Need code to make multi region
Have a philips dvd and want to be able to play all dvds, ours says region 4 on back want to be able to change to all region
thanks
Lynda
  • 376 Answers
Http://www.videohelp.com/dvdhacks?dvdplayer=philips&hits=50 Search for your model on the following link to see if theres a hack available for your player.
Posted on Oct 19, 2008
Will the dvp 311ok play ntsc dvd i am in australia and i am reg 4
As long as the NTSC DVDs are not region coded, and your TV is multi-standard (able to receive NTSC as well as PAL signals via A/V inputs or similar connections), the player should play NTSC just fine through it
I assume this is a PHILIPS player? If so, most PHILIPS DVD players support NTSC playback on PAL TV.
You are correct, Australia is region 4 for DVD standard. The only restriction would be region codes.
Feb 27, 2011 | Televison & Video
My DVD player isn't multi-regional
Here's the regionfree code..
1. Open Tray
2. Press 9,9,9,9,0
3. Press open/close to close the Tray
4. Regionfree..
Jay
May 28, 2009 | Philips Televison & Video
Multi region code for philips hts 3090 dvd player
With your set on and without disc in the tray:
1. Press PLAY from your remote control
2. Press the following button sequence: 1590 2379 390
3. Press PLAY again
This will release the region verification in your home theater (region free). However, some DVDs (multiregion in particular) will not play, since they require region detection from the player unit.
I've done this to my 3090 and been using it like this for 3 years.
Mar 08, 2009 | Philips Televison & Video
Our Sony DVD player will not playimported DVDs from the UStates
1) those DVDs are coded in Region 1(Canada, United States; U.S. territories; Bermuda)
you will have to change the region code on the dvd-rom to region 1
2) if you bought the stand alone DVD player in the U.S. it will play region 1 dvds and nothing else(some dvd players will play region code 1-6)
3) to change the code in windows vista you'll have to go under the drive property's in the device manager go to the dvd region tab and set it to what ever the number on the back of the dvd is WARNING you only get 4 changes before the drive locks you out permanently then your stuck with what ever number you put in on the 4th try you've been warned
windows xp/2000/98/me
you'll have to change the region code from your software player again your limited on how many times you can change the region code before you have to reinstall the dvd player software
Feb 02, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Philips 7" DVD portable player
The PET702 will be a region 5 machine, whereas the UK DVDs are region 2.
DVD players from a particular region are designed to play only DVDs from the same region, due to copyright and distribution rights in each country or region.
However the PET702 can have the region protection removed by making it multi-region:
Switch on the PET702 and Open the tray.
Press SETUP button on the remote control, which will bring up the menu.
Highlight "PREFERENCES" and press OK.
Press [2], [5], [2], [3], [1], [5], [LEFT], [DOWN]
The screen will show: "Region Code: 2"
Press [1-6] to manually set the region OR [0] for multi-region.
You will now be able to play DVDs from anywhere in the world.
This is particularly useful, because region 1 DVDs from the US often come out when the movies are still in the cinemas over here. Region 1 DVDs can be bought perfectly legally by mail order or from the internet.
May 07, 2008 | Televison & Video
Philips DVD Player 3144
1. Turn the unit on and open the tray. Take out any disc from the tray.
2. Enter the code 98790 on the remote and press Ok. The 0 on the end is the region. Eg to change it back to a region follow step 1 and enter the code 98794. 4 being the region code in this example.
3. To check the region code follow step 1 and enter the code 966.
Apr 27, 2008 | Philips Televison & Video
Multi region phillips dvd player
Is this a Multi-region Player ?
Some Players are region Set to play Only the region they, are intended For. i.e Region 1 = NTSC( USA ) Region 2 = (PAL ) UK. Region 6 = ( ASIA ) And so on.
If you need a multi-region hack for your player, Post here.
I do charge a Small fee for This service.
Mike @ compurepair.
Feb 29, 2008 | Philips DVP3140
Invlaid region code
Sounds like you are trying to play a DVD of a different region to that of the player.
Worldwide region codes, sumarised:
1 - US / Canada
2 - Europe
3 - Asia
4 - Australia
5 - Africa
6 - China
You can change the region code of the DVDR520H to any region or use region 0, which makes the unit multi-region to play DVDs from any region.
  1. Go into the main menu
  2. Highlight the exit button
  3. Type 2960
    This should give you access to a hidden menu form where you can change the region code.
Feb 20, 2008 | Philips DVDR520H DVD Player/HDD
Programmed for region 2....Need to change to 1
Q: What is Regional Coding enhancement(RCE)?
A: It's a digital enhancement added to some Warner Bros and Columbia DVDs to stop region 1 (R1) DVDs from playing on Region-free DVD players.
Q: What's the difference between Region Coding and RCE?
A: Regional Coding enhancement(RCE) is an additional layer of protection which some studios have placed on select REGION 1 DVDs to prevent them from playing on region-free or multi-region players. Region Coding is a part of the DVD spec which divides the world into 8 regions:
Region 1: U.S., Canada, U.S. Territories
Region 2: Japan, Europe, South Africa, and Middle East (including Egypt)
Region 3: Southeast Asia and East Asia (including Hong Kong)
Region 4: Australia, New Zealand, Pacific Islands, Central America, Mexico, South America, and the Caribbean
Region 5: Eastern Europe (Former Soviet Union), Indian subcontinent, Africa, North Korea, and Mongolia
Region 6: China
Region 7: Reserved
Region 8: Special international venues (airplanes, cruise ships, etc.)
Basically, DVDs released in each region will typically only play on players sold in that region. IE a DVD released in the UK *Region 2* would not play on a player sold in the us *Region 1*. You can tell what Region a DVD is coded for by looking at the back of the box for a Globe with a number on it. The number correlates to the region list above. If a DVD is listed as 'Region 0' it means that it isn't coded for any region and should play on ALL regions players.
Dec 14, 2007 | Philips 30DV693R 30 in. TV/DVD Combo
Incorrect region codde
This is for DVP31XXX series i hope it works all on DVP31 series. It has been tested on DVP3146K /51 and it has been worked...
1. Make sure there is no disc in the player.
2. Turn power off and on again.
3. Open the tray.
4. On the remote, hit 9879 and then 0. This changes unit to Region 0, meaning it'll play all regions.
5. Hit OK on the remote.
Good Luck Guys!
Apr 27, 2007 | Philips DVD 622 DVD Player
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
