SOURCE: Dell 5150 - solid amber light at the switch.
This is Telling you battery has gone bad, I had that same problem
SOURCE: amber light on power button of Dell Dimension 4500
ok - the amber light of doom on a dell means one of two things - either your power supply is pooched - or your motherboard, If under warranty dell will send out a friendly tech to replace them - if not it will cost you a bit. get the price and consider if it worth upgrading instead. Contact your dell rep or dell tech support and see what they say
cheers Pete
SOURCE: Dell GX270 won't boot up with solid amber light on Power button
Check motherboard for bad capacitors. I had the same problem and when i had bad capacitors replaced everything is ok.
SOURCE: blinking amber light with green 4 light
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Try, unplugging the power cable from the pc, and reinsert it, if this does not help try a differnt power outlet, if this dont help, open the computer, take the power Molex conector out of the mother board and try turning it on, if this dont help, take out the Memory modules and reseat them, if this dont work you may want to ring up dell support.
Hope this helps!
SOURCE: Solid Amber light when starting the Inspiron 530
Amber led simplifies a start-up-error. This could be a number of things.
For example:
Check if HDD is connected properly
Check if RAM is connected properly / also if this is damaged your pc wont start.
Check your m/board for any loose capacitors an if they are not popped at the top.
Your LCD screen is properly plugged in to the m/board and if the cables aren't damaged they are very thin and fragile.
also could be the power supply...
Goodluck
Ryno Gerber
