Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Linksys Rouer BFR stops functioning
HS Internet 1.5Mbps ADSL > 3Com Home Connect modem > Linksys BEFSR41
-Online 24/7
Several times in the last few months I have lost my HS ADSL Internet connection. I've determined it's a problem with my Linksys router, by simply pulling it's power for several minutes.
This router is several years old and up until recently has provided solid service.
Is this router failing or is some outside action causing it to lock up?
TIA; Josh
  • Anonymous Oct 24, 2008
    I have a similar problem with my router, a few days ago things started to run much slower.
    then internet connection were lost and now I can't get the router to see the computers.
    modem works fine , WAN lights up, but the ports 1-4 show no activity when either or both of the pc's are plugged in. The adapter says cable not plugged in??
    I did notice that the link/act leds were flashing really fast during those last few days. .. now resets don't work power down and back up either, nothing is seen as being plugged into any port except the WAN .. think it's time for a new one????
  • Anonymous Mar 17, 2014
    I lost my linksys site and have reentered the code several times but it will not connect. The lock button is on the link site.
  • Linksys Master
  • 6,487 Answers
There's a possibility that the router is already going bad but you can try first updating the firmware of the router because sometimes this problem is related to the software of the router so you may need to update its firmware,but if still after updating and still the same a new router will be the best solution for this problem of yours..You can also call this number for technical support help and double checking if the router is bad or still can be fix 1-877-787-8749...
Don't forget to rate the solution FIXYA thank you....
Posted on Oct 18, 2008
Hello, my internet service provider gave a preinstalled modem to use, however I would like to use my Linksys Wireless - G ADSL Home Gateway to be able to connect my devices to the internet wirelessly......
No. Your wireless router will not be recognized as a modem, nor will your service provider allow it if it would work. Plug the router into the modem.
Plug a cat 5 wire in from the yellow jack on the router to the same on the modem (it may not be yellow). The rest is software. Reboot everything and run the wizards depending upon the version of windows you are using, which you don't mention, BTW.
Your service provider may offer to help you set up your home network. Give them a call.
Thanks for your question @ FixYa.com
Aug 04, 2011 | Linksys Wireless-G WRT54G Router
My internet connection is slow. wireless home network setup connected to adsl.
is it as slow as when you connect it from the router(not the modem) to your pc with a wire instead of wireless? if so its bc adsl is slow in nature and you may need a filter adapter going into your MODEM first
Mar 25, 2011 | Linksys Wireless-G WRT54GL Router
I am currently using a Linksys BFR series router that works fine. I am trying to replace it with a Linksys WRT 300 N router. I go through the installation program provided by Linksys on my HP computer...
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 20, 2010 | Linksys WRT300N Wireless Router
The area connections with internet were lost
Try updating its firmware, if its not yet making any improvements, consider buying a new one.
May 08, 2009 | Linksys EtherFast BEFSR41 Broadband Router...
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Woodenthings
Your provider probably sent you either a cable modem or adsl modem. If you connect the single port on the modem to the WAN or Internet Port on the Linksys and then connect the computers to any of the 4 ports that are grouped together, it should work.
Mac or PC, it makes no difference and drivers are not needed.
Unless this is a new router or it is one that you personally configured, I recommend resetting it back to factory default by holding down the little red button for 30 seconds, this eliminates any configuration issues that someone else may have introduced.
Jan 03, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Setup and confifuration of my linksys befsr41 ver 2 router
Since you did not include your exact model number and type of internet provider I cannot give you more specific instructions. Although you can refer to the links below on how to set it up. If you require further assistance just reply to this and give me the model number of your ISP and the model of your router. Also answer this question " When you plug your computer to your modem do you get online automatically or do you need a username and password"
DSL
Cable
Dec 17, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I cannot install the CD for my router
u can simply connect connect modem to internet port on router and connect no 4 of linksys to computer and u will be able to go online ....
Oct 22, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
3com router dmz doesnt allow to ssh to the asa
undo the dmz and forward the ports 22 for ssh and any other services you need to the cisco. Ok dmz is not good... 3com calls port forwarders virtual servers just add what you need there... hope that helps.
Mar 20, 2008 | 3Com OfficeConnect Router
How to connect linksys router with aztech adsl modem
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
Nov 16, 2007 | Computers & Internet
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
100 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
