Question about Zebra LP 2844 Thermal Printer
Zebra 2488-z Hello, Zebra lp 2844-z has been printing label without any problem till yesterday but now start to print skipping about half inche and finish about half inch too hight. So that printed label is missing three lines information and finish with half inch extra bottom margin. I tried with setting Paper/Output - Top Adustment but no help. Please help. novice Zebra user
  • Oscar Suarez
    Oscar Suarez May 11, 2010
    have you tried resetting it to factory defaults?
  • 21 Answers
Have you done calibrating ? try to calibrate the printer, or set the printer to the factory setting
Press and hold the feed button until it flash 4 times,
it will restore the printer to default, if that's not work......... then there's a problem on the Media Sensor...... try to clean it up from dust............. or replace the sensor
Posted on Aug 20, 2009
    Scholar:
  • 62 Answers
Check your user manual. Perform a reset
4 flash method.
Posted on Aug 02, 2009
  • 4 Answers
Have you tried cleaning the sensor? It is underneath the labels oppoistethe print head.
Posted on Jul 28, 2009
    Problem Solver:
  • 18 Answers
Unplug the printer, place your finger on the green button and with the other hand turn the printer back on. Let the light flash four times (flash, flash flash, flash flash flash, flash flash flash flash) then immediately release the green button. The printer will cycle and feed out a couple of labels. Press the green button one more time and you are ready to go.
Posted on Sep 20, 2009
I need to print labels and bar codes without installing the zebra driver.
This printer supports EPL if it is a true 2844 not a 2844-z. If you want to print to it directly from programming you can to it that way.
Jul 29, 2015 | Zebra LP 2844 Thermal Printer
Label splits
because if label lengh is ex. 20mm and you set up label print area as 21mm, it will over the size and it will skip the next one. the print area shoul be less than the label length. please verify software or driver.
Jan 22, 2014 | Zebra LP 2844 Thermal Printer
Doesnt print all the way to bottom of label
I had the same issue with my Zebra printer. Make sure your margins are set correctly, and you have the correct size label selected. This fixed my problem.
Aug 07, 2012 | Zebra LP 2844 Thermal Printer
Print labels created in ms access
first check your driver for zebra 2844 it is compatible with the OS, if it's Ok may be you can find third party software that help us create label
May 13, 2010 | Zebra TLP 2844 Label Printer
Zebra LP 2844 Printer Error, Cannot Print
Try this
START
SETTINGS
PRINTER/FAXES
in the pop up window go to
FILE/SERVER PROPERTIES
DRIVERS
SELECT THE MFC5440 DRIVER AND REMOVE
SELEST THE LP 2844 DRIVER AND REMOVE
Now go to www.seagullscientific.com and download the Zebra driver pack, once downloaded run it and install the Zebra Lp2844 to with the USb port.
This should solve the problem, if not please come back.
trevor
Feb 15, 2010 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 direct thermal printer is only printing half the width of the label. Label dimensions appear correct in prefrences.
check the "unprintable areas" on the preference. it should be Zero. find the Zebra Setup Utility on www.zebra.com , with that utility program, try to set the printer to the factory default
Jul 10, 2009 | Zebra Eltron LP 2824 Thermal Printer
TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Dec 08, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
1,504 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
