Question about Garden
Riding lawnmower blade
How do I jack up the tractor safely OR how do I remove the cutting deck? I need to clean it out and replace and/or sharpen the blade.
  • Anonymous Jan 17, 2009
    how to do maitence on belt and deck
  • 14 Answers
First, always wear safety glasses and hand protection when working on machinery. Also include my favorite saying; "Common Sense Prevails". No amount of overgrown lawn is worth getting hurt. Work on as flat a surface as possible, always chock the tires in both directions to prevent movement and disconnect the negative battery cable making sure it will not contact either battery posts while working on the mower. This will insure the engine will not start on it's own or the mower move of it's own accord. Release the parking brake, with the shifter in "neutral" position. Check your tire chocks and make sure the mower is not going to roll in either direction. Now, lower the deck to it's lowest position. Now loosen any guide pins that extend from the underside of the main chassis that keep the belt from coming off the drive pulley on the engine. Again, there may be one or more. Remove the belt from the pulley. Now find the linkage that tightens the belt when you engage the blades. It should extend from the chassis at an angle to the deck. If your mower is equipped with a PTO (power take off) clutch that engages the blades by a switch on the dash, skip this step. Now remove the clips that secure the raising\lowering arms from the linkage at the top of the arms, not the deck end. This will allow you to slide the deck, slowly and carefully out from under the mower, with out the arms "dangling" from the mower interfering with the deck. You will have to adjust the angle of removal as you are sliding the deck as most have an "attack angle" that is not 90 degrees from the strait line of the mower from front to back, but is angled more forward on one side or the other. Once the deck is clear of the mower, depending on the size and weight you can lift it (with help) or use a floor jack to raise it (being VARY careful not to contact the blades) and lower it onto 4 blocks at least 4 inches high. Place the blocks at the 4 "corners" of the deck. Two blocks long enough to run past the length (front to back) on both sides of the deck will work as well. Remove the covers on both sides of the deck that cover the belt\pulleys on top of the deck by removing the bolts that secure them. Most are a self tapping type, some have nuts and washer on the underside, and some have studs welded to the deck, so you don't have to reach underneath. Some tractors have one of these covers, some two, and some non at all. Clean the top side of the deck with high pressure water from a garden hose, or a pressure washer if you have one. Be careful of flying debris. There may be rocks, pebbles or other items that can become flying missiles and injure you, or someone close by.Flip the deck over, again being careful not to trap your (or your volunteer's) hand between any moving parts and the deck (like between the sharp side of a blade and the deck housing) and place on your blocks in the same position. You can now access both the nuts holding the blades and the top side  of the pulleys that either have nuts as well, or are made to accept a wrench or socket. Using a block of wood, ("2 x 4" x 12" is a good size but adjust the size to fit your particular deck) insert the block between the deck and one blade on the side of the blade that will stop it when loosening the nut holding the blade, making sure to get a good "bite" so it will not slip when pressure is applied. You can also use a wrench or socket on the pulley retaining nut on the top of the deck to stop the blade from moving as they both employ the same shaft. A volunteer to hold this is a good idea, perhaps a must. Make sure to equip them with safety gear as well. Apply a good lubricant like PB Blaster to the retaining nuts on the blades. Allow at least 15 minutes to absorb. Using either a 3/8" air gun or ratchet, or if using hand tools, a 1/2" breaker bar with the proper size socket of an impact grade, loosen the nut holding the blade. Your volunteer can help by hold the deck as you apply pressure to the bar. An extension of the breaker bar's handle with a piece of steel pipe having an inside diameter not much bigger than your breaker bar, and no more than a couple feet in length can be applied for more leverage, however this should only be done by someone with experience using the technique. Better to use air tools or a proper extension than bust up your hand by a slipping ad hock device. Remove the nut and washers, keeping them in the proper order for re-installation, and remove the blades noting which side is up and down. The cutting edge of the blade is always the lowest part of the blade when attached. Clean the underside of the deck. You may have to include a scraping tool as grass buildup can become quite hard over time and appear to be part of the deck. Pay special attention to moldy, wet grass around the blade shaft. This kind of moisture can induce corrosion prematurely to the deck housing and the bearings\shaft housing. Look closely for any type of wire, line from weed eaters, cables or any line that can be picked up by the mower and can wrap around the blade shaft between the blade and the deck. This line can eventually work it's way into the bearings, causing the bearings to fail.  Carefully inspect the shaft, bearing and it's housing for damage, corrosion, etc. Repair\replace as needed. Remove any surface rust with a wire brush (hand or power) again watching for flying debris. Inspect the blades, looking for obvious impacts that have caused visible damage to the blades. If found, remove the blade shafts and check to be sure they haven't been bent. If they have, don't try to straiten them, but replace them. A bent shaft will have caused undue wear on the bearings, and a straitened shaft will be weak where the bend was. A failure of the shaft, bearings, or bearing housings can be fatal if the blade becomes detached and manages to fly out from under the mower while in use and strikes someone nearby. Now sharpen the blades, or replace them if needed. An experience blade sharpening service should be employed as the angle of the cutting edge and the level plane on which they travel is critical. Simply using a grinding wheel will not give you anything but a sharp piece of steel, but will cut unevenly. Clean any buildup from the blades and the shaft's mounting platform for the blades as rust or any foreign substance will cause the blades to be at an improper angle. While the deck is removed, inspect the holes where the raising\engaging linkages attach looking for wear to the hole or the linkage shaft. Replace if any undo wear is detected. Check for side to side movement of the pulley\blade shafts indicating a worn shaft or bearing. Replace if needed. Check the bearing housing the shaft travels through on the deck for electrolysis corrosion cause by dissimilar metals in a moist environment), cracks or other damage. Replace as needed. Inspect the deck belt for wear, cracking or age and replace if needed. It's always a good idea to replace it regardless when performing this deck//blade service. Reassemble in the reverse order of dis-assembly, using Loctite red on all threaded surfaces, and greasing any available grease fittings. Apply a coating of graphite lube or grease to the linkages where the attach to the deck an mower. Make sure all fasteners are tighten to proper specs. Lift the deck to it's highest setting, engage the parking brake, and reattach the battery. Start the mower and engage the blades checking for any undo noise indicating loose parts. Check the deck movement by lowering to different settings always listening and feeling for vibrations or noises. Should everything be in order, you may consider leveling the deck for optimum cutting performance. But that's a different question........ Best of luck, and please indicate your rating of this solution if appropriate. Thanks so much, Papa
Posted on Nov 18, 2008
I have a florabest electric lawnmower, the blades are turning and were sharpened recently but it is not cutting the grass...any ideas?
check that the blades were put on correctly and the sharp side is in the right position . if not then the blades are trying to cut the grass on the back side un sharpened side.
Jun 02, 2013 | Garden
I have a John Deere LA105 Riding Mower and when I mow it leaves a strip of grass in the middle. Left and right sides are cutting fine. I have taken the blades off and shaarpened them and have leveled...
jack the tractor (using a tractor jack) or remove the deck, measure the blade tips against each other where they meet in the center of the deck and see if they are the same tip to tip. Bearing wear, a bent deck or blade can make them cut at different heights in the center.
Sep 25, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do you replace the belt on the mower
Without looking in the manual, I would suggest removing one of the blade housings. First, jack up the tractor from the middle of the rear axle. Use some jackstands as a safety net to keep the tractor from falling, I usually use two jack stands for total support and be sure to scotch the front wheels so that the tractor is sturdy, unable to move and safe. Next, note the routing position of the belt. I have replaced 2 of these blade housings already from shearing them while mowing. There should be 4 bolts running from the top of the deck thru the blade housing. When this housing is removed take the old belt off and reinstall new belt. Reinstall the blade housing and you should be set.
Jul 15, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
How do i replace a blade that had fallen off. 42 inch tractor. The main problem is how to get underneath the tractor?
To replace blades, belts, sharpen blades, etc. one must remove what is called the cutting deck from the tractor.
Once the deck is off the tractor, pull it out, turn it over and you can work on the blades.
Jul 10, 2011 | Ariens 42" Riding Lawn Mower Blade ...
Hi There The cutting deck is not cutting properly, is worn out and needs replaced
Have you sharpened the blades? They must be sharpened regularly.
Also, the deck should be level left to right and be slightly lower in the front of the mower.
Ensure that the blade is installed with the sharp edge closer to the ground when installed on the mower.
Feb 07, 2011 | Husqvarna Garden
How do i remove the cutting blades to sharpen them
you could take the mower deck off and do it that way or you could jack the tractor up. i recomend that you use a 1/2 inpact gun or a 1/2 breaker bar
Oct 01, 2010 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
The mower is mowing uneven in the front. what can i do? it seems that it is scalping the grass but both sides are level
Look under the mower deck. If you can't see well and work on it, you may have to remove the mower deck and flip it over on the ground. Grass and mud buildup in the decj could cause a blade to pinch grass, 'scalping' the lawn. Clean it all out. Dull blades cause cut grass to look torn and brown. Remove and sharpen. Bent blade will cause uneven cut. Replace it. Good luck! Please rate if you found this helpful, thanks!
Jun 05, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Duel blades on craftsman riding mower cut unevenly
check the front tire air pressures then for a bent blade
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
967 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
