Question about Aiwa AV-D50 Receiver
Center, surround speakers not working. "Can't Use" message for DSP.
We can't seem to get the center and surround-sound speakers on our Aiwa AV-D50 working. All the speaker types are right, and we have everything hooked up correctly into the back of the unit, and the back of the speakers, checked and double-checked. (position, pos/neg, all that.) The left and right speakers, as well as the subwoofer, are working just fine. Another problem, perhaps related, perhaps not, are our DSP buttons. For some reason, we get a "Can't Use" message, no matter which setting we press. Dolby Surround, Live, Arena, etc. It was working fine before we moved to a new apartment and set everything up again, but we can't find out what we've changed that might cause that error, or how we can fix it. Can you help? Any assistance is appreciated.
    President:
  • 3,130 Answers
Sounds like the old stuck button thing after a move??? What i mean it go over all the push buttons and maybe you will find one that is not pushing in and returning??? If alls ok then you should check the obvious like bent shafts or balance controls ect. ay have jogged something inside and you will need to see a pro to assit you unless you know how to trouble shoot solid state electronics?? These units have no real serviceable parts inside. Check with your owners manual for the sevicer nearest you. If they are not listed call the service # or try 1-800-289-AIWA . good luck
Posted on Jun 06, 2006
Sony STR-DH510 Multi-channel AV receiver connected to cambridge soundworks ensemble IV w/ passive subwoofer: no sound from center channel during viewing, or during speaker level test- all other speakers...
The STR directs sound to the center as instructed by its speaker setup. You say the center does not work on calibration. Is it defined?
Prove another speaker does or does not work on the center output. Then we'll know if it's the receiver or the speaker ensemble that has the problem.
Have you checked the manual for this "
There is no sound, or only a very low-level sound is heard from the center/ surround. "?
Aug 03, 2010 | Yamaha DSP-A1 Receiver
Is model AV-D75 compatable to AV-D50?
Compatable [sic] or comparable? Everything is compatible to some degree, but one doesn't often link AV receivers to each other.
The AV-D75, according to what little I could find, is a circa 2000 unit that does NOT some things the AV-D50 does have:
BBE processing
Super T-Bass
Graphic Equalizer
5.1 analog inputs
Numerous DSP modes
Jun 21, 2010 | Aiwa AV-DV75
Only front and center speakers work, not surround.
If by white noise do you mean the test tone generated by the receiver? If so, this is actually pink noise and it is internally generated by the receiver. I would make sure either in the menu or on the remote that you haven't accidently turned off the surrounds and double check the wiring to the surrounds. Good luck.
Feb 15, 2010 | Aiwa AV-DV75
Seems to be a problem with the sound or the
if all you have is bass sound, get into the menu and turn the center channel in option off, this will restore your sound. that is for if you want to use your tv speakers for center in a surround sound system.
Sep 16, 2009 | JVC AV-48WP30 48" Rear Projection...
Hi there, i have a Kenwood V7090D AV receiver. the problem is a) i cannot switch the DSP off without 5.1 switching off as well and b) DSP affests all channels when speakers B is swithched on. if u can...
If you have only Left and Right connected the receiver wont know what to send to the other speakers without some kind of DSP.
If you are using an optical or coaxial connection from a dvd player it may utilize the other speakers if the DVD player is providing that information.
If you dont like the DSP but still want to have all the speakers function while listening to non surround sound material try setting the DSP flat or to a reduced setting.
If you are listening to a DVD with surround sound information and the DSP off still provides no sound to the rear speakers check the manual for that receiver for a "auto surround detection" setting.
good luck.
May 02, 2008 | Televison & Video
AMPLIFIER CENTER CHANNEL NOT FUNCTIONING
Center channel will not work unless unit is set for Surround or Pro Logic. Make sure center channel's volume is up
Apr 28, 2008 | Yamaha DSP-A3090 7-Channel Amplifier
Center Channel Audio
There are probably several sound settings on the receiver :
Dolby surround , stereo, theater, SACD etc.
Try another setting other than the one you have
Dec 16, 2007 | Yamaha RX-V661 Receiver
AV-DV75 center speaker works surround speakers do not
If all others had been fine before this problem arose, and you are sure that you haven't changed anything in your amplifier's channel selection menus, the problem might be deeper to solve! Try these out; 1-If the amplifier has a test menu to check out all channels plugged in, activate it. You must be able to get sound, which is like rustle, from each speaker. 2- Check your plugs, cables etc. be sure that there isn't any short circuit 3- Grab your amplifier's remote control and find the "channel selection menu" that allows you to increase and decrease volume levels for each speaker independently.
Apr 15, 2007 | Aiwa AV-DV75
Can't get all speakers to turn on in AV-1 function
can't seem to get the sound to come on. i knowe i have sound but will not turn on
Feb 09, 2007 | Amphion Mediaworks T-365 System
Aiwa AV-D50 Receiver Logo
386 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
