Question about GE Profile WPSR3120WWW
Washer Leak on GE Profile WPSR3120
On the fill cycle leaking water out of the bottom of the washing machine. All cycles work fine and the drain cycle is clean, no leaks. On the Internet I have been trying to find a diagram showing how the unit is put together but I have not been able to find one. I know all of these machines have certain areas that you can just pop open but if you don't know where they are you can do some severe damage.
Do you have any idea as to what my problem is. I appreciate any help you can give me.
That is an 7-10 year old model. Buy a new one. You're probably talking about major seal leaks which are gonna cost you a lot of time and money to repair.
Posted on Dec 21, 2008
I recently found that my washer is causing a leak, only on the first drain cycle. The second drain cycle is fine. I thought I had a plumbing problem with the drain, however after snaking it and using ...
The most common leak point for this machine is at the center tub seal. Remove the front panel by removing the screws from the bottom of the front panel. Look at the bottom of the tub, directly in the center. See if there are any water marks around this seal or around the inside of the cabinet. If there is, this is a pretty intense repair requiring specialty tools, so you will likely need to call in a servicer. This typically runs about $300 or more to repair.
Jan 13, 2011 | Maytag LSE7806A Top Load Stacked...
Washing machine leaks at bottom left corner. Water still machine after drain/spin cycyle
My GE washing machine leaks while filling up in the first cycle in the left back corner. Need help!
Jun 16, 2010 | GE Profile WPRE6100G Top Load Washer
GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
Jun 11, 2010 | GE WVSR1060A Top Load Washer
i would inspect both the hoses on the pump
no leak during cycle is explained because water is moving through them to fast to leak when the machine settles it starts to leak
Oct 15, 2009 | Hotpoint Aquarius WD63 Front Load...
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
GE Profile will not run cycles. Runs water continuously.
OK, i would do a hard reset by unplugging for 2 minutes. if the problem still exists, this is defiantly a malfunctioning relay. it will have to be replaced.
Mar 06, 2009 | GE Profile WPRE6100G Top Load Washer
Fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Jun 27, 2008 | GE WHRE5260E Top Load Washer
Machine leaks at beginning of rinse cycle
have you checked the rubber seal round the door might be torn
Mar 03, 2008 | Samsung WF337AA Front Load Washer
Water is flowing into machine & it will not fill
If your machine wont fill, what IS happening? Is the pump coming on & not allowing the water to reach the correct level for the rinse cycle.
Oct 22, 2007 | GE Profile WPRE6100G Top Load Washer
Washing Machines Logo
409 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
