Back to:
Tags:
Dell A940 All-In-One InkJet Printer
Error 0502 (by 14 users)
posted by De Guyver on Jun 06, 2006
Getting the 0502 error when turning on the printer
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
13 Other Users Have The Same Problem
Comment by mengesath, posted on Sep 10, 2008
Error code 0502 keeps showing and printer will not print
Comment by sailaway56, posted on Aug 30, 2008
refilled Dell catriges and still wouldn't print. now when I turn printer on it makes a banging sound and still wont print and I get hardware error 0502
please help
Comment by af11, posted on Jul 13, 2008
While when I try to fax or copy it shows up hardware error 0502.
Jasmine Prince
Comment by GDP3030, posted on Jun 30, 2008
i turn the printer on it goes to line up the ink car and error out hardware error
0502 Help!!!!
Comment by Guest, posted on Jun 26, 2008
hardware 0502 displayed..cleaned shiny bar with Kleenex and the lubricated with WD 40 and still doesn't work
Best Solution
posted on Jun 03, 2008
FixYa! (100)
augusta-loui
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
Fixed the problem first time. Tipping printer upside down so dislodgeing any detritus probabaly did the trick!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Error 0502:
I don't want to Accept this solution
Solution #2
posted on Dec 05, 2007
FixYa! (100)
Trimble
Rating: 98%, 18 votes
Your solution to error 0502 was 100% correct. It fix the problem
Thanks, John
Thank You!
Solution #3
posted on Jun 06, 2006
FixYa! (100)
silly girl
Rank:Wiz Wiz
Rating: 81%, 3302 votes
Re-position the Encoder Strip on your all in one Printer
To re-position the encoder strip, perform the following steps:
1. Remove the power cord from the unit.
2. Lift the lid of the unit, just below the scanner portion of the All-In-One, to expose the inside of the unit where the printer cartridges are located.
3. Gently slide the ink cartridge carrier to the middle of the printer.
4. Gently move the top part of the printer belt to the right.
5. Using an index finger, gently push encoder strip down and then back up to get it back into the slot located on the back of the ink cartridge carrier.
NOTE
NOTE: There is a small slot that the encoder strip fits into, which is going to be located on the back of the ink cartridge carrier.
6. Gently press the strip first to the rear and then forward to ensure that it is seated correctly.
7. Manually move the ink cartridge carrier to the left, then to the right to check the positioning of the encoder strip.
8. Once the encoder strip has been re-seated, close the lid to the unit.
9. Re-connect the power supply to the All-In-One.
10. Press the Power button. If the encoder strip was re-seated correctly, the Hardware Error: 502 code will not appear.
See attached pictures, one for an out or place encoder strip, the other for a well placed strip.
Other faults that can bring up this error is a carriage rail that needs cleaning and oiling (so you might want to do that while your inside the thing), and also obstructions to the paper ways. Try removing paper jams, and put the printer upside down to shake loose anything that might jam the mechanism.
Comment by silly girl, posted on Jun 06, 2006
this one is of an in position strip
Thank You!
Solution #4
posted on Aug 29, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
-Removed ink tanks
-Cleaned ALL contacts with alcohol pad
-Cleaned ink ports on tanks with alcohol pad
-Reinstalled tanks
-Ran jet clean using dell program
-All checks-"SAT"
Thank You!
Solution #5
posted on Jun 09, 2008
Not Rated (0)
Tatianna
Rating: 0%, 0 votes
Worked very well, once I figured out the diagram and followed the directions. Though since the procedure it is quit a bit louder than before. I hope this fix will last. If not, I will return for more help. THANK YOU very much. and May the computer G~ds smile upon you and all of your machines :-)~
Tatiana - Fort Lauderdale
Thank You!
Solution #6
posted on Mar 06, 2008
Not Rated (0)
tonyet031462
Rating: 100%, 3 votes
My printer is horrible it will start printing then make a very loud popping noise or it will go "screech"!!!!!!!!!
Thank You!
Can you Help with these Printers problems?
need help with printer
As printed pages come off there is ink at some paret of...
i installed my printer, it won't print a thing and reads...
tells me paper jam but no paper in printer and it will not...
was working fine ' it's full of ink but won't print the...
13 Other Users Have The Same Problem - Continued
Comment by dumbdell, posted on Jun 11, 2008
prints portion of a page .Error 0502 comes up on printer. Cartridge stall, comes up on computer monitor. I follow the instructions given......it makes no difference.
Comment by avee007, posted on Apr 03, 2008
remove cartridges and clean them.
Comment by Bouie143, posted on Mar 02, 2008
our printer is given an "hardware 0502 error" and will not preform any functions.
Comment by jeanybabe, posted on Feb 27, 2008
I have a hardware error code 0502. Have tried WD40 on the metal rod and baby oil nothing seems to work.
Comment by gtaylor1954, posted on Feb 25, 2008
it will not print where the ink go it gust move a little and there is a big poping sound
Comment by rsmadrid, posted on Feb 24, 2008
When I use the printer as a copier it will start to copy, but then stop midstream and show a " hardware error 0502"
Comment by Mounder, posted on Feb 08, 2008
We keep getting a hardware error 502. It does appear the encoder strip is out of place, but where exactly is the slot it's supposed to fit into? I can't feel anything on the back of the cartridge and you sure can't see anything. The pictures supplied by dell are worthless.
Comment by jojov, posted on Jan 06, 2008
error code 0502
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
