Question about Mitsubishi VS-45607 45" Rear Projection Television
Turns off every so often
My TV will work for hours some days, others not. It will go off and when you try to turn it back on, the green light comes on, but goes right back off, like it has to cool down, reset or something before it can be turned back on. At first it just went off, but now there are red and green lines that appear as it is going off and it is happening more frequently than it used to. Is it time for a new TV or can this one be fixed?
  • 4 more comments
  • 867tmp Feb 15, 2008
    had power outage and knwo when you turn power on green light comes on for a second and then shuts off.
  • BILL SMITH Sep 09, 2008
    THE GREEN LIGHT ON MY 56' BLACK DIAMOND EDITION MITS. BLINKS AND WONT GO OFF I LOOKED IN THE MANUAL AND IT SAYS SOMETHING ABOUT LOW POWER HOW DO I GET THIS TO TURN OFF SO I CAN TURN ON THE TV ITS BEEN BLINKING FOR 2 DAYS EVEN IF UNPLUG IT OR HIT THE RESET BUTTON
    SORRY ABOUT THE CAPS [SEE HOW MY WEEKS BEEN]
  • jack_ellingh Sep 23, 2008
    Same thing runs for hours then shuts off . Wont stay on until it "cools down" maybe .
    The repair shop doesnt know whats wrong
  • Anonymous Oct 21, 2008
    same thing is happening to me
  • lanellezaval Nov 23, 2008
    i have the exact problem
  • Anonymous Dec 20, 2008
    I have a used Mits VS-45607 without a remote or manual it has a great picture but it also shuts itself off. Sometimes in a matter of minutes sometimes in a half hour. The green light is on, does that mean its a timer issue?
    President:
  • 3,130 Answers
This symptom seems to be a vertical Sweep fault cause what happens is theres a protection circuit in this set that activates when it sees theres no verticle sweep, it shuts off the picture on the set so that the tubes dont get lines burnt in the middle and become damaged. If you know your way around a TV set then you could locate the vertical output IC and resolder all its pins first as well as anything else in that circuit that looks like a cold solder connection. Then i9f it still does the same thing I would just replace the verticle output IC as well as the B+ supply capacitor off the flyback xformer for the sweep dirived power supply. Now if your not knowlegeable about these HI VOLTAGE circuits my advice would be do not attempt the repair yourself as you could get hurt and /or cause more problems with the set as there are no tubes in this set to test except the picture tubes. Contact Mits. at this #800-332-2119 or look in your owners manual for a contact #. Good Luck.
Posted on Jun 07, 2006
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
TV turns on then off no picture
this is very common. it is the power supply going bad. it should run at 130 volts dc. but it is now running much lower that this. just enought for the tv to come on. but not enough to power all the circuits right.
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green power light comes on, the turns right back off. No picture. Please help
I'm not sure what TV model you have. But, thing I can tell you is the most common problem.
Most of the time with flat panel TVs, the power supply for the screen fails. And the TV normally turns itself off to protect other parts in the TV from being damaged. Basically " Protection Mode".
You can try leaving the TV unplugged for 30 minutes so the TV can reset itself; then try again turning it on. If it doesn't work after that, it's time for the TV repair shop.
May 21, 2009 | Sanyo Televison & Video
Mitsubishi WD-62827---PICTURE TURNS GREEN
I had the same problem. I deducted that if my TV worked fine for an hour or so and then the colors became bad (green, people's faces purple...), it must be a overheating problem. Simple logic, right? So, I picked up a few tools and a small vaccum and went to work.
I went first for the main source of heat: The lamp. Just a few screws, and I removed it. The lamp cage has a fine screen to prevent the dust to cover the lamp. Mine was covered with dust! And the fan behind the lamp was also covered with dust! Bingo!!! That's my problem! I cleaned everything and vaccumed all the air vents on the the back of the TV. I put the lamp back and checked that the fan was working. The TV works like new since!
Before you are out of a TV for days and spend an arm and a leg for a "Technician" to fix it (replacing expensive parts that didn't need to be replaced in the first place), try what I described above first. It's very simple and it takes only 15 minutes.
Since my TV is 2 1/2 years old, I purchased a replacement lamp. I know that one of these days it will burn out. I'll be ready and my TV will be working again in 15 minutes!
Since my problem was solved, I didn't go to the next step. There must be one or two other cooling fans inside the TV, but they must be working...
Good luck,
alecoz@roadrunner.com
Oct 06, 2008 | Mitsubishi WD-62827 62" Television
No pic
alright guys...blew a bulb....fixed that. still didint work...found out it was ballast...replaced that. tv worked for a month..all the sudden hdmi input didint work id plug in my playstation and screen would turn green and say "hdmi color has been corrupted" im thinking wtf? so a week later it works fine then just turns off in middle of watching espn... comes back on an hour later...only to turn off again...it just turns black for ten seconds then just turns off and the red and green lights blink at intervals of one second....replaced a bulb..not that, same problems.......when the tv comes on for the ten minutes before it quits working the pic and sound are great i just dnt get it...is it shorting out? color wheel bad? a fan?
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
May 16, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
Well guys I found that if one just reads the manual you may find the solution...Mine seemed pretty simple - the room temperature was too warm! I adjusted the heat in the house, the yellow Status light went off and...it works again!
Thanks
ndre
Dec 23, 2007 | Televison & Video
If this is a sony or mits it may be the subject of a thermal cutoff service bulletin. (I don't recall which)They have extended the factory warranty on these to cover this problem.
Dale
Dec 22, 2007 | Televison & Video
Tv wont turn on
stephster, check to see if you have a reset button on the back of tv good luck-hope this works for you
Nov 05, 2007 | Panasonic CT-36HL43 36" TV
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi VS-45607 45" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
