Question about Kenmore 73952 Gas Dryer
Kenmore 400 series electrical dryer
Was working fine then just will not turn on anymore does have power
  • bigce Nov 02, 2008
    My Kenmore 60 series is not tumbling
I have a 400 series kenmore dryer that just quit running after 10 min. into cycle. breaker in house checked and is ok but no power to dryer. what could the problem be
Posted on Mar 30, 2011
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Kenmore 400 series gas dryer doesnt dry clothes
Replace timer, if you are sure that it is not working.
Do an internet search for kenmore driver parts and get dozens of hits.
Aug 03, 2014 | Kenmore Dryers
I have a Kenmore 400 series top loading electric dryer that just stopped working right in the middle of a load of clothes. It was working just fine and then it just stopped. Now it will not turn on at...
Hi there....this sounds to be like you blew the breaker. Go to your breaker panel in your house and search out the fuse for the dryer. This will be a double 110 volt breaker. You need to reset both sides to be sure. It is easily locatable as they almost always have the items listed on the inside of the door of the panel. If this works for you great. Please try to remember to click on the yes box on your way out ...thank you and good luck.
Oct 10, 2010 | Kenmore 73952 Gas Dryer
My kenmore 400 series dryer will not start. It has electricity the inside light comes on when I open the door. I push the start button and nothing happens.
There is a thermocouple on the inside that prevents the dryer from getting too hot. If this burns out this opens the circuit so the dryer will not work but all other functions will work.
Sep 23, 2010 | Kenmore 400 6943 Dryer
Kenmore series 400 electric dryer when I press the start button won't start bar
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 31, 2010 | Kenmore 400 6942 Dryer
Kenmore 6742 - 400 series electric dryer - has quit heating
Could be a broken heating element or a safety limit . The safety would open if you have some sort of air restriction due to lint or kink in hose. I have some repair photos HERE
Jan 02, 2010 | Kenmore 400 6942 Dryer
I have a Kenmore Serie 400 Dryer. It goes on and never stops. It doesn't heat up anymore, it just tumbles. How do I go about finding the problem ?
remove back cover, check with an ohm meter the heat element and also the hi temp thermal fuse above the element for continuity, if open replace.
Aug 18, 2009 | Kenmore 400 6942 Dryer
Kenmore 400 Series electric takes ver long time to dry.
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem. Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Mar 09, 2009 | Kenmore 73952 Gas Dryer
Kenmore 400 series dryer
is the belt broken? some dryers have a belt broken switch.
Oct 18, 2008 | Kenmore 62602 Electric Dryer
Kenmore dryer stopped working, start button does nothing
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Jan 21, 2008 | Magic Chef CYE4000AWW Electric Dryer
Kenmore 73952 Gas Dryer Logo
993 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
