Question about Mitsubishi WS-55613 55" Rear Projection HDTV
No color on mitsubishi 1080
Turned on mitsubishi 1080 and no color
    New Friend:
Projection is not clear what will be the problem and solutions
Posted on Dec 19, 2012
  • Luis Martinez Dec 19, 2012
    I have cable or Concast the problem is how can I ajuste the picture and colors
    Scholar:
  • 70 Answers
1080 is a High Definition setting. If your Television is HD capabilities you need to make sure that the programming that you are viewing is being broadcasted in 1080. If it is not then you will see a difference in picture quality and sound. If no color at all and program being watch is HD programming check your connections on back of Television. depending on what kind of input the Television is receiving you might need to try new cables or a new input. Good luck
Posted on Oct 18, 2008
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi Medallion 1080 WS-55413 - colors not aligned
There is no "reset" as the set has in the customer and tech menus ways to attempt to manually adjust this.
under convergence in the customer menu select advanced and follow the instructions on the screen.
If Red or Blue or Green are skewed and will not adjust it means one of the two STK-394-250 CONVERGENCE chips this set uses is bad.
Depending on where you buy them they will range in price from about 12 dollars each to nearly 35 dollars each.
Let me know what you find; this may or may not be a do it yourself repair as some real expertise is required to correctly get at and replace the chips.
SD TECH
Posted on May 12, 2010
65" 1080 mitsubishi tv model# WD-65733 wont turn on
It is probably the wiring. Try buying a new power cord.
If not than it is just malfunctioned.
Contact Mistubish
http://www.mitsubishi-tv.com/contact
Nov 25, 2012 | Mitsubishi WD-65733 65" HDTV
SD TECH
May 11, 2010 | Mitsubishi WS-55413 55" Rear Projection...
I bought a used mitsubishi ws 55513 and when i turn the tv on is says 480i stretch. How do i use the 1080?
U don't get to chose modes.480,720 and 1080 it chose by the tv show itself.Want more 1080 must have HD package from cable or satalite compannies.
Jan 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
I have a mitsubishi 1080 series wt-42311 model. When I turn on the TV the green lite comes on then goes off? The TV wont turn on.
STKs,one of them controls startup if bad TV will not come on.STKs are big black ICs will have part# on them. call Mats for parts you have 2 replace both. 1-800-628-1118
Sep 18, 2009 | Mitsubishi WS-65315 65" Rear Projection...
The picture on my tv (mit. 1080) is made up of
Convergence ICs Two of them STK392-570 ,they are big black ICs,Replace with same Number on ICs.You can order them at MATS 1-800-628-1118.
Aug 07, 2009 | Mitsubishi WT-46805 46" Rear Projection...
MITSUBISHI HD 1080 series
most likely the convergence Ics have failed. Check F9a04 and F9A05 pico fuses if they are blown you will need to replace them and the convergence Ics.They are located on the center board they are green and look like resistors without the color band. see the photoa193b32.jpg82b89b8.jpg
Feb 08, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi hd 1080 tv humming and blurred words/ bight colors
check the capasitor near the plyback value 250 volts and also the B+ capasitor
Oct 01, 2008 | Mitsubishi WS-55807 TV
Tv will not turn on manually or with remote
you need to get the stk chips replaced. i had it done with mine, it cost me 411 dollars for a tech to come do it. it worked fine for about 4 months now, and my red color is gone. mitsubishi sucks, sorry : (
Sep 25, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi 1080 hd
check and re-solder the connections on the 2 convergence ICs in the middle power board. they are going to be attaches to the biggest heat-sink in the tv. if the re-soldering doesn't fix then replace with STK392-570 i would replace both but if you look at the board you should be able to figure out which chip is responsible for the vertical and which is the horizontal convergence. each IC converges all 3 colors but one is responsible for one axis.
Feb 20, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
260 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
