make sure you are using the same settings on your GPS.
Apr 09, 2010 | Garmin eTrex Legend GPS Receiver
My owner's manual and reference guide was "drowned" while fishing. I need another one for my Garmin eTrex Legend personal navigator.
hi,
This should be the manual your looking for:
Garmin eTrex Legend Manual
This is a pdf file so you will need adobe or foxit to read it, I;m sure that most pc's come with adobe on them though.
I hope that helps..
Mike
Sep 01, 2009 | Garmin eTrex Legend GPS Receiver
Display on my Garmin E-Trex Legend GPS
Sounds like the screen is shot and theres nothing really you can do to fix it, sorry :(
You can send it to Garmin for the flat rate repair fee of $79 dollars. I would recommend getting the new eTrex Legend H with the high sensitivity receiver if you want a similar model. It's sat reception will blow the prior version out of the water and has 24mb of memory rather than the 8mb it used to have.
Jan 19, 2009 | Garmin eTrex Legend GPS Receiver
No reply from garmin
We are NOT garmin, we are a help site for various products. You'd be best to write Garmin with all the details of your unit ID, date sent, etc.
Jan 12, 2009 | Garmin eTrex Legend GPS Receiver
How do I convert the gps coordinates from Google Earth?
In GoogleEarth, change your coordinates to decimal format. In your Lowrance GPS, change that format to decimal. You don't mention which Lowrance model so I can't find the online manual to tell you exactly how to do it.
Jan 01, 2009 | Garmin eTrex Legend GPS Receiver
Screen is unreadable
I have garmin e-trex Legend and it was just working fine then the next time i turned it on the screen is unclear with lines thru all the writing. Please help.
Jun 04, 2008 | Garmin eTrex Legend GPS Receiver
Garmin eTrex Legend GPS Receiver Logo
216 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
