Question about Zenith DBZN-311 Remote Control
Help!!!!!!!!!!1 I have a Silvania TV and it was working very good with this Sentry RMC-10 control but I pressed the button TV-VCR by mistake and something happened to the tv, now there is no sound and appeared strange numbers on the screen and the control doesnt work on my tv, not even its own original remote control. In order to shut off the tv i have to unplug it.
    Genius:
  • 1,124 Answers
You switch your tv between video and tv ....hit again the key tv/video once. That's it.
if you have a VCR or digital box remember that yout TV must be always set it up on channel 3
(put this manually on your tv)
This will fix your problem.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Posted on Oct 18, 2008
I need codes for my tv brant and directions forModel rmc 10 sentry big remote
The instructions and different (TV,VCR etc) brands and their respective codes are
http://www.sentryindustries.com/pdf/instructions/RMC10_Instructions.pdf
Oct 16, 2012 | Sentry Safe Sentry RMC10 Universal Jumbo...
Sentry RMC-10 remote can't 'discover' my tv's code
.there are several codes. try each one seperate.
1. press and hold setup button until the red light stays on.
2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
3. enter one of the 4digit codes.
note: if the code is valid the light will turn off if it flashes it is an invalid code.
4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
CODES:1171,0116,0167,0176,0922
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 28, 2009 | Sentry SE-RMC10 Remote Control
Remote Control Jumbo sentry Model RMC-10
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
Jun 09, 2009 | Zenith DBZN-311 Remote Control
Thanks but i need more help
Don't be panic.
Check the batteries of your remotes control. FIRST
Be sure to aim the control to the sensor of your tv.
Usually you have one remote for your tv and the other to control the cable box or digital box.
You have to set the RMC10 again using the code of your tv Silvania (like the first time)
Then set your tv on channel 3
Another thing, be sure that you are hitting the right buttons.
The control doesn't work if you hit on the top any key instead of cable
What i mean?
The remote has on the top 4 key usually (tv, cable, vcr, aux, etc).
You must hit first cable to set the control to cable
1, Manually turn on the device(TV, VCR, etc.) to be controlled.
2. Press and hold the code search button until the red indicator stays on, then release the code search button.
3. Press and quickly release the desired mode button (TV, VCR, ect.). The red indicator blinks off once.
4. Press the Channel up button repeatedly(up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press channel down button to backtrack through the library until device changes channel. Pressing Channel up changes direction forward again.
5. Press and release Mute to install code.
Don't forget to rate my help!
Have a great day!
Pablo :-)
Let me know how it is going!
Oct 18, 2008 | Electronics - Others
Sentry really big universal remote
the following is a link to the updated code list for the RMC-10, note it is in pdf format so if you do not already have adobe acrobat reader you will have to download that before you can read the code list. I will also leave the link to download the adobe acrobat reader in case you need it
Hope this helps
Carl
http://www.adobe.com/products/acrobat/readstep2_allversions.html
Feb 07, 2008 | Televison & Video
Remote control
I was able to get my Motorola DVR Cable Box to work with my Universal Remote using the following instructions:
The Instruction Manual for Manual Code Search seems incorrect. (Page 5).
A) Manually turn on the device to be controlled. (O.K.)
B) Press and hold the code search button until the red indicator stays on, then release the code search button. (O.K.)
C) Press and quickly release the desired mode button (TV, VCR). The red indicator blinks off once. (O.K.)
D) Face the remote control directly to the device you want to control. (O.K.)
E.) Press the ON/OFF Button (this should read CHANNEL UP button) repeatedly until the device to be controlled changes channel. The red button blinks off with each button press.
F) Press and release enter to install the code. (O.K.)
-Note, the remote is able to change the channel, however, it does not control the volume.
Jan 03, 2008 | Televison & Video
I need the instructions and codes for my really big remote control
HAVE THE REALLY BIG UNIVERAL REMOTE SENTRY RMC-10 .
I NEED THE CODE FOR THE DVD/RW SV2000 RECORDER
Jan 02, 2008 | Bushnell Sentry 78-1836 (18-36x50 mm)
Sentry RMC-10 codes
This is the official Sentry website with the updated .pdf of the codes to the RMC10 Really Big Universal Remote:
http://www.sentryindustries.com/category/remotes/remotes_rmc10.asp
Dec 26, 2007 | Televison & Video
Zenith DBZN-311 Remote Control Logo
61 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
