Cameras Logo
Posted on Oct 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
OK I had 188 pictures on my norcent camera and I was looking through them yesterday and when I got back to the main menu all of them was gone and I know I didn't delete them.
CameraR
Level 3:
  • Cameras Master 4,738 Answers
  • Posted on Oct 19, 2008
CameraR
Cameras Master
Level 3:
Answers
4738
Questions
Helped
1195961
Points
12483
Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
You will need to use a flash card reader with this software. If you don't have one, get one, they're cheap:
http://www.amazon.com/s/ref=sr_st?keywords=card+reader&rs=172282&page=1&rh=n%3A172282%2Ck%3Acard+reader&sort=price
No picture on Norcent LT-2790 bk
There are two possibilities for this fault. The first one is with it deflection yoke connection. If this connection have any loose contact at main board side, horizontal sweep pulses will be absent to deflection yoke. Check this plug in connection first. If it is OK, check and replace the CRT connection socket.
1helpful
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Green and blue stripes in the picture
turn tv on, press the menu button.
look at picture if the lines are in front of the menu problems most likly the display ,if the lines are behind the menu its the vido module
hope this helps
Switch to memory card?
click on review and press menu (make sure menu is not pressed before review because the menu under review and main menu are different things)
when the review menu comes up, scroll down and look for IMAGE STORAGE, select that and choose AUTO> continue> ok
Pentax Optio WPi lost program mode
It is 12 years old - replacement will be far more cost-effective than service or repair.
How to delete pics from camera
Hi there. I can help you with that.
Press the menu button. Scroll down in the menu by pressing the direction button down and find Erase All, then press the Set button. You should see a confirmation screen. Select Ok by pressing the direction button Left. Then press the Set button again.
They will be gone from the camera's internal memory.
That will fix you. If you have any further questions please respond in a comment. If you like my answer feel free to rate it a fixya.
Thanks for coming to FixYa.
Rob
4helpful
3answers
I have a sony cyber shot dsc-n1 how do I delete all the pictures
Here's a little more detail... connect the camera to your computer; turn your camera on; switch cable connection to "camera"; in the pop up box select "Copy pix to a ... using Micro Scan & Camera Wizard" and press "OK"; in the next box select "advance users only"; Double click the "DCIM" file; double click the next file; and if you want all the pix gone select the first photo press "Shift" then select the last photo; right click either photo; then press delete. All gone.... Hope this helps.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
