Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
1991 fatboy harley
The clutch cable is very loose sometimes and the clutch wont work, This problem comes and goes.
  • 216 Answers
Theres a rubber boot on your clutch cable, under it is your cable adjuster. free up the jam nut then turn your adjuster , you should be able to see it tighten at the hand control. If you wanna do the whole job, you'll need to remove your derby cover on the primary. You'll be lookin at the clutch. In the center is a jam nut. Loosen it and then u can turn the adjusting screw clockwise till it stops. Then back it out 1/2-1 full turn. Tighten the jam nut.... take up the slack in the cable..... replace the boot,,,,TA DA!
Posted on Oct 18, 2008
1995 Harley fatboy has spark getting gas but still wont kick or start.
Hi, Dennis and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enrichner.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Fuel line to carburetor or throttle body pinched, kinked or blocked.
8. Carburetor float stuck.
9. Fuel injectors clogged.
10. Severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
11. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
12. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
13. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
14. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
15. Faulty neutral, clutch lever, or kickstand safety switch.
16. Faulty fuel pump or fuse or relay.
17. A stuck bent or burnt valve.
18. Tilt sensor needs a reset.
19. Security system not disarming alarm needs a reset.
20. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Fatboy Won Start Please help Harley Davidson Forums
http://www.carlsalter.com/pdfs/Harley%20Davidson-HD%201984-1998%20FLH-FLHT-FXR-FXSB-FXEF%20Service%20Manual.pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://www.harley-davidson.com/content/h-d/en_US/home/owners/maintain-your-bike/owners-manual.html
Instant Tech Relief A must have !!! Absolutely "FREE"
Jan 16, 2017 | Harley Davidson Motorcycles
1993 flstf clutch cable installation?
Hi Anonymous, for more information on your question please visit the websites below and good luck:
How to Remove the Clutch Cable on Harley Davidson Big Twin Motorcycle
Aug 02, 2012 | Harley Davidson FLSTF - FLSTFI Fat Boy...
Have no clutch pressure on a 1996 Harley davidson Fatboy
Make sure the ball and ramp was in the proper position after you replaced the clutch cable. It should have been to the rear of the trans cover.
Jul 30, 2012 | Harley Davidson Motorcycles
04 harley davidson fatboy is hard to shift into gears what could be the problem
Hi Anonymous, you definately need a clutch adjustment, for more information about your question please visit the websites below. Good luck and have nice day.
How To Properly Adjust The Clutch Clutch Cable Harley Davidson
May 16, 2012 | Harley Davidson Motorcycles
97 fatboy, goes in gear but wont move.
Hi Anonymous, you could have a clutch or transmission issue try a clutch adjustment first then call, take a ride or trailer your bike over to your local dealers service/parts department, I'm sure they will be happy to take your Harley Davidson for a test ride if necessary/possible and offer professional advice and assistance concerning your issue. Good luck have a nice day. How To Properly Adjust The Clutch Clutch Cable Harley Davidson
Apr 20, 2012 | Cars & Trucks
1996 fatboy just replaced broken drive belt goes into gear but wont move
Hi Glassforce8, you may need a proper clutch adjustment, for more information about your question please visit the websites below. Good luck and have nice day.
Mar 18, 2012 | Harley Davidson Motorcycles
Lands Phones Logo
236 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
