Question about Samsung RS105N Remote Control
Samsung TV stops responding to remote
Our Samsung HL-R6178W DLP TV stops responding to the Samsung remote after we have used our Onkyo remote to adjust the Onkyo receiver. The TV will only start working again after it has sat on or off for 20 or 30 minutes without using any remotes. Then it goes back to working normally. We also have a Yahama receiver and it's remote causes the same problem with the TV. Our DVD players remote does not seem to cause the same problem.
SOURCE: Samsung TV remote control
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Posted on Jan 26, 2008
  • 547 Answers
SOURCE: Code for lite on dvd player
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Posted on Feb 12, 2009
  • 6 Answers
SOURCE: want to use samsung remote to control fios box and tv
You can use your own SAMSUNG remote but some of the guide options and dvr buttons may not come across.  If your remote allows you to 'map' the buttons you could circumvent the issue.
Another suggestion would be the universal remote by harmony.  great gadget.  pricey though.
Posted on Apr 28, 2009
  • 226 Answers
SOURCE: Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
SOURCE: We have an AK59-00104R remote
To program this Samsung remote to work with a TV, press the TV POWER button on the remote while entering a manufacturer specific code into the remote at the same time.
1. Switch the TV on. 2. Point the remote towards the TV. 3. Press and hold the TV Power button and enter the two-digit code for that brand of TV. If the code is compatible, the TV will switch off. 4. There may be more than one code for that manufacturer, so try them all until one works.
For Samsung TVs, one of the following codes should work: +01 +02 +03 +04 +05 +06 +07 +08 +09
Posted on Jan 29, 2011
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Samsung hl-s6767w timer reset. Can I reset using the menu option located on the tv. I have no factory remote
Yes, you just have to toggle manually using the plus and minus key as well as the channel up and down keys to navigate the menu
Nov 17, 2013 | Samsung HL-S6767W DLP TV
High pitch noise flashing colors Model: HL-R6178W
Most likely cause is the color wheel needing replacement.
Mar 20, 2011 | Samsung HL-R6164W TV
I have a samsung hl-r6178w, it suddenly turned off & the 3 lights in the front started blinking & it would not turn back on. i replaced the lamp now & still nothing, what can i do?
In regards to your issue, I got a question for you: when your tv2.gif turns on or tries to turn on, do you or can you hear a humming, buzzing or rapid click noise coming out of the tv? if you say yes this could be an issue with the ballast and most likely needs to be replaced as soon as possible the definition of a ballast and how it works is this: A ballast is an electrical component used with a fluorescent bulb (or mercury vapor lamp or arc lamp) to conduct electricity at each end of the tube. It supplies the initial electricity to the bulb that creates light, and then it regulates the amount of electricity flowing through the bulb so that it emits the right amount of light
You can go to DM the have this parts and you can get a good price,
please keep us posted
good luck
Oct 01, 2009 | Samsung HL-S5087W DLP TV
Samsung hl-r6178w 3 blinking lights
The power board ic converter is dead.
U can tries to go to the web buy the part and replace it yourself.Or hire the repair man part and labor $575
Aug 13, 2009 | Samsung HL-S5087W DLP TV
Remote Code Samsung 50" DLP HL-R5067W
022 036 043 159 160 170 175 212 215 702 713 706
Dec 14, 2008 | Samsung 50" Slim-Depth DLP HDTV
Remote stopped working after color wheel replaced
See , that seems to address the same problem.
Aug 26, 2008 | Samsung DLP HL-P5663W 56" TV
Dlp tv problem
Is the lamp light the only one thats flashing? Does the buzzing your hearing stop or is it constant? Also when you press power off does the buzzing stop instantly or continue? Respond to this post and I will try to assist you. Is HL-R677w the correct model number also?
Jun 21, 2008 | Samsung HL-R5677W 56" HDTV
Intermitten remote sensor issue
Evidently 2 good remotes point at the problem being the remote sensor on the TV itself. I have about 4 remotes I can adjust volume w/ including the remote that came w/ my samsung. The TV exhibits the same behavior w/ all of them.
Per the samsung site, the "test" for this (remote vs sensor) is to us a digital camera, (including the kind that's on most cell phones) to "see" if the remote lights up. Just point it at the camera/phone, and press any button. You should see a bright flashing light on the camera/phone's LCD screen. If not, REJOICE! All you need to replace is the remote or batteries in it. If you do see the light, good luck if you're not in warranty. I've been unable to find any procedures for replacing this kind of item.
Nov 13, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung RS105N Remote Control Logo
90 people viewed this question
Jerry Greenberg
Jerry Greenberg
