Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tv Keeps Blinking
After my tv warms up the picture starts blinking and gets progressively worse until it blinks once every second. Can anyone tell my whats wrong? Thanks.
  • jas78 Dec 30, 2007
    after my tv warms up, it starts to blink. the longer I watch it the more frequently it blinks. what could be the problem and how do I fix it?
  • latasingh Aug 10, 2008
    toshiba tv model number tp50h60 power switch on tv front panel , blinks no picture /no channel ???
WHY DOES MY SONY TV KEEP ON BLINKING
Posted on Jun 14, 2010
  • 513 Answers
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. In some other brands/models the tubes have problems over heating and cracking. This would give you the same symptoms. If this is indeed your problem you will have to replace all 3 tubes, since leaving some to be stronger than others will still result in blinking. Can be very expensive, up to a 1000 $. Good luck
Posted on Jun 08, 2006
SOURCE:
Sharp aquos TV lc-42d64u has blinking power light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 07, 2016 | Sharp Televison & Video
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
Samsung DLP HL-R5067 blinking lights
when is the wheel is broken doo you cleaned the glass around because if it not rotate tv not turning on it is a one of the posibilitis
Mar 02, 2017 | Samsung Televison & Video
Sony Model KV32FS13, blinking lights.
check the horizontal output of your tv set,if short you need to replace it.
Dec 09, 2008 | Sony KV-32FS13 TV
I have a celestial HP4388I rear projection TV and it just switches its self off from time to time and when you try and turn it back on it wont turn back on the light keeps flashing but no picture. So i...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
Aug 24, 2017 | Televison & Video
Samsung hlp5674w
not blub you do get light ie a picture it sound like your video processor has a heat problem,
alias, you can not repair this you self, Hope its still under the warranty. You got to take it to the repair man... Soory
Feb 12, 2008 | Samsung DLP HL-P5663W 56" TV
Blinking picture until warmup
On Sony TV's they monitor the current drain on all three electron guns Red Green and Blue. Until all are somewhat equal it will keep the CRT blank. As the set ages it means that it might flash a few times until the cathodes are good and warmed up.
Jan 28, 2007 | Sony KV-32V36 32" TV
Sony KV-36XBR250 - no picture, good sound
This is a common failure mode (which I now share), and has nothing to do with the picture tube or surge protection. From the forums I have searched to-date, it appears to be a failed component in the flyback circuitry, but Sony will not admit to an inherent defect. If anyone has ACTUALLY FIXED this problem, please post a reply. Guessing won't help anyone. Thanks.
Oct 24, 2006 | Sony KV-36XBR250 TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
1,308 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
