Question about Mitsubishi WD52527 52" Projection HDTV
Mitsubishi wd52527 yes it does blink for 1 minute and then pause for about 30 seconds and blinks again but still wont power on
  • ivery809 Oct 18, 2008
    where do i get this e2p board,whats the cost, and is it easy to replace?
    thank you
    Novelist:
    Champion:
  • 203 Answers
The most common thing to cause this problem is the E2P board. It will need to be replaced.
let me know what information you would like.
Thanks,
Tim
Posted on Oct 18, 2008
I have a WS-65907 tv, it wont turn on
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Oct 30, 2012 | Mitsubishi WS-65907 65" Rear Projection...
Error code 13 on mitsubishi wd52628
wait for the light to go out then press power. Then if it doesnt power up hold the menu and the Device/input buttons on the set both in together for 5 seconds the light will blink a series of blinks pause briefly then blink another number of blinks then pause then it will repeat the same two digit blink sequence a few times . Let me know the two digit blink sequence.
Aug 29, 2012 | Mitsubishi WD-52628 52" Projection HDTV
The timer light is blinking yet no power what does that mean
The model indicated if unplugged and plugged back should have the green light blink for about 70 seconds and then stop blinking and go out---set is booting up--if it does not ever stop blinking something in Digital area is bad--this was a common problem in these sets and is not a do it yourself repair.
Apr 30, 2012 | Mitsubishi WD52527 52" Projection HDTV
When I attempt to turn on the TV the green power light will stay on for about 2 seconds. Did system reset with paperclip, timer light flashed for 1 minute. Tried again with same result.
STANDARD ANSWER FOR THIS PROBLEM:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
BEFORE YOU RATE THIS INFORMATION LET ME KNOW WHAT YOU FIND, i AM HERE TOP HELP.
SD TECH
Jul 15, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Turned off and power light blinks
Please let me know if the blinks separated with a pause, if so first blinks is denoting the first digit then pause blinks again denoting the second digit. Example, if the error code is "22" the unit will blinks two times pause blinks 2 times and will repeat the error code. It will help to determine where the fault came from.
Jdvillanueva
Jun 24, 2011 | Mitsubishi WT-46809 46" Rear Projection...
My 65 in mitsubishi medallion hdtv 1080 wont turn
Jun 07, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I have a Mitsubishi WD-52725 and the timer light continues to blink and I cannot reset it. What can i do to fix this.
1. Timer LED does not stop blinking; suspect the DM PCB part # 934C152001-V28++ 2. Timer LED blinks 70 seconds, pauses then starts blinking again, suspect the E2P PCB part # 935D820001-V28+ 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition.
Feb 17, 2011 | Mitsubishi Televison & Video
Mitsubishi WS-55909 dm board repair
The DM is fine if the led isnt blinking. Your set is going into protective shutdown. Try pressing the menu and the device/input buttons on the set both in together for 5 seconds to see if the set will blink a series of blinks pause then blink another series of blinks. Such as 2 blinks pause then 2 blinks, Then let me know what the blinks were and I will assist you with whats wrong
May 28, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi wd52527
does the light flash for 1 min then pause for a second then blink for another min?
Oct 18, 2008 | Mitsubishi WD52527 52" Projection HDTV
Mitsubishi WD52527 Timer LED FLashing Rapidly
This could be bad caps on the "DM" board. To confirm this though, can you count the blinks please and post here?
Thanks,
Dan
Jun 06, 2008 | Mitsubishi WD52527 52" Projection HDTV
Mitsubishi WD52527 52" Projection HDTV Logo
101 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
