Question about Technics SA-DA8 Receiver
Cuts out after about 30 min when in surround sound mode.
After about 30minutes in surround sound it cuts out. If you crank the volume you can hear it but it's at a whisper. In stereo mode it can play all day long. It was very hot to the touch. Checked the cooling fan which didn't come on regardless of what the volume was at. Replaced it with a computer fan of the same size and now the fan does come on, so I thought the problem was fixed. But it's still cutting out in surround sound just like before. I don't think it's the connections as I have completly disconnected everything from it and reconnected at least a dozen times with both my upstairs entertaintment setup and my basement entertainment setup. Any advice would be greatly appreciated as well as wether the unit is worth repairing or replacing. Thanks.
  • RONNIN Jan 12, 2009
    Thanks for the help!! But I don't think there is a spot for another fan. Although heat may not be the problem as it'll work all day long in stereo.
    Genius:
  • 2,035 Answers
If the unit is heating even if the fan is running then there component failure ,you need to replace the component on the unit will resolve the issue and if really like sound quality then it worth fixing and if go service center it may cost around 200$ , if want you do it yourself the please click on this link get the
Service manual and components list:
http://www2.panasonic.com/consumer-electronics/support/Audio/Technics-Audio-DJ/Technics-Receivers/model.SA-DA8
and click on :See parts available for this model
And
Posted on Jan 12, 2009
  • Anand Kumar
    Anand Kumar Jan 12, 2009
    And parts list ..
    Good luck..
    Sniper:
  • 59 Answers
Hi welcome to fixya i think that you should replace it because if something like this happens again then you will have to pay more money if you look at it in the long run your gonna be saving money by getting a new one
    President:
  • 1,990 Answers
Welcome to Fixya! Have you tried Running Dual Cooling fans on this Unit? Could make all the Difference.
  • Travis Humphries
    Travis Humphries Jan 12, 2009
    Just for kicks. Get a Portable Fan and put it where it will Blow Directly on the Back of the Reciever and Try it. If not you will have to replace the Circuit board on the Back side of the Reciever. Trying to not have you do that Though.
Lg32lc46 lcd tv cuts off after a while
It sounds like a back-light inverter board fault. Check it. Replace it if needy. Normally, these boards has no repair. Replacement only can be done. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 24, 2013 | Televison & Video
I have a Panasonic HT-692 surround sound system. Any time I use the surround sound features and turn the volume to a higher level(not ear piercing mind you) the system cuts off as if a ckt breaker has
If you are playing the unit that loud, for an extended time it sounds like the unit is going into overload, meaning it's getting to hot. Try turning the volume down to 1/2 of your current level. If it stays running, you will have to cut back on your volume, before you seriously damage the unit(or your hearing)
Dec 18, 2011 | Panasonic Audio Players & Recorders
Cuts out and stops sometimes after 30 min. or so
check your fuel delivery system. It sounds like a blocked filter, failing pump or a restriction in the fuel line.
Apr 25, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Car starting and shutting off
sounds like a loss of spark issue, have u had it checked for computer trouble codes? if not Kragen and Autozone do it for free.
Mar 31, 2009 | 1996 Oldsmobile LSS
5.1 Surround Sound Cutting Out
HI,
Yes you are right man, this problem occurs only with the cable problem, i can explain you, if there is a receiver problem means you won't get the sound its dam sure,
only if there is a cable problem you will get some noise or sound cut off with the speakers, so you please check the cables properly it will be alright.
Mar 26, 2009 | GE GTD120 System
Bose surround sound system cuts off
Hi when you turn on check all your speakers work check connections make sure the wire has no stray strands touching the fault could be in the sub unit this is possible / or your speakers one or more could have gone short circuit due to exessive volume thats if you play loud. Had a party lately .Just joking .Regards kirk
Dec 10, 2008 | Bose (321GS) System
Sound cut-out
Most likely this unit goes into protect mode due to heat detection. Try to see if there is a pattern to when this behavior starts. Does a lower volume level allow the unit to run longer? Perhaps there is a problem internally that is allowing DC voltage to get to the output stage. This will cause excessive heat which can then cause the protection circuit to kick in. This unit may need to see a bench with some test gear to locate the exact problem. If you can, look for any pattern and update this.
Dan
May 13, 2008 | JVC RX-6042 Receiver
Bass module
You dont have to crank up the volume to hear the bass man. It sounds like you have a bad connection some where. check all your connections and also if the wires are shinning and not dull at the connection point. having carbon or dust there will not help.
Apr 10, 2008 | Bose Acoustimass 15 System
Sound level & Picture size
The screen height is easy, just press the "view mode" button on the controller and change the scaling thru that. As for sound I'm not sure on that, as I can hear mine just fine, plus I use a surround sound system.
Jan 14, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Denon AVR 2802 - Unit Turning Off
If DIGITAL sign blink, this mean DSP board is defective. It will cut the sound on the AMP section. DSp is maybe defective.
Jan 12, 2008 | Denon AVR-2802
Technics SA-DA8 Receiver Logo
128 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
