Question about Frigidaire CWS3600AS Top Load Washer
Fridgidaire 7 cycle - older model top loading washing machine wont drain
My machine filled...and spun. Now, when the timer progresses to the cycle where it normally drains and spins and just hums...the timer progresses clockwise until it does nothing.
  • 958 Answers
Could be a stuck gear box. motor trying to turn it on the reverse rotation for spinning. it could be the motor that hums. or the belt could just be loose.
inspect the belt and see if it is loose and adjust it if necessary.
tnx 4 using fixya,
Posted on Oct 18, 2008
I have a Hoover top load 610 and it wont start wash cycle
These are a great little machine,I dont know why they have to go changing things.Anyway this sounds to me like the timer.It fills & the water cuts off so the inlet valve is ok.It drains so the pump is ok.It spins so the motor should be ok.Try it on other cycles like gentle or delicate & see if it agitates.I'm sure it will be the Timer.
May 22, 2010 | Washing Machines
Top load washer won't go through cycle
modle problem here its the main board common fault with this model good luck
Mar 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Cycle switch must be moved manually
what you gona need is a new timer knob.
copy n paste this web address;
"Was this helpful?"
May 08, 2009 | Maytag LAT3600A Top Load Washer
Washing machine wont wash or spin, just fills and drains
Apr 24, 2009 | Washing Machines
Washer gets no power
are you sure the outlet has power? make certain by plugging in a lamp or something else to the outlet first. the timer does have to get power to turn on the unit, but its not likely it is the problem.
try a different cycle and see if it wont run on any position. like fill, wash or spin. then if your outlet is ok, it could be the timer.
i dont think it is but it could happen. usually if the timer fails, it will work on some cycles but not all of them. if it wont work on any cycle then i would expect the outlet first.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Dec 29, 2008 | Kenmore Washing Machines
Fridgidaire model fwx223lbs4 will wash, but won't spin fast and the water won't drain
HI thanks for the question it sounds like the pump is either burnt out or jammed with debris thanks the appliance doc
Sep 08, 2008 | Frigidaire CWS3600AS Top Load Washer
No spin
you say the machine is tryng to drain. does in drain? if it doesn't the pressure (fill) switch is preventing it from spinning because there is too much water (weight) in the tub
Jul 03, 2007 | Kenmore 9297x Top Load Stacked Washer /...
Washer Problem - Fills but doesn't start wash cycle.
you got a broken clutch and is ease to replace, tilt the washer to the floor with the motor in the upper position, remove the motor(two litettle scews) and remove the clucht(you will see it, is a small ruber pices) go and by a new($12.00us) one and replace it, replace the motor and thath is...good luck...
Jul 24, 2006 | Whirlpool LTE5243D Top Load Stacked...
Frigidaire CWS3600AS Top Load Washer Logo
158 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
