Question about Toshiba Gigabeat F41 (40 GB) MP3 Player
Did he fry it?
Ok, my younger brother hooked his, Toshiba 40 gig gigabeat, MP3 player up with the wrong power supply. It's rated at 3 volts 2.2 amps.... the power supply he used was 5 volts 3 amps. Now it won't even turn on.... Did he "Fry" it?.... or is it possible that he just killed the battery not the hard drive? He is really stressing over this.... please let me know what you think.
  • Rick PereZ Jun 07, 2006
    Thanks for the replys.... I will check on this for him..
    Also where would you go to find an authorized repair shop?
Sana
Posted on Mar 25, 2008
  • 593 Answers
It didnt. The power supply that is supplied is probably a 5v anyway. the gigabeat and all other rechargeable batteries needs more than 3.3v to charge a 3.3v battery and the amperage doesnt affect the unit, itll only pull what it needs, as the charger needs to be rated more than the battery anyway as it keeps the power supply cool. Inversly if you tried to use a adapter rated at 500mw instead of 2000 (2.0A) it would overheat the power supply. Is the jack labeled as 5.0V? My Iriver is labeled 5V but the battery is a 3.3V. The gigabeat or device is smart enough to regulate the input voltage from its adapter, preventing overcharging.
Posted on Feb 18, 2008
  • 215 Answers
If you've used a power supply beyond the specifications of the units requirments I'd say you've definitely caused some major damage. If the unit incorporates a fusible link then perhaps that's all that needs replacing. If by chance the link survived then he's not only fried the unit he's char grilled it as well. There's a very good likelyhood that he may have reversed the polarity as well. Check the unit and somewhere near the dc socket or on the label it will tell you it's either centre pin positive or centre pin negative (it's easy to work out from the symbol) If the power supply differs from the player then once again he's either blown the fusible link or killed the unit. I'd suggest a quick visit to the repair shop. Because you'd probably never find the fusible link unless it's marked on the motherboard. BMW
Posted on Jun 07, 2006
  • 175 Answers
It just had a bad current that went through it the player shouldn't fry, check the battery voltage see if its still got the original voltage if not it will be under its capacity. Rejuvenate the battery and use the right power supply this time. If its still under warranty take the player and its original charger back to where you got the player from and they might swap it out.
4 Suggested Answers
SOURCE: system error 0000020
1.U need to reformat player first: see page 52 of owners manual(application software) 2.when formatting with gigabeat finished u need to restore of the firmware data see page 51 of the manual. Piece of cake,dude!
Posted on Aug 31, 2007
Lapoot
SOURCE: Toshiba Gigabeat F40 MP3 Player
My experience is that sometimes the battery swells up and puts pressure on the keypad, causing it scroll. Get a new battery and the scrolling stops....
Posted on Apr 18, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Driver files for Toshiba Gigabeat MES30VW
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 26, 2008
How do i clear the memory on the f40 toshiba gigabeat i cleared the songs out on my pc but the listings still remain on the gigabeat itself and keeps reading no file found
You have to clear the play list, until then the list will always appear in the player.
Have a nice time over there Does this not solve the problem, then try to return here
Please rate my answer
Jul 06, 2010 | Toshiba Gigabeat F40 40 GB MP3 Player
System error 00200060 NO SYSTEM FOUND ON HDD ona Toshiba MEGF40. I tried firmware upgrade, reformatting but not working hellp me
Okay, here's what you need to do. I'm assuming at some point yours like mine was formatted under windows. This is bad for them lol. Locate your copy of gigabeat room, and install it. This comes with a extra program in the start menu titled formatting utility for gigabeat. Format with this program, and then look under program files/toshiba/gigabeatroom/GBsystem. Copy GBsystem to the gigabeat, then turn the battery off with the switch on the bottom for thirty seconds. That should do it.
IMPORTANT NOTE!!!!!!!!!!!
This can only be done with a computer running USB 1.0. My newer computers could not "see" the gigabeat properly. I used an old machine with outdated USB to get mine to work again :) you can also check for aftermarket firmware called Rock Box, just installed that one mine, no more converting music to *.sat, it'll take straight mp3s now just like it should :) uploaded 20 gigs to it in less than half an hour :) beats the hell out of waiting ten hours for 8 gigs lol!
Jun 14, 2010 | Toshiba Gigabeat F40 40 GB MP3 Player
Needs software for Toshiba Gigabeat F40
Maybe you can find it on Toshiba site, the following link is download link include all aplicable to Gigabeat models:
Click here for Gigabeat F40 software
hope it help
regards
Apr 18, 2010 | Toshiba Gigabeat F40 40 GB MP3 Player
How do i convert mp3 music to wma.sat for my gigabeat f40? when i copy the mp3 files into the gigabeat player it cant be played..
You need a format converter to convert the mp3 to WMA. You can download a free format converter at the following website:
http://www.formatoz.com/
Good Luck, I hope this helped you Please rate me, Thanks
Dec 31, 2009 | Toshiba Gigabeat F40 40 GB MP3 Player
I need to reset the entire program on the f40. System settings and all
The EASY but Time consuming way (If you Only hagve USB 1), is to just RESET the unit.
The manual will run you through it, and reload.
I have both Gigabeat Room, and Win/Player 11, and have reset and reloaded a few times.
Just take some time (Specially with Gig Room)
Good Luck
Jun 13, 2008 | Toshiba Gigabeat F40 40 GB MP3 Player
Error 00100060
You might need the new driver call Toshiba Gigabeat support 1-877-250-8595
Oct 22, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Error number 00100060
Comment by MAHMOOD, posted on Oct 22, 2007 my younger brother plugged my megf20 gigabeat to pc and he formatted that using windows xp format disk utility now when i am turning on the gigabeat i just see an error and that is
no system found on hdd
error number is 00100060
if you can help me please
Toshiba Gigabeat F41 (40 GB) MP3 Player Logo
152 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
