Question about Samsung DVD-V6700 DVD Player/VCR
How to program Samsung DVD/VCR combo V6700 to tv channels?
I have lost my manual for the Samsung DVD/VCR combo and don't know how to program it to local tv stations to record stuff. Anyone?? Please help!!
4 Suggested Answers
  • 120 Answers
SOURCE: Region code for Samsung DVD-V6700
Humm...have you tried going to www.videohelp.com to find a regon free hack? Just put your machines numbers in, hit search, scroll down to your machine. And see what they say-usually on the right side of the page.
Posted on Jun 27, 2008
  • 3 Answers
SOURCE: Samsung DVD-V4600A Combo DVD / VCR will no longer timer record to Videotape
Storms tend to fry most delicate electronics. Quality surge protection is required.
Ben
Posted on Jul 26, 2008
SOURCE: i need help programming vcr to tape show
Since the V9800 has no built-in tuner, your TV set must be set to the channel your show to be taped is on. There is no way to tune it to any particular channel. Now, isn't that convenient?
Posted on Feb 25, 2010
etaf
  • 779 Answers
SOURCE: Check firmware version Samsung DVD-V6700 DVD
Posted on Apr 10, 2010
I have lost my Samsung V6700 manual. How can I get a copy.
Hi!
you can download it from here for free...
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Apr 07, 2011 | Samsung DVD-V6700 DVD Player/VCR
I am trying to program my urc-4220 all for one remote to my tv and dont know how, i have an older zenith tv and need to know the steps to programing it to my tv
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program before starting step 2.
2. On the remote control,press a device key once (i.e.,VCR/PVR,DVD,CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press VCR/PVR once. After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes (starting on page 36) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn’t work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
Download the full manual for FREE with codes included from http://www.replacementremotes.com/One-For-All-Manuals/Download-FREE-URC4220-MANUAL-OPERATING-MANUAL.html
Aug 11, 2010 | One For All URC4220 Remote Control
Apr 10, 2010 | Samsung DVD-V6700 DVD Player/VCR
How do i program a remote for this product....i
Samsung.PartStore.com
or
Remotes.com
or
ak5900051b.jpg&size=16&dhm=121da6f5&hl=en SAMSUNG DVD-V6700 DVD/VCR REMOTE CONTROL
$14.95 new - NewRemoteControl.com
Oct 01, 2009 | Samsung DVD-V6700 DVD Player/VCR
Lost remote to sylvania combo tv how can i change the channel manually?
If tv is programmed you should be able to change channels at the tv front control panel. Also, you can buy a univeral remote and program it to your television.
Apr 23, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
I have a samsung dvd vcr combo connected to a jvc tv but when i have press play i get no screen for either video or dvd the dvd runs but no recpetion
If you are connecting the dvd/vcr combo to the tv with coax cable first make sure the tv is on channel 3 and also make sure you have the samsung dvd/vcr combo on channel 3 by using the remote that came with the samsung. You should get picture and sound then if not try channel 4 on tv instead of channel 3. If that doesn't work try to put the samsung on channel 4 as a last option to try. This is only recommended if the combo is hooked to tv with coax cable out of combo to in on tv. Make sure coax is plugged into the out jack on combo and in on tv.
Nov 26, 2008 | Insignia Digital-to-Analog Converter for...
Region 1 to Region Free
Here is the region hack:
Tested working on a region 2 Samsung DVDV6700.
1) Turn on
2) on the remote press subtitle button
3) on the remote press enter , 5 , 7 , 5 , 3 , 8 .
4) region 2 will appear in the left corner, press 9 to make region free,
press the subtitle button
5) open and close tray twice
6) power down then back up
& your machine is multi region
Let me know if it is working.
Sep 09, 2008 | Samsung DVD-V6700 DVD Player/VCR
URC-3021B00
PROGRAMMING DEVICE CONTROL
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
then release SET.
4. Use the Manufacturer’s Codes (starting on page 18) to
For future reference,write down each working device
Here is a link to your manual:
http://www.ofausa.com/remote_manual/CTGA...
Nov 26, 2007 | One For All URC-3021 Remote Control
Samsung DVD-V6700 DVD Player/VCR Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
