Question about Mitsubishi WD52527 52" Projection HDTV
Mitsubishi wd52527 flashing green timer light flashes very fast for about 1 minute and then go,s out, but tv won't power on
  • 4 more comments
  • ivery809 Oct 18, 2008
    have a mitsubishi wd52527. green timer light flashes very fast for about 1 minute and then go,s out. but tv won't power on. green timer light continues to flash every minute.
    yes it does
  • amysu23 Nov 29, 2008
    The light for the "timer" flashes but the tv wont turn on, even with a remote the tv won't turn on. I have tried pressing the "system reset" button, but it only proceed with the flashing green light for the "timer".
  • melvin myles Dec 15, 2008
    timer green light flashes tv comes on for 30 seconds and goes out timer continually clicks on and off get into menu and tmer is shaded
  • tkraft31 Dec 23, 2008
    I am having the same issue with the blinking green light and resetting and powering down as netted no results. Does anyone have a fix for this problem?
  • trish7466 Mar 21, 2009
    the Green light flashes for 30 sec i push power tv comes on for 10sec then red light comes on wich is the lamp light.
    Novelist:
    Champion:
  • 203 Answers
Does the light flash for 1 min then pause for a second then blink for another min?
Posted on Oct 18, 2008
Yes
Posted on Dec 15, 2008
TV taking a long time to initially turn on after it has been setting. The timer light will flash green for about a minute than the set will turn on.
Change the TV Energy Mode to "Fast Power On" in the Set Up menu if the TV takes an excessively long time to power on. The TV Energy Mode could be set to Low Power.
You can download the user manual from Sears.com
http://download.sears.com/own/5754146e.pdf
Oct 31, 2011 | Mitsubishi WD-65731 65" HDTV
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Timer light did not stop flash
Lamp is not the issue. It most likely is a your DM card. You most likely have some capacitors that need to be replaced. This is a terrible issue with this unit. Do a google search for "DM" and the model number and you should see hundreds of posts.
Jul 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Timer light blinks constantly
Is it Mitsubishi WD-52628 TV? please confirm model number.
Unplug TV from AC outlet for couple of minutes, replug back in, turn power ON and check, still same problem?
Lets read error code in TV, press Device and Menu buttons on front of TV at same time for 6 seconds that will activate error code read process. Led will flash in 2 sequence with half second pause. count it and let me know the error code to proceed.
Thanks.
Jun 29, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi 52" WD52725 flashing green timer light
your projector bulb went out. you need to call the manufacturer and order a new bulb. they cost 300 to 400 dollars a piece I believe your tv only has one bulb and they are really easy to install.
hope this helped
please rate well.
Mar 06, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Green light flashes and than goes off for 30 seconds.
If your TV is a Mitsubishi, there is no count actually. You are the victim of the famous "green flashing light" problem. This is resolved by replacing a number of bad capacitors on the "D" board I believe. If you can solder, you may be able to resolve this. Be aware however that some of these caps may be surface mounted which is a more intricate task.
Let me know if you wish to attempt this and I'll provide more details.
Dan
Jul 30, 2008 | Mitsubishi WD52527 52" Projection HDTV
Mitsubishi WD52527 Timer LED FLashing Rapidly
This could be bad caps on the "DM" board. To confirm this though, can you count the blinks please and post here?
Thanks,
Dan
Jun 06, 2008 | Mitsubishi WD52527 52" Projection HDTV
Mitsubishi WS73713 - Now working - Timer light flashing.
hold menu button for 8 sec and then unplug for 1 minute. then when you plug it back in it will work after 1 minute
Dec 30, 2007 | Televison & Video
Mitsubishi WD52527 52" Projection HDTV Logo
470 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
