Question about SanDisk Sansa m250 MP3 Player
Mp3 vs mp4
I dragged files from my itunes and the player m250 will recognize and play mp3 but not mp4 which is most of my itunes files. It accepted the mp4 and shows on the computer but they do not show on the player itself. Any ideas?
  • 31 Answers
Hi Richards147,
Have you tried importing the file from your PC to the Sansa m250 directly rather than from iTunes?
You can also try converting your mp4 files from iTunes into mp3.
You will need to re-import your original files into mp3 format. You will need to change also your import settings to Mp3 encoder on iTunes. You can find this by choosing from the Menu bar of iTunes "Edit--->Preferences--->General---->Import Settings--->Import using : Mp3 encoder.
Regards.
Posted on Oct 21, 2008
SOURCE:
My MP3 won't download music
I was having this same problem, but the solution I came up with was forehead-slappingly simple. I merely put the files on my MP3 player manually, using drag-and-drop from the itunes music file folder (not from within the program) to the device storage folders.
I can\'t say if this will work for all MP3 players (ours is a Sony walkman), as they need to be able to play m4a files. But after trying a dozen ways to get WMP to recognize the m4a, and trying to get itunes to recognize the players (including trying 3rd party addons which would have had to completely erase the player to start with)... I just figured I\'d try just drag and drop and to my surprise, it worked perfectly, absolutely no problems. I\'m listening to my itunes-purchased music on the MP3 player right now.
Mar 12, 2014 | Audio Players & Recorders
Not able to download mp4 music files into my Ipod anymore
What happens when you try to transfer MP4's to your ipod? Are the MP4's recognized in itunes? If so, can it play them?
Dec 29, 2007 | Apple Ipod Nano Second Gen. Green (4 GB)...
Music from itunes will not play on the device
The Itune music files maybe in MP4 file format.
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player using the USB cable.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
May 02, 2012 | Nextar MA933A MP3 Player
What happens if my files are mp4
You will need to convert your mp4 files to mp3 for them to play in the Sansa M250. You can download a free converter at:
http://www.maniactools.com/soft/m4a-to-mp3-converter/index.shtml
Oct 19, 2010 | SanDisk Sansa m250 MP3 Player
Will my itunes music library play on my Garmin nuvi 760? I dragged and downloaded my itunes music library onto my nuvi 760. When I hooked it up this morning to use it in my car it kept saying it was...
Your Garmin only supports MP3 files and iTunes is all MP4. The Best way to convert them is with "Real Player sp" Which is probably on your computer already or downlaod it for free. Open the music library and right click on the centre. There you will see "Converter" Select convert to MP3. Don't open iTunes. Instead go through; Start, my music, iTunes, library. This way you can drag a whole album into the converter. Plug your Garmin in with the USB cable and go through; Start, my computer, storage device H. At the bottom of the converter you can select where to send the converted files. Select the device H. Now press start and let it do it's thing. When it's finished you can see the old files in MP4 format with the new files in MP3 format listed under. Drag and drop is only a copy. You can delete all these files after to keep it tidy. All the original stuff is still safe and you Garmin should now have music on it. Try it with a small tune first to test. Best of luck. Regards Chris4fingers
May 31, 2009 | Garmin Nuvi 760 Car GPS Receiver
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Songs deleted
this unit doesnt recognize ITUNE files, because ITUNES are MP4, you have to convert the audio files to MP3 first. Once they are converted, you can add to your Coby unit, here is a guide on how to convert in ITUNES:
http://www.wellesley.edu/Computing/Idocs/Itunes/convertMP3.html
Aug 21, 2008 | Coby MP-C7085 MP3 Player
ITunes Store .m4v videos do not play on iPod
you should change the .m4v file into mp4 with ipod video converter. ipod only accepts video in .mp4 format.
Aug 03, 2008 | Apple iPod MA446LL/A MP3 Player
My mp4 player (phillips) won't play certain songs that I have ripped from my vista
1) The file is not in a format recognized by the player - Philips only recognizes mp3 and wma files, so it will not play iTunes1.gif files, for instance
2) The file you are transferring has DRM encryption, and your player does not support DRM-encryption (or the reverse - the file does not have encryption, and needs to be encrypted)
BTW, most Philips players were not automatically created for Vista. You may need to download the Vista compatible version of the software at www.usasupport.philips.com, or you may run into problems with this player in the future.
-Tha Mp3 Doctor
Mar 08, 2008 | Audio Players & Recorders
Can not remove files from sansa
Windows Media Player is a little temperamental when it comes to music on the device.
You can manually manage the music from My Computer>Device Name (m250)>MUSIC Folder.
You can drag & drop files onto the device from here, as well as, right click and delete them.
Best of Luck.
Nov 19, 2007 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
110 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
