Power supply board component out
Hi robotek. one day when my nad t562 dvd player was only about 18 months old, a component that looks like a large resistor on my power supply scorched the board and the capacitor next to it. i didn't have a proof of purchase, so i didn't pursue warranty repair. now that i know how to solder, i'm wondering how i determine exactly what the parts are and if i can replace them on the board, or if i need a new board and where i might get it. i have not heard back from nad tech support. i can send photos.
  • 1,512 Answers
Hi goikem
I would replace the capacitor first and check the resistor with an ohms meter to see if it has changed in value(gone high). remounting the resistor (you may have to replace it also to do this with longer leads) to be clear the Pcb and also the capacitor to be as far away from the resistor as a heat source also may help. Darkening of the board is not uncommon where there are power components. Having said that, it should not generally happen in the first place... but it often does. Power supply failures in modern gear relates to heat stress so often. Capacitors failing from this overheating is the biggest problem of all. In the workshop, where we suspect that caps have failed, we generally replace them all, and always use good brand name 105deg rated devices(Rubycon or Nichicon brands i prefer) to help minimise the recurrence of failure. You can order them from Farnell in most countries of the world. If you cannot identify the values of the components, I am happy to try and help you here. Please feel free to ask any questions you may have. FixYa rating is the best way to thank me for helping you out. Cheers
regards
robotek
Posted on Oct 18, 2008
How do I fix backlight problem on JVC LT32D-500 TV. I want to know if it is perhaps a common problem with this model and it it is FET or transistor related.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Oct 06, 2015 | JVC Televison & Video
How to reset a nad T562
To reset it to factory settings, you have to enter its Service Mode option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jul 26, 2014 | NAD T562 DVD Player
My toshiba sdk990ku dvd player stopping playing the audio. Have connected via HDMI to LCD HD tv and worked for months! One day audio stopped, but picture is fine. Tried different HDMI cables, dvds with no...
Tries unplug,replug it back like an hour later.Letting the DVD player resetting itself back to the factory setting.Tries it than,see if it work than.Not,than tries hook it up with the RCA component cable Y,R,W.If still have the same problems,the PCB in the DVD player is bad.Not worth repairing.Trash it.DVD players are very cheap these days.U can get a brand new one like for $40 dollars.
Nov 18, 2010 | Toshiba SDK990 Player
BLACK AND WHITE
Hello.
1. Have you tried to switch channel to AV or RGB on your TV?
2. Some DVD Players have internal settings for the output mode if you go into the menu and settings on the DVD.
3. If its connected to the TV via a scart cable make sure the connectors are fitted all the way into the socket on both TV and DVD
Hope this will help you with your problem.
Thanks for using FixYa
Feb 10, 2009 | NAD T562 DVD Player
Ilo dvdr05 needs power supply
Most electronic components are available at any large parts warehouse, except maybe the power transformer, and other indigenous parts. What part of the power supply do you need?...accordianman
Mar 05, 2008 | iLO DVDR05 DVD Recorder
RCA DRC246N Power problem
I had this problem after only a few months of use! There were some bad capacitors on the power supply board. Replacing them fixed the player. They used cheap electrolytic capacitors on this unit; check them all while you have it open.
Jan 21, 2008 | RCA DRC246N DVD Player
Sony DVP-NS55P DVD player will not power on. No LEDs light and no display message appears when the on/off button is depressed (dead). Fuse on power supply board is ok, no components look fried,...
If it is the power supply then the whole unit should be replaced. Or it indeed may be the power on button its self. Only technician with the appropriate knowledge of the particular machine will be able to tell and have the means to check it out.
Jul 31, 2007 | Sony DVP-NS55P DVD Player
Tray won't open
What your husband is doing appears to be the right approach. Looks like the CD was not inserted properly and must've gone out of its seating and preveting the door from opening. Just pusing the CD back to position should take care of it.
Jan 02, 2007 | NAD T562 DVD Player
141 people viewed this question
 Grubhead
Grubhead
