I turn on the set, it tries to turn on the lamp, but gives up after several attempts and several seconds. Finally it ends up with three blinking lights. This after I replaced color wheel. Already replaced lamp but with same result, so I,m thinking that I didn't get something back correctly during the color wheel swap. What could I have done during color wheel change that results in this condition? Seems unlikey that lamp or ballast coincidently went bad, as they worked fine before I did the color wheel.
  • 3 more comments
  • robc54 Oct 18, 2008
    samsung HLP5063
    jango's web instruction pre-date my model. I did use them as reference though. I thought I got everything back as it was, but now this problem. I'm looking for how this problem relates to the steps taken in replacement of color wheel, as I don't think I have another faulty component.
    What expert knows the relation between the color wheel replacement process and the failure to turn on the lamp / picture. I get sound and you can hear the set click as it attempts to start the lamp.
    findmeifucan -- I've tried switch in both positions, but same result. Are you saying that the ballast failed because I unplugged the tv to change the wheel? Are you ruling out an error in the color wheel changing process? Are the lamp and ballast ONLY possible causes? Just seems too coincidental that one of these would fail when color wheel replaced. I'm trying to save myself some money, not replace parts until I finally end up going to a repair shop.
    knowing the color wheel was the trigger for lamp was just the piece of info I needed. I removed the new color wheel and re-installed, making sure it seated properly and all the connections were in place. What do you know... worked like a charm, sound AND picture.
    P.S. if anyone's still following jango's process for color wheel replacement on later models, it will lead you to way more work than necessary. The first wheel replacement took me almost 2 hours. The second took me less than 15 minutes. I think Samsung learned how to make this component easier to get to. Thanks to all you who shared your knowledge, and jango too or I would not have had the confidence to undertake this. RobC
    Genius:
  • 2,035 Answers
If the lamp is working, most likely it’s another failed part. Ballast or color wheel, color wheel is new this could the problem with ballast in the tv.........
Posted on Oct 18, 2008
    Genius:
  • 1,030 Answers
Startup inmost dlp is dependent on the startup of the color wheel reaching speed. in most set the lamp doesnt fire until reaches speed. it just might be possible that your color wheel is faulty.. or as we called it at the shop "new defective" it "sounds" like other problems though. ussally the lamp will not strike until the wheel reaches speed.. also the lamp can still be at fault
  • 507 Answers
Sir,
it has something to do with the with the color wheel to replace it here's the instruction
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
if all else fails, you may try the service request
http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
    Genius:
  • 1,550 Answers
You need to provide brand and model number of your tv.
  • SAM ANDERSON Oct 18, 2008
    The ballast is the part that connects to the actual bulb. Samsung TV's
    ballasts seem to fail frequently due to power outages in the standard
    household.
    The 3 blinking lights can either be Bad Bulb or Bad Balast for the bulb.Open your lamp door and make sure the switch is in the down position,not the up position .
I have the WD-65731 DLP HDTV. The tv will not turn on. Initially, it will power up, and you can here the fan running. The green "timer" light will blink for several seconds. Finally the fan will...
Have you replaced the lamp?? You usually have to replace the lamps around every two to three years. The manufacturer has designed it so you the customer could change it yourself without a technicion. Hope this helps.
May 25, 2011 | Mitsubishi WD-65731 65" HDTV
Samsung MD# HLR-6167 When you turn on the TV it will be on for about 1hr then it turns itself off and the three lights are lit 2 green an the reds on the bottom. Upon trying to turn it back on, you can...
I guess no one has answered your question after 21 days. I wish I could, I have a similar but slightly different problem. Mine was slow to come on and made whining or whistling sound when first turned on or off. It sounds like incoming ordinance. It starts out high pitched and gets continually lower pitched. It took a while for the lamp to come on. I thought we had both a lamp going out and a color wheel issue. I replaced the lamp which made it a slightly brighter but not much else different. The next day it wouldn't come on at all. It cycled through several times for a few minutes and ended up with the three blinking lights. You turn it off and it does the same thing, neither turning off or on. I put the previous lamp back in and it made no difference. Since it has been 21 days for you I guess there is no response on this forum.
Jan 17, 2011 | Samsung HL-R6167W 61" HDTV
Just replaced the bulb with a brand new sony bulb. it takes me almost 20 minutes to get the tv to turn on..i turn it on it turns itself off and red light blinks, and i keep trying until it finally powers...
If red light blinks 3 times when tv refuse to power up then check lamp cover that was removed to replace lamp, make sure lamp cover is fixed in its position securely and screw is tight.
Let me know how many times red light is blinking after three second long pause IF it is not blinking 3 times.
Thanks.
Dec 30, 2010 | Sony KDF-50E2000 50" HDTV
The printer is not printing receipts and the error indicator is blinking on and off, what is the solution to this?
Flashing (approx. once every second): Out of paper
Flashing (approx. twice every second): Mechanical error (Buzzer sounds once.)
Most likely your paper feed is giving you the error. Remove the current feed, ensure there are no paper jam & insert fresh paper.
If
Mechanical Error :: Quick blinking Buzzer Sounds continuously for a pprox. 1 second :: Reset the Power
switch
Paper End Blinks.:: Buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Paper Near End Blinks.(Once a second) :: buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Mechanical Error : If the printer mechanism has a greater load due to a paper jam, etc., the buzzer will sound and the SEL/ERROR lamp will blink to stop the printer mechanism.
Paper End : If the printer has run out of paper, the paper sensor in the paper path near the print head will detect the end of the paper roll, turn on the buzzer, and blink the SEL/ERROR lamp to stop the printer mechanism. If the paper is inserted into the paper path, the paper will be loaded.
Paper Near End : If the paper is running out, the paper near end sensor will be activated to turn on
the buzzer and make the SEL/ERROR lamp blink. Even after the paper near end is detected, a command can be used to print by the specified number of lines. (See a description on the command for setting the number of print lines after paper near end detection)
Finally
Backup Data Clear : When the power is turned on, depending on the SEL switch operation, the
backup data in the input buffer will be cleared according to the flowchart on the next page.
To clear the input buffer, turn on the power while pressing the SEL switch.
The following messages will be printed.
"Clear Data in Buffer"
"Cleared Data in Buffer"
To print the data in the input buffer, simply turn the power on.
The following message is printed and the data in the input buffer is printed.
"Power Down(Data in Buffer)
Dec 13, 2010 | Citizen iDP-3550 Matrix Printer
Toshiba 52HM84 DLP TV with new bulb but the lights keep blinking
They exact way the lights blink are telling you what the failure is. If the tv is firing the lamp and the lamp is bad, you will hear a buzz sound for about 1 second. The tv tries 8 times before it gives up and spits out the lamp error. Check the user manual for led diagnostics. If you put in a new lamp but still have issues, you've likely got a bad ballast (most common on this model) or colorwheel (less common). Both are part of the optical block (light engine) and I don't believe they're available as individual components from toshiba.
Nov 28, 2008 | Toshiba 52HM95 52" HDTV Projection...
Reseting the lamp timer. Error message saying: 'Change Lamp' on Hitachi CP-5X 5600 projector. A new lamp has already been changed but we cannot get rid of the message which appears on the projected screen...
How do you reset the lamp hours counter?” and “How do you get into the service menu?” I don’t know if the service menu is a big secret or not, but since I’m not the first to publish this, I’m not going to lose any sleep over it.
For those inclined to get into service mode on DLP TVs, simply turn your system off, then use the remote and press the following buttons with about .5 to .75 seconds delay between presses: MUTE-1-8-2-POWER.
Once in the service menu, select the bottom item, Options, and from there you can reset the lamp counter.
I’ve never played with any of these settings. I’d strongly caution against any “curiosity tweaks” in there.
I think the most common cause of this problem is a faulty lamp. If you have replaced the lamp, or otherwise have reason to believe that it is not the lamp, it may be the ballast (the thing that starts up the lamp). You can purchase a ballast at a good price at partstore.com. (approx $140 vs. $180 at samsungparts.com)
Hope this may help;
Thanks for Jangro site source;
Sep 17, 2008 | Audio Players & Recorders
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Problems turning my tv on, need to try several times
I just recently had the same problem and finally my set would no longer turn on. I replaced the projector lamp and now my set works. However, when it first comes on, it only stays on for about 2 minutes and then goes off. After another minute, it comes back on and works fine from then on. I don't believe this double power up can be any good for the lamp, but I don't know if the problem is the lamp or the set. These lamps run on about 65 volts, but require a short blast from 5000 volt source to fire up. At $200.00 a lamp, I don't want to go buy another!
May 30, 2006 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
141 people viewed this question
Top Televison & Video Experts
