Question about Hitachi 43UWX10B 43" Rear Projection Television
Alignment I see 3 images of the picture with the 3 colors of the projection. I'm thinking its just some alignment issues but not sure, hoping that i just need replace a part other than dragging it out to a repair place. Thanks!
    President:
  • 3,130 Answers
Did you mess with the alighnments?? I doubt that just an alighnment will help as they do tend to drift but all three tubes dont go out of alighnment unless something happens to the circuit. If your a technician then sure you can replace the convergence ics but if your not its not like replacing spark plugs in your car. Electronic repair is a trained trade. Its not something we can teach you overnight or even in a month. Im sorry but If you are not a tech you should and its highly advised that you do take the set to a pro to have rthis problem fixed as theres very high voltage in these sets that can hurt you very badly.. Good Luck
Posted on Jun 06, 2006
Our Sony KP-46WT510 rear projection screen TV just
Convergence ICs, they are big black ICs will have part# on them if they are STK392-110s use 180s better ICs also CK pico fuses in front and behind ICs
they will look like resistors but will be Yellow or Green 5amps/6amp fuses
Mar 18, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Xerox Phaser 7300 color misregistration
Apparently, turning the unit off for 30 seconds, then back on will force the Phaser 7300 to do a color alignment procedure (according to Xerox support).
Then, if the problem persists, you are instructed to follow a very detailed troubleshooting procedure which I will leave with you in the following link:
Xerox Phaser 7300 Misregistration Issues
I hope this helps!
Mar 15, 2010 | Xerox Phaser 7300DN Laser Printer
Hitachi 43fwx20b magic focus the 3 colors are not adjust.
First have the convergence IC's replaced these are the two large black IC's mounted on an metal heat sink.
Oct 24, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Blurry and colors are seperated red green white
if you are viewing from a projection tv, chances are you have to go thru the menu of the tv to 'picture tuning'. here it gives you different things that could be fixed. one to look for is 'lamp alignment'. It should show all the colors and lines with directions to bring them into focus. This should fix the blurriness and 3-d red/green/white separations. hope this helps you!
Aug 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
I have a 3 year old mitsubishi wd-52526 lcd projector tv that is starting to have some focus/image alignment issues - in general picture is a little out of focus and there are rainbows around things at the...
the differnt guns are out of alignment. Your tv has 3 lcd screens, a red, green and blue one what overlay to form the image. Sometimes they move slightly for what ever reason and that causes the rainbow and out of focus picture. Its something that a trained pro should do but is a cheap fix and won't set you back too much
Oct 20, 2008 | Mitsubishi Televison & Video
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
3 images in different colors-42 in Sony projection
So this is a rear projection TV.
Chances are the tubes are out of alignment. When cleaning or anything never move the tubes as it will be hell to get em back properly.
In the back you can take off the rear panel and move the tubes to partially re-align the picture.
This is generally followed by a model specific procedure using the remote to bring up alignment grids to finalize the picture alignment.
The reason for the 3 colours in the picture are that the rear projection units use Red, Green and Blue tubes to create the one colour picture.
All in all... When I messed mine up it took about 2 hours to set it straight again.
Now I just have to fix my flashing screen problem and i'm set.
Feb 16, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Convergence
Color tubes are OK. Do not adjust. The issue at hand is called
convergence alignment.The repair involves-------
1)Pull chassis
2)Replace convergence IC's
3)Recheck alignment
work should be done by a skilled technician........T.
Oct 24, 2007 | Philips 60PP9202 60" Rear Projection...
Red, Blue And green put of alignment- see double on screen all 3 colors off
Your convergence amps are bad. Replacement is necessary and I would recommend contacting a servicer in your area. You can find an authorized JVC serivcer at this link http://maps.jvc.com/cAscList/
Jun 06, 2007 | JVC AV-56WP74 56" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
49 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
