Question about Dell 1700 Laser Printer
Dell 1700 laser. refilled toner, getting gray background
After I refilled my dell 1700 toner, the printouts have a gray shade.
- I verified that the drum is always covered with a toner. Then I used soft napkins to clean the drum.
- Still getting the same gray background. I think the problem was in the waste hopper located in the drum unit.
- I disassembled the drum unit and removed all the waste toner and cleaned tha blade.
-Reinstall toner and drum: same problem.
- I am told that I have to reset the "drum chip". I tried the proposed solution "door open + cancel button + flashing lights, not good"
-Does someone has another proposition?
Thanks
Check toner darkness settings using the setup utility.
Posted on Nov 03, 2008
Close door or replace cartridge message won't go away
Dell growing very fast in computer market because Dell provide best and affordable products to users but one thing is confronting by many users is that "Close door or replace cartridge message won't go away" that's why Dell experts provide a toll-free Dell Support Phone Number through which number every Dell user can easily connect with Dell experts and solve issue within a couple of minutes. Don't late to call because Dell experts provide first come first serve service so call anytime without any hesitation 24x7.
Jan 08, 2016 | Dell 5210n Laser Printer
PRINTER IS PRINTING OUT PAGES WITH DARK SMUDGES FROM ROLLER. DELL LASER PRINTER 1700.
toner spill on the paper path. this occurs mainly due to 0verfilled toner cartridges ( refills) use damp cloth or metho damped cloth to clean the rollers in the paper path.
Please rate my help++++Thanks for using FIXYA
May 20, 2010 | Dell 1700n Laser Printer
Dell 5110cn black toner
mag roller was jammed, forced a few rotations and it started to work
Feb 25, 2010 | Dell 5110cn Laser Printer
Ink on the edge of the page everytime we print a document.  we refill our toner, but have done so for years.  dell says that it is bc of the refilling and that it has filled up our drum??? any...
The Dell 1700 cartridge can leak from a failed mylar blade that sits against the Developer Roller.
The plastic locking ring on the and of the Developer roller spindle (of the toner cartridge) can come loose, or break (over time).
The drum unit has a relatively low capacity to hold waste toner, and all toner is not the same (waste toner shouldn't be re-used - it will just fill up the waste section of the drum even faster). Some toners are more efficient than others.
If you reset the 'replace drum' indication, without actually replacing it (or at least emptying it) you will soon have the drum over-full of waste toner, and the only other place it can go then, is inside the printer, and onto the paper.
Jun 23, 2009 | Dell 1700 Laser Printer
Flashing error and toner on Dell 1700 and will not print even after replacing drum and toner this happened before and I found on line sequence of pushing the buttons on printer to clear...but i can no
After replacing fysicalythe photoconductor/imagaging drum, leave the door open. Press and hold Cancel untl all lights flash in sequence to reset the printer. Close front cover.
May 28, 2009 | Dell 1700 Laser Printer
Paper turns gray
it is written in the Manual:
If the amount of background toner shading becomes unacceptable, the procedures described below may help to clear the condition:
* Increase the density setting. This will decrease the amount of background shading.
* Change the paper to a lighter basis weight.
* Check the printer's environment' very dry (ow humidity) conditions can increase the amount of background shading.
*Replace the toner cartridge.
*Replace the transfer roller
i hope it can help.
Regards,
sabeteh
Mar 28, 2009 | HP LaserJet 4 plus Printer
Is my Dell 1700 Laser Printer photoconductor drum truly fried?
The drum collects used toner for apprx. 30,000 pages. After that, the printer recommends that it be changed to prevent used toner from spilling internally into the printer's mechanisms. The whole photoconducter/drum can be replaced. The new part from Dell is apprx. $50.00 US.
http://accessories.us.dell.com/sna/products/Printer_Accessories/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=310-8710#Overview
You might have reset the "counter" for the photoconducter. Ever  have a water  fillter with an electronic timer? You replace the filter, then you reset the timer? Perhaps you reset the timer without actually replacing the filter. So to speak. :)
The question you should ask yourself is: would I like to spend $30 - $60 [it's cheaper for refurbished parts- Google it] replacing the drum head on a 7 year old printer, or would I rather invest that in a new printer?
Feb 23, 2009 | Dell 1700n Laser Printer
Dark background on Dell 1700 printing
Faulty (or wrongly) remanufactured cartridges can produce a 'background' to a print, which can be even across the page or have a mottled effect.
Do a printer self test page (press the arrow button).
put the old toner cartridge back in and do the same.
Does the background show with the old cartridge ?
If it does, its a drum unit problem, if not its a toner cartridge problem, and that should be under warranty if you've just replaced it.
Dec 06, 2008 | Dell 1700n Laser Printer
Refill toner in dell 1710
hi fireind
take out ur toner form your printer take the toner nearest printer ink refiller he will refill it he will chage for it $5 to 20$
Apr 08, 2008 | Dell 1710n Laser Printer
Printer prints documents with gray-shaded background
check the mode of printer is i grayscale or in colour mode. bye
Jan 30, 2007 | Dell 922 All-In-One InkJet Printer
Dell 1700 Laser Printer Logo
285 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
