Question about Brother IntelliFAX-2440c Plain Paper Inkjet Fax
No dial tone
I have a Brother FAX 2440C. The machine has been working properly for two years. When I tried to make a phone call I had no dial tone.The machine still makes copies but can't receive or send fax's or calls.Hooked up another phone to the line and line is OK.Also hooked fax to another line and still no dial tone.
Leo
  • Anonymous Oct 31, 2008
    same problem only occured after switching to charter phone service
  • dlgraham Feb 27, 2009
    I have the same problem....Have checked all phone lines and can't get dial tone with phone
Same problem only occured after signing up for charter telephone wonder if they didn't connect basement line
Posted on Oct 31, 2008
    Genius:
  • 2,120 Answers
Very strange that there a no other symtoms.
Are you sure you are plugged into the LINE port of the fax machine?
Posted on Oct 18, 2008
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother 575 phone does not work?
If you can send fax out, your handset should have dial tone. If there is no dial tone, try to replace the handset cord.
Sep 17, 2009 | Brother FAX-575 Plain Paper Thermal
Multifunction phone/fax/copier machine
Hi sythonk
1. Make sure you have a telephone cable connected the jack labelled "LINE" on your brother machine.
Go through the Menu on the LCD, Initial setup, dial tone, choose the correct dial tone PULSE or TONE.
Exit from the menu.
Pick up the handset on the fax machine, and dial your nuber to make a phone call. (To send a fax, dial the number without lifting the handset.)
Hope this will work for you. If it solved your problem, give a please rating
Cheers
luciana44
Sep 06, 2009 | Brother Office Equipment & Supplies
Photo 926 fax no dial tone
ALL fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines.
Jun 30, 2009 | Brother IntelliFax-2820 Laser Fax
No dial tone - brother 1030 fax phone
I'm sorry to say that you've done all you could to assess the problem, and "yes" it is a modem problem
Apr 23, 2009 | Brother FAX-1030e Plain Paper Thermal...
No dial tone when sending fax
PLESE CHECK TO SEE IF YOU HAVE DIAL TON TO ANOTHER PHONE, OTHERWISE THE PHONE BOARD CALL THE NCU BOARD MAY BE BAD
Jan 06, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Intellifax 1270 lightning damage. no dial tone
Plug a regular phone into the wall jack to verify that you have a dial tone.
Nov 06, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
HISSS on line; no dial-tone; no fax in or out
it sounds like you may not have any dial tone. the hiss [white noise] you are hearing is from the dsl modem.try plugging a regular corded phone into the jack to check for dial tone.if there is none,call your phone company.also try plugging the fax machine into another jack where you know there is dial tone.
good luck
wg
Feb 02, 2008 | Brother FAX-2920 Plain Paper Laser
No Dial tone
Have you had an electric storm or power failure? A power surge can cause no dial tone also. It can be the main PCB in the machine or NCU PCB(board for phone cord). Unplug the machine from the wall, put your finger on the menu key first, plug the machine while holding the menu key, the light will flash and display will say maintenance. Press number 82, if there is a DF error the main board will need to replaced. The main board is the brain of the machine and is one of the most expensive parts of the unit. It is hard to distinguish if it is the modem or the main board on this unit that is causing the unit not to have a dial tone. It may be better to take it to a service center.
Aug 15, 2007 | Brother 2440C Colour Plain Paper Inkjet...
Brother IntelliFAX-2440c Plain Paper Inkjet Fax Logo
95 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
