Home | Creative Labs | Zen Nano Plus MP3 Player | When i dowload music on ...
Creative Labs Zen Nano Plus MP3 Player
Problem for Creative Labs Zen Nano Plus MP3 Player
When i dowload music on to my mp3, some music doesnt show up
By Kendy on Jun 06, 2006
Every single time i download music on to my mp3 player, some of the music wont show up on my player..
for example:
Using windows media player, i download 90 songs, onto my player, and it says all of them have gotten on successfully. BUT when i unplug my player and go back on to look at how many songs it says in the "information" it says i only have 60 songs on my player.
Its like half of the music gets earased! im soo confused! someone please help!
thanks!
Comments:
Jun 07, 2006
- responding back
i loooked and it is supported, all the music is an mp3 and if it isnt. Windows media player converts it. So it can go in player. ahh im not very good with electronics as you can tell... this is really quite confousing. Because now ive figured out that, it just randomly picks what songs it wants to have on the player. As said before i have 90 songs dowloaded and it says that all songs have successfully been on the mp3. And then we i look on the mp3 it says i only ahve 60 downloaded, and they are completey random. Ive re done this about 20 million times, and im using the same playlist, and sumtimes songs that got on my mp3 before dont show up, while the other ones doo.
soo if anyone can give me any other options on fixing this, that would be great!!!
*ken*
Same Problem
Sep 25, 2008
-   i hav almost like teh same problem with my mp3 player an windowsmedia player wen i plug it to my comp it says there on it but wen i go to listion on mp3 player it says empty disk so wat should i try or do?
im not sure wat kind it is my brother bout it off internet an it says its a
firmware v
MP3 PLAYER
LKC_9121_01_01B
2007-01-27
9.0.50
2005-01-09
thts wat is says in the info an it says like firmware version were the info is so if someone could hlp tht would be awsome thx-   drangonsusa
Feb 23, 2008
-   I copy songs from my own cd's, they show on my music list on the computer, but then when I unplug it to listen to my songs, many of them don't show up.-   muffits
Dec 13, 2007
-   WE HAVE DOWNLOADED MP3 SONGS AND IT SAYS THEY HAVE BEEN DOWNLOADED WHICH YOU CAN TELL BY THE LOWER MB'S THAT HAVE BEEN USED, BUT WHEN WE GO TO PLAY THEM THEY ARE NOT THERE; SAYS NO FILE-   Guest
Solution #1
posted on Jun 07, 2006
Helpful)
soldierruel
Rank: Wiz
Rating: 75%, 872 votes
Check the format of your playlist it might not be supported.
Was this helpful?
Yes
No
Solution #2
Helpful)
bmwrider
Rank: Wiz
Rating: 84%, 1891 votes
Check the bitrate of the songs which didn't make it. If they are too low they are ignored. Also some machines won't tolerate VBR MP3s (variable bitrate)
Downloading songs off the Internet can be the cause of this problem. Not all people converting music to MP3s for the Internet use the same specifications. In future keep an eye on the bitrates of the music. Many people use lower rates so they can fit more on their computers but the portable players don't always like them.
BMW
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
Jughead
Rank: Apprentice
Rating: 79%, 21 votes
There are MP3s and then there are MP3s. Some are VBR (variable bitrate) then there are MP3s recorded at a high bitrate and MP3s recorded at a low bitrate. Some players don't like Low bitrate MP3s and a few don't like Very high MP3s. All you have to do is check your manual and find out what the manufacturer recommends as the optimum bit rate and make sure the one's you're loading fall into that recommendation.
Maybe it's a problem with DRM or Digital Rights Management which is a system designed to stop people from doing exactly what you're doing, copying copyrighted music. As I'm not here to encourage piracy you'll have to search the Net yourself to find out how to bypass it.
If you're using the software that came with the unit why not just drag and drop the MP3s into your player? Creative software is rather hard to handle unless you're savvy with mp3S
BMW
Was this helpful?
Yes
No
Solution #4
posted on Jun 02, 2008
Somewhat Helpful)
Sun Sun
Rank: Apprentice
Rating: 70%, 1 votes
If you downloaded the songs using the wrong format which can be changed in your settings, the music you have downloaded is going into the wrong place. The files that you transfer to the MP3 are messing with your V-TOC and if thats the case, then you need to use Windows Explorer and transfer your music to your computer and place the songs into a folder. After you have finished transferring them, you need to go to settings and reset your MP3. Once it has been reset, transfer the songs back over to the MP3. Note: Not all the songs are going to transfer back over because when you were putting music on it in the wrong format, it corrupted files and they may not all be recovered.
Was this helpful?
Yes
No
Solution #5
posted on Jun 03, 2008
Not Rated)
reoxoiw
Rank: Apprentice
Rating: 0%, 0 votes
You can from bestshareware.net choose Audio products to solve your question.
Was this helpful?
Yes
No
Solution #6
posted on May 23, 2008
Not Rated)
iannn
Rank: Apprentice
Rating: 0%, 0 votes
I noticed that some songs wouldn't go to my mp3 player randomly. I found that the player would not accept two songs with the same name. For example "track 10". I use itunes. Most of my music is from burned cd's so there are no track names, just tons of "track 10" and other numbers. So i rename them so the player will take them all as different.
Was this helpful?
Yes
No
Solution #7
posted on Mar 26, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i solved this problem that i found that some of downloaded folders have system atribute and it didnt show that foder in mp3 player...u can change it for example in total commander
Solution #8
posted on Feb 14, 2007
Not Rated)
tasseldad
Rank: Apprentice
Rating: 0%, 0 votes
The files need to be added to the MP3 directory on the MP3 player, not the root. The player won't see them unless they are in the MP3 directory regardless of actual file type.
Was this helpful?
Yes
No
Popular Solutions for Creative Labs Zen Nano Plus
Questions and Unsolved Problems for Creative Labs Zen Nano Plus
Do you recommend Creative Labs Zen Nano Plus MP3 Player?
Answer
Answer
my nano says it has no music on it, and when i try to download music on it, It says not enough space
Answer
My Zen Nano is stuck in playing contents of a folder in alphabetical order. I push NORMAL in the... (More)
Answer
I downloaded a couple of audiobooks onto my player and it shows no recording when I go to play them... (More)
Answer
I delete songs but it does not free up space on the zen nano
Answer
tried to record and now can't seem to find my other music on the device. can find when attached to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Creative Labs Zen Nano Plus...:
Top MP3 and Digital Med... Experts
Rank: Guru Guru
Solutions: 450
Experience: By using this stuff I know what I know when I know, but sometimes don't know how I know you know??
Ask Me
Find more MP3 and Digital Med... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
