Question about TurboChef TORNADO Electric Oven
F3 MAG Error
Hi, I am looking solution for F3 MAG error in Turbochef TORNADO. I read article for checking MAG, now how do you I check ? Even if I find out there is a problem, where will I get them.
Thanks, Rajesh sqlr@in.com
  • 45 Answers
When f3 comes up change both megs not just one cause it will go shortly after. I have been working on these ovens for almost 15 years.
Posted on May 09, 2012
Open the right side panel and change 3rd fuse from the left
Posted on Nov 03, 2008
F3 Mag Low Current
did you check transformers. also k1 , k2, k3, relays. also make sure all wires are put back right and the diodes are going in the right direction.
Mar 29, 2014 | TurboChef TORNADO Electric Oven
F3 mag current
well...seems that you have an early warning of a possible failure of a major component. Is this unit still under warranty, by chance?
Jun 20, 2008 | TurboChef TORNADO Electric Oven
F3 mag error. can it be the waveguides.
What is your amp draw? You could just have a bad I/O board.
Oct 02, 2012 | TurboChef TORNADO Electric Oven
Hi, F3 mag curr. what is means and how do I fix it?
F3 is an complex code.
Easy fix is look at the transformers and the capacitors and the diodes.If it seems that any component has changed its appearence then fix it and replace the F3 fuse(3rd one from the front).
If the magnetron is bad ,then to check that you must know how to use clamp ammeter.
let me know if you know how to use clamp meter .
I will give you the solution .
NOTE oven has 5000V in it.
make sure you dischared the capacitors.
Thanks
please rate my work
Apr 16, 2011 | TurboChef TORNADO Electric Oven
F 3 mag error. had a bad magnetron and hv transformer. went head and changed both hv transformers,diodes,caps,magnetrons. worked for about 5 hours and its back to blowing f3 fuse. Any ideas
F3 errors can indicate a mag problem. Did you replace both mags? It can also be a door switch. If your fuses are good, you need to inspect the 2 magnetrons. If you have a burned tip on one the waveguide and waveguide cover it will need to be replaced.
Feb 05, 2011 | TurboChef TORNADO Electric Oven
I have a c3 oven that has a fault code f3 mag curr
Very expensive mag required , buy tornado or i3 instead don't waste your money on c3
Jan 03, 2011 | TurboChef C3 Single Oven
TURBOCHEF TORNADO OVEN...Errors F3 Mag Current and F5 Mag Temp just began. They appear occasionally, now and then. Oven temp seems about right to me. What needs replacing or attention? Thanks!
the mag's only activate while in cook cycle, it will be hot as normal with toasted subs that are cold in the center.
AMP draw the Mag's and ohm the Mag thermal couples
Oct 14, 2010 | TurboChef TORNADO Electric Oven
Turbochef Tornado doesn't always heat food internally
you could have a problem with the microwave circuit. That would really be the only thing preventing the food from heating internally. I would call turbochef and call for warrenty service again. Is the bread comming out nice and toasty. If the blower for the convection circuit is weak or sticking this also cause the same effect of not properly cooked food.
So check microwave circuit and also check the blower.
Hope this helps if you need more in depth advice feel free to ask
Feb 15, 2010 | TurboChef TORNADO Electric Oven
F3 Mag Curr. on Turbochef Tornado
Hello. Interesting coincidence, but that error code is for the magnetron/microwave part of the toaster. You will need to have it serviced by someone familiar with the unit, it could be easy and reasonable, if just a fuse blew, but not likely. If the fuse blew, it is 20amps, so something took it out. Call turbo chef, they will get you to the closest servicer, may be able to help you on the phone.
Here:http://www.turbochef.com/commercial/site.php?PAGE_TYPE=CONTACT
or 1800 90turbo
Hope that helps, and thank you.
Dec 21, 2008 | TurboChef TORNADO Electric Oven
Turbochef tornado
F3 errors can indicate a mag problem. Check your fuses first, it can also be a door switch. If your fuses are good, you need to inspect the 2 magnetrons. If you have a burned tip on one the waveguide and waveguide cover will need to be replaced. I usually replace the entire system at a cost to the customer of $1500.00
Jun 21, 2008 | TurboChef TORNADO Electric Oven
TurboChef TORNADO Electric Oven Logo
1,221 people viewed this question
Top TurboChef Ovens Experts
Sean McKenna
Level 1 Expert
Richard Roth
Richard Roth
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
