Question about Kenmore 62602 Electric Dryer
Kenmore 400 series dryer
Has power but will not turn on
    Sergeant:
    Champion:
  • 324 Answers
Is the belt broken? some dryers have a belt broken switch.
Posted on Oct 31, 2008
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Kenmore 400 series gas dryer doesnt dry clothes
Replace timer, if you are sure that it is not working.
Do an internet search for kenmore driver parts and get dozens of hits.
Aug 03, 2014 | Kenmore Dryers
I cleaned and made sure there were no loose connections. the dryer will not start. could it be the push to start relay or an issue with a fuse. is there a common item that is usually fails on the kenmore...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 10, 2011 | Kenmore 400 6942 Dryer
Kenmore 400 series dryer heats but does not turn, how do I access drum belt
to open dryer:
http://www.partselect.com/dryer+open-cabinet+repair.htm
belt:
http://www.applianceaid.com/images/belt-config.JPG
Dec 11, 2010 | Kenmore 400 6942 Dryer
Kenmore series 400 electric dryer when I press the start button won't start bar
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 31, 2010 | Kenmore 400 6942 Dryer
My Kenmore 400 series is taking too long to dry
Make sure the vent and tube are clear and not blocked in any way, if clear try washing off the lint screen with hot water, softener will clog the filter
and not allow proper air flow, water will bead up on screen if this is true
Oct 27, 2009 | Kenmore Dryers
Kenmore 400 series dryer will not heat?
LP dryer flame goes on for a few seconds and them goes off
Oct 27, 2009 | Kenmore 73952 Gas Dryer
I have a kenmore 400 series dryer model no heat
Srart by pulling each thermostat wires and tape them together until you find the bad one. You should have 3 of them to test.
Oct 25, 2009 | Kenmore Dryers
Kenmore Dryer 400 series turns on but will not dry
Maybe the heat-fuse are broken. Need check and change if necessary.
Oct 02, 2009 | Kenmore 73952 Gas Dryer
Kenmore 400 series electrical dryer
I have a 400 series kenmore dryer that just quit running after 10 min. into cycle. breaker in house checked and is ok but no power to dryer. what could the problem be
Oct 18, 2008 | Kenmore 73952 Gas Dryer
Kenmore 62602 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
