Question about Protron PLTV-32 Television
No HD My built in tuner for HD dose not pick up the signal on the DTV setting every thing is set and hooked up correctly still dose not work? Can any one Help me with this or is the built in ant. defective? I have cable and my digital tuner does not work. There is two inputs one for cable/ant, the other digital. The digital does not work I can not pick up any kind of signal.
  • Anonymous Dec 21, 2008
    Exactly the same problem.
  • 899 Answers
The digital tuner needs to be checked for soldering connections and if that don't fix it then you will need to get a new digital tuner.put in. but you can unplug the tv from the wall plug for a little while and that may help but if not then it will need to be checked for bad soldering or it will need to be replaced
Posted on Oct 18, 2008
I cant get a singal for my antnna
Tv does work for HD but must have cable or satellite tv signal.Yes,this tv able to play HD signal,but it is a CRT-(tube tv) design was built before the DTV switch over and never added the DTV tuner in it board circuitries.Sorry antena free DTV this tv must have to added the converter box to get the DTV free air signal.
Feb 17, 2011 | RCA P61310 TV
Why won't my new Vizio DTV work on an antenna without the digital box?
Do you have the antenna aimed correctly and the correct antenna for the distance between your location and the stations? Check antennaweb.org and tvfool.com for the directions to the stations you should be able to receive. Antennaweb assumes an external antenna and is very conservative in the station list. TVfool gives the stations you should get with various different types of antennas. Tall trees and buildings will block signal strength so consider the environment around you.
With digital signals, if you do not have enough signal strength for a given tuner, the channel will not come in. An amplifier may help you get the signal, particularly if the signal is shared to several devices. Failure of an amplifier or lightning surge protection can stop the signal from reaching the TV. A surge through the antenna can damage the tuner.
A damaged cable can also be a source of a problem. Check the outside portion of the wire as well as the interior wires. Replace any that have damaged insulation or ends.
For this TV, if you have done a channel scan with the TV set to the Input TV/DTV, and the Signal Source set to Antenna. Turn the antenna and then set the Additional Scan to On. (Menu > TV > Channels > Additional Scan.) Then do another channel scan.
If you need a copy of the manual, see: http://www.vizio.com/m220va.html#support .
Jan 22, 2011 | Vizio M220VA 22 in. LCD HDTV
Dose my tv (Hisense TL3000) is hd-tv ready
Not all units were fitted with the DTV tuner before the switch over occurred. you set should have an insignia that sates that it is DTV ready. if this insignia is not on the box or actual set, you will need a converter box to receive this DTV signal.
Jun 21, 2009 | Hisense TL3000 30 in. HD-Ready LCD...
Built in tuner not working since digital transition
I do not know if you will get this message but if you do. Here goes. The protron PLTV3250 does indeed have a digital tuner that can be used with an over the air antenna. You need to push "source" on the remote until DTV is selected. With this selected and your coaxial cable from your antenna hooked up to the digital connector (not analog) on the back of this tv you can then press Menu and you will see a totally different looking menu that you are probably not used to seeing and then from there you can do an auto scan for the digital channels and it works great. I have rabbit ears hooked up to this Protron PLTV3250 and this has a beautiful picture. Far better than the picture I get from just the standard digital Directv receiver. You do not need a seperate digital tuner box to use with this TV. It does indeed have an ATSC digital tuner and it works great. You probably are selecting Source "TV" in the menu and that is not what you select for this TV to use the Digital Tuner. You need to select DTV from the source menu. Good luck and please let me know if you already knew this or if this helped you. Thanks, Tom
May 27, 2009 | Protron PLTV3250 32 in. LCD Television
Dtv ready?
Going to the following link will help you to find out if your television is DTV ready or not:
http://www.dtvtransition.org/index.php?option=com_content&task=view&id=51&Itemid=94
Using their online tool, select the Brand (Akai) and the Model from the list. If you cannot find your model in the list (which I was not able to for your television), they are saying that you most likely do not have a digital tuner.
All is not lost, however. As stated on the aforementioned site, you can consider one of the following options:
  • Purchase a digital-to-analog converter box that plugs into an existing television. The boxes, which are expected to cost between $40 - 70 will be available for purchase in 2008. Beginning in February 2008, U.S. households can request up to two coupons valued at $40 each. Each coupon can go toward the purchase of a single set-top converter box that will allow you to continue watching FREE "over-the-air" television on an analog set.
  • Subscribe to a cable, satellite or telecommunications service provider if all desired local broadcast stations are carried by that service.
  • Purchase a new television set with a built in digital tuner.
    Listed on the page is further information that may help you to determine the status of your TV:
  • Consult your owner's manual. If that's not possible, you may be able to look up information about your TV set on the manufacturer's website. Or, you can take an up-close look at your TV set. You are trying to find out if your set has an input connection labeled "digital input" or "ATSC" (for Advanced Television Systems Committee, which is developing the DTV format).
  • If you bought your TV set before 1998, it probably doesn't have a digital tuner at all. Almost every TV set made before 1998 was a traditional "analog" set that can't display digital TV signals without either a special converter or a cable TV connection. If you bought a big-screen, projection TV between 1998 and 2004, it's possible there's a built-in digital tuner inside. But chances aren't great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
  • If you've purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores have featured digital tuners that will let you receive the new digital over-the-air broadcasts starting in February 2009. But be wary: It's not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as "HD-ready" or "HDTV monitor" sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You'll still need a special converter or a cable TV connection.
  • Jan 12, 2009 | Akai PT5492S 54" Rear Projection...
    Tv Tuners
    Hey jp62388,
    According to information provided by the manufacturer, this model TV should have a built-in NTSC/ATSC and QAM tuner. These should allow you to receive locally broadcast digital TV signals without the use of a set-top box or digital converter box.
    If you're concerned about your TV's specifications, the most important thing you'll need to look for is a built-in or integrated ATSC tuner. NTSC is the old analog standard that is to be phased out in early 2009, while ATSC is the new digital standard that is to be used within the United States and Canada as NTSC’s replacement.
    Should you have any other questions or concerns, I'd strongly suggest checking out the FAQ section of the federal government’s official DTV transition website:
    http://www.dtv.gov/index.html
    Hope this helps you out.
    Sincerely,
    Aaron
    Go Ahead. Use Us.
    Jul 03, 2008 | Televison & Video
    DTV
    The TV you have was made prior to the DTV standard, so it will not have that capability built in.
    However there are two easy fixes.
    1) If you have cable such as Comcast, they will automatically start providing the Digital signal conversion inside the cable box for you so you will be fine. I believe the satellite providers will also be offering this feature.
    2) If you watch TV from an antenna, then you can purchase a set-top converter for like $40 and request a coupon from the government that covers most if not all of that cost. You will want to check on the coupon first, because I believe you need that when you purchase the converter.
    Either way, you should be able to watch DTV just fine without buying a new TV or other similar big expense.
    Jun 23, 2008 | Hitachi 43UWX10B 43" Rear Projection...
    Is my tv digital compatible or not
    https://www.dtv2009.gov/FAQ.aspx What you need to know is whether your TV set has something called a “digital tuner” already built in. If it does, your TV set will work after February 17, 2009. The best way to determine whether your TV set has a digital tuner built in is to consult your owner’s manual. If that’s not possible, you may be able to look up information about your TV set on the manufacturer’s website. Or, you can take an up-close look at your TV set. In any case, you’re trying to find out if your set has an input connection labeled “digital input” or “ATSC” (for Advanced Television Systems Committee, which is the DTV format).
    Here are some general guidelines that may help:
    TV set made before 1998 was a traditional “analog” set. If you bought a big-screen, projection TV between 1998 and 2004, it may have a built-in digital tuner inside. But chances aren’t great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
    If you purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores feature digital tuners that will work after February 17, 2009. But it’s not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as “HD-ready” or “HDTV monitor” sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You’ll still need a special converter or a cable TV connection. Hope this info above helps. Also, check your manual, and if you don't have it some manufacturers, (Philips does for some models) offer the manual on their websites.
    Apr 07, 2008 | Philips TV Tuner Video Capture PCI Card -...
    No HD
    Your TV has a built in tuner but NOT a built in antenna. Depending on where you live (distance from broadcasters) you will need to add anywhere from rabbit ears (with the UHF loop) to an antenna on the roof or mast.
    If your home already has an antenna installed, connect the coaxial cable to the back of your TV. Then go to "Set-up" and scan for DIGITAL channels. If you are trying rabbit ears, do the same.
    Mar 15, 2008 | Protron PLTV-4250 42 in. LCD Television
    Philips CCB130AT02 TV/VCR combo
    Is this an Analog TV? Does it have a picture tube and not an LCD or plasma screen? Most likely this is a Analog TV.
    If it is an Analog TV (and I would bet that it is), then no, it does not have a digital (QAM) tuner to pick up DTV broadcasts. The fact that it has a VCR also indicates that its an Analog TV.
    If you are picking up your TV signals from an outside antenna and not cable, then yes, you will need a converter box to convert the new digital signals to Analog so that you can continue to use your TV set.
    If you are using cable to receive your channels, the cable company already provides the conversion for you and your TV will continue to work as before.
    The government is giving out coupons to help consumers defray the costs of purchaing a converter box. The following sites are good places to obtain more information.
    www.ntia.doc.gov/dtvcoupon
    www.DTVanswers.com
    - Jim
    Feb 06, 2008 | Televison & Video
    Protron PLTV-32 Television Logo
    127 people viewed this question
    Top Protron Televison & Video Experts
    Jaime Hernandez
    Dave Naylor
    Dave Naylor
    Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
