Question about Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player
Pioneer deh-2800 I hope you can help me i have this deck but iam getting no audio. All my wiring is right my deck turns on and puts bass threw my sub. I just get no audio at all please help
I can't figure out how to set the clock it isn't even in the manual
Posted on Nov 03, 2008
I Have A Pioneer DEH-P6100R and i would like to know how to tune the radio as i havent got a manual... everytime i try and tune the radio theres like a fuzzy sound being made... could you tell me how to go...
Now if you mean tune as in the EQ well they all work about the same way and pioneers EQ's are the best. As for the nosie from experence it's either going to be the outlet in the deck or your speakers. Use the Audio button then go through the list and make adjustments to ur liking. I always like to recomend when you get to the low- mid - and high setting I always put low to the most negitive setting because it takes all the extra unwanted bass out of the component speakers and keeps it in your subs. Good luck and take care
Mar 19, 2011 | Pioneer DEH-P77DH CD Player
I am putting an external amp to run my subs and i need to know where to hook my remote wire to from the back of the deck
Norrmally the head unit/deck has a blue wire for the remote in the Pioneer set. So check this out and use a meter to see for voltage when the head set is switched on. Now you can connecct this as the remote swiching required for your amplifier. hope you look into the back side of the head unit ,in the cluster wire from the connectors. Good day
Aug 15, 2010 | Pioneer DEH-1500 CD Player
Pioneer DEH-P680MP Deck won't power on
not positive but i would have to say you prob have a lose wire if all your fuses are good, make sure you checked all the fuses the box in the car and under the hood, Run through all the wireing and check sometimes you need to put your acc wire with your power so blue an yellow, blue is remote yellow is power if you need to hope you have some luck
Nov 10, 2009 | Pioneer DEH-P680MP CD Player
What is the orange wire for on the pioneer DEH-2800MP?
If you have a blue with white on it or a solid blue lead, I'm at a loss, however the manual even states that colors may change w/o notice. Best way to tell is to use a meter, black probe to ground and red probe to the orange. Put it on DC voltage then turn the ignition to acc. then turn on the deck, my hunch is that it's your amp remote turn on wire for an external amp or it can be used for a power antenna. Voltage should be 12.2-13.8dcv. Hope this helps
Jun 23, 2009 | Pioneer DEH-2800MP CD Player
Wire colours for my pioneer deh 2300
here are the wiring for the deck and the car:
Deck:
12v - red
ignition: yellow
blk - ground
orange - dimmer
white - frt left +
white /blk - frt left -
gray - frt right +
gray /blk - frt right -
green - left rear +
green /blk - left rear _
Purple - right rear +
Purple w/blk right rear -
Car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 02, 2009 | Pioneer DEH-P4100
2v preouts from deck want to make them higher voltage for amp
You can get a line driver, it will add the volts you need and they are adjustable, Audio Control has some nice stuff.
May 31, 2009 | Pioneer DEH-P760MP CD Player
I cant get my subwoofer system to work
Do you use a amplifier to power the subs? If so, the amp needs a signal to turn on. This is supplied by the blue/white wire labeled 'system remote' in pioneer radio's.
Search for the next term on this site for more information about this wire:
Remote turn-on in car amplifiers is obligatory?
Sep 13, 2008 | Pioneer DEH-P4100
WEARD DECK PROBLEM
Replace your RCA cables. You may have a short ie screwed into it during wrap-up.
Jul 22, 2008 | Pioneer DEH-P6900UB CD Player
Prot. light at High vol. (forget Bass CD)
You may have the speakers wired for the wrong impedance.
How many ohms per voice coil?
How many voice coils per speaker?
If the speakers are DVC, are the coils of each speaker wired in series or parallel?
Are the speakers bridged on the amp or one per channel?
Jul 06, 2008 | Lanzar VIBE266 Car Audio Amplifier
BASS ADJUSTMENTS
What type of deck is it?
Mar 20, 2008 | Pioneer DEH-P6800MP CD Player
Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player Logo
144 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
